Question about Refrigerators
The ice machine in our bottom drawer freezer makes very little ice. it seems the arm goes up right after the first batch of ice is made.
    Genius:
  • 1,073 Answers
What is the model number
Posted on May 05, 2008
What to do after new water filter installed ice stopped being made?
Need to change water head (the part that the filter fits in).
Aug 29, 2014 | Sub-Zero 650 / O Bottom Freezer...
Need ice maker arm replacement
www.partstap.com has helped me in the past with freezer parts....
Jan 20, 2013 | Samsung RF265AA Bottom Freezer French Door...
Model b198 makes one batch then stops
Check the bin arm spring you will have to disassemble the front of the ice maker to do this and check timer motor could be getting hung up. not a cleaning problem. or replace the complete head.
Oct 09, 2012 | U-Line Icemaker
The ice maker in my 550 bottom drawer makes ice but does not shut off before spilling a few ice cubes into the drawer. In lookin at teh metal arm that exrendes into the tray it appears that it may not...
good day,
Sub Zero makes both a wire device and on some models a round rubber device that slides over the ice level arm. If you don't have one on your model, call your local appliance parts house and check with them. The wire model just clips on, the rubber style has a **** in it. The purpose is to shut the ice maker off before it becomes too full, causing your problem.
Nov 22, 2010 | Sub-Zero Bottom Freezer Refrigerator
Not making ice fast enough
Good day,
Assuming the cubes it's making are the proper size, the speed the ice maker produces ice is determined by the temperature in the freezer.
When the ice maker harvests a batch of ice, an electric heater heats up the whole ice maker.
There is a thermostat embedded in the ice maker. It must cool back down to approx. 12 degrees before making the next batch. The colder the freezer compartment, the faster the cycles.
If the cubes are too small then that is usually caused by a blockage in the water filter if your unit has one, or the water valve that feeds water to the ice maker is getting weak, or lastly the water supply to the machine has become partially restricted.
On extremely rare occasions the thermostat built into the ice maker goes out of calibration which can cause a delay in cycling and requires the ice maker to be replaced. But again, it is a very rare occurrence.
Oct 27, 2010 | Sub-Zero Bottom Freezer Refrigerator
Seems to be cooling fine but makes a buzzing sound for 7 seconds then stop.
The 7 second buzz would be from the water valve trying to fill the ice maker that is in the freezer.
My guess is that your refrigerator is not connected to a water supply. You can stop the buzz by opening the freezer drawer and turning off the ice maker, it will have either an on/off switch or an arm on the right side that lifts up and locks in place, that will stop the buzz
Apr 18, 2010 | KitchenAid Architect KBRA20ERSS Bottom...
RF266ABPN French Door Firdge/freezer Ice maker sensor
I found David's solution very helpful and I'll just add to it. Take out the top freezer door-- it just slides out and up. I had a bunch of stuff on the little shelf on the actual door and I had to take some of it off first. The big bottom drawer stays on. The little foam piece was on the floor of the freezer so I picked that up and can see how the little sensor part fits into it. Next, I put a chair next to the open bottom drawer, sat on it and leaned back onto and into the big drawer. I had to torque my head to actually get right under the ice maker. I am 5'5" so I don't know the heck David did it! Anyway, there is a little "slot" next to the last ice cube mold closest to the door. This is where the foam piece goes in. The slot where this piece goes has some raised lines sticking out on each side-- I wouldn't call them brackets and the foam thing doesn't stay in well by itself. However, on the right side of the ice maker, near that last cube, is a little hook. So I slid foam piece up with the sensor tucked in, facing the ice cube mold. I wrapped the tail/wire around the bottom of the foam piece and also the hook, so that it kind of holds the foam piece up in there, kind of cradling it. That was my solution, we'll see if it works!
Sep 29, 2009 | Samsung RS2534 Side by Side Refrigerator
Feeler arm on ice maker prevents freezer drawer from opening
Hi, There is no adjustment on the level arm other then bending it. Is it posible that something snagged it as the drawer was being pulled out and bent it? The arm should collapse all the way down tothe side of the icemaker and level with the bottom of the icemaker.
Hope this helps. Please let me know if I can help further.
Vic
May 11, 2009 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
