Water leaks from unit often - Heating & Cooling
    Genius:
  • 1,970 Answers
Mcdevito75 Here, all A/C units leak water, if your unit is a window unit you"ll have to re-tilt the unit so that it is leaning more toward outside the window and not toward the inside. Contact an A/C shop in your area they come to the house.
Posted on Aug 26, 2010
My hot water tank is continually leaking ? I shut off the valve at the top of the tank and it is still leaking ??
They wear out especially if they are older. You did not say what make and model it is but if there is water coming out the bottom it is time for a new unit. The leak is still happening because even though there is not supply pressure, gravity is pulling the water out the break in the liner.
Jul 05, 2016 | Water Water Heaters
Why is my keurig 560 leaking water from the base
Most likely the water lines inside your unit are leaking. If you can take the bottom of B60 off and look inside the unit. Usually, the line that comes off the water pump is leaking at the T connector. If not leaking there look for other signs of leaking while the bottom is off. You can call Keurig 800 number to see if your unit is still under warrenty. Hope this helps.
May 28, 2014 | Keurig B60 Coffee Maker
Kenmore elite 596.735 .water leaking from rear of water filter unit.
What is the complete model number of your unit? Look inside the refrigerator section.
Oct 21, 2012 | Kenmore 73502 / 73504 / 73509 Bottom...
Carrier Infinity AC indoor unit in the garage is leaking water on the floor. There is no ice on the coils, The drain is not clogged. There is no water in the coil area. I turned off power to the...
It seems as though you have an unrelated water leak....
Often the water supplies are copper tubing....
Copper tubing and concrete do not get along well...
but hey it lasts till the warranty is up....
and they can't see it from their house...
heatman101
Jan 16, 2011 | Carrier 52CQ315 Air Conditioner
RHEEM 40 Gallon FVR NATGAS Low WATER HEATER 6YR 22V40SF: water leaking from top of water heater how can i f...
If water is leaking from a pipe. then replace or repair the pipe or fitting. If the leak is coming from the unit itself, then replace the unit. Hope this helps.
May 17, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Unit leaking water,
if your humidity is excessively high unit wont be able to cope,try it again after hi humidity lowers
Jul 27, 2009 | EdgeStar AP450Z Portable Air Conditioner
Water leaking into machine
it's possible, like mine with the same problem, that one or more of the plastic feet under the water tank has broken, then making the tank move and upsetting the valve underneath. My one always leaks clean water, never dirty and I have a broken foot.
Sep 29, 2007 | Saeco Primea Cappuccino Touch Plus Coffee...
Heating & Cooling Logo
55 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
