Question about Toshiba REGZA 42RV530U 42 in. LCD HDTV
Remove stand from toshiba bottom of tv - Toshiba REGZA 42RV530U 42 in. LCD HDTV
  • 10,594 Answers
Remove Four Screws as mentioned in below image and lift up tv to remove stand. Or face down tv on some clean flat table/ surface and remove marked four screws and pull out stand.
Hope this info will help you.
Thanks.
Posted on Aug 26, 2010
3 Suggested Answers
SOURCE: Removing bottom stand Flat Panel LCD Magnavox 32MF605W 32
There are 4 shiny screws at the back of TV just above the stand neck. Unscrew those 4 scrws and then lift the TV up, stand will come out.
Posted on May 21, 2008
  • 4 Answers
SOURCE: Removing the stand off the boton of the TV
on the bottom of the foot there are some screws that u agve to take out
Posted on May 15, 2009
How do I remove the stand from a toshiba 32hl57 tv
  • 1 & 2 Remove all cables and lay down towels on a clear space.
  • 3 Set the 32HL57, screen side down, onto the towels gently.
  • 4 Locate the four screws at the bottom center of the TV. These screws attach the stand to the Toshiba 32HL57.
  • 5 Using the Phillips screwdriver, unscrew all four screws, one at a time.
  • 6 Once the screws are completely removed, grab the base of the stand and gently pull away from the TV.
  • Read more : http://www.ehow.com/how_7318172_remove-stand-toshiba-32hl57.html
    Jan 20, 2015 | Toshiba Televison & Video
    Not sure how to remove bottom stand from the tv
    Lay the tv down to flat cushine surface like a bed maybe.Take all the tv Philip screws out of the base stand,give it a little tuckles like fordward or backward of the tv base stand will come wright out.
    Jun 17, 2011 | Toshiba 37LX96 37 in. LCD TV/DVD Combo
    I can't remove the stand off the tv
    Hi, i have instruction on removing your base stand.
    Removing the Pedestal Stand
    1) Carefully lay the front of the unit face down on a flat,
    cushioned surface such as a quilt or blanket. Leave the stand
    protruding over the edge of the surface.
    Note: Extreme care should always be used when removing
    the pedestal stand to avoid damage to the LCD panel.
    2) Remove the jack pack cover on the back of the TV to expose
    the pedestal stand screws. The jack pack cover can be removed
    without tools.
    3) Remove the four screws shown in the diagram below. This will
    allow removal of the pedestal stand.
    4) Once you have removed all four screws holding the pedestal
    stand in place, remove the pedestal stand from the TV by
    sliding the pedestal stand away from the TV.
    Feb 12, 2011 | Toshiba REGZA 52RV530U LCD TV
    Im wanting mount my 37 in toshiba regza but i can figure out how to take off the bottom brace that supports the tv as it stands. i have taken off all the screws but the brace or base still wont come off.
    Carefull turn the tv on it's back and remove the 2 black screws in the bottom of the stand in addition to the screws on the back that I assume you already removed.
    Nov 10, 2009 | Toshiba REGZA 47HL167 TV
    I have a 52in Toshiba flat screen that I want to take the base of of so that I can mount it on the wall. The model number is 42XV540U.....I have removed all the screws from the bottom of the base of the...
    Check carefully with a flashlight to see if you removed all the screws completely. The stand should pull out quite easily as long as all the screw are out on the back bottom center of the TV.
    Nov 09, 2009 | Toshiba REGZA 47HL167 TV
    How to remove tv stand from toshiba 42 inch lcd model 42hl167
    Remove 5 screws as shown in below image to remove stand of TV.
    It is also mentioned in user manual of TV page-5, click Toshiba Support to download a copy, if required.
    Thanks.
    Aug 30, 2009 | Televison & Video
    Taking stand off toshiba regza tv
    forget the four holes on the bottom of the stand. Remove the five allen bolts on the back bottom of the tv-not the stand. Yank on stand and metal plate slides out with stand.
    Jan 25, 2009 | Toshiba REGZA 47HL167 TV
    Question on toshiba tv - fixya post
    Found this on the www.Toshiba.com website. Q. How do you remove the stand?
    Models: 26HL37, 26HL47, 32HL17, 37HL17, 42HL17, 32HL37, 26HL67, 32HL67, 37HL67, 42HL167, 42HL67,
    47HL167, 52HL167, 42LX177, 46LX177, 52LX177, 57LX177
    REF:FAQLCD00078
    1. Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand
    protruding over the edge of the surface. NOTE: Extreme care should always be used when removing the pedestal
    2. Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can
    be removed without tools.
    3. Remove the five screws shown in the diagram below. This will allow removal of the pedestal stand.
    4. Once you have removed the five screws holding the pedestal stand in place, remove the stand from the TV by
    sliding the stand away from the TV. The Toshiba customer service number is 1-800-631-3811. Hope this helps you with your problem.
    Dec 22, 2008 | Toshiba 42HL167 42 in. LCD Television
    Remove swivel stand
    There's likely a plastic cover on the back of the swivel stand. If so, remove it and you will find four to eight phillips screws. Take them out and the stand should come free. If there is no plastic cover, then there should be some screws in the back cover that go through the back cover and into the support. Remove the screws and gently remove the stand. Good luck. David
    Sep 05, 2008 | Toshiba REGZA 46RV530U LCD TV
    Removal of stand
    There are 5 screws in the back of the TV, immediately above the stand. From the stand, they are at the 10:00, 11:00, 12:00, 1:00, and 2:00 locations. If you remove the screw, and find a washer with the screw, then it's probably the right one. Once all 5 screws are removed, the stand slides right off the bottom. Unfortunately, once the stand is removed, the opening is left in the bottom. It's not too bad since once it's mounted to the wall, it's not high enough to see the bottom of the TV anyway. Good luck!
    Aug 09, 2008 | Toshiba REGZA 47HL167 TV
    Toshiba REGZA 42RV530U 42 in. LCD HDTV Logo
    590 people viewed this question
    Top Toshiba Televison & Video Experts
    Jaime Hernandez
    Henry  Thomas
    Henry Thomas
    Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
