I have a Whirpool thintwin model LTE5243DQ2. The machine take a long time to load water and start the job. I never had been made any modification on the water line.
    Genius:
  • 1,073 Answers
Long fill time go to the water inlet valve first
Posted on May 05, 2008
Whirlpool Thin Twin model LTE5243DQ2 The washer will pump the water out but it wont spin unless i open the machine and rearrange the load. Then it spins but sounds like it's working very hard to do so
I'm not familiar with your model but on the surface it sounds like the belt is loose. If the load is not really well-balanced, a loose belt can't move the drum and when the load is balanced the motor turns really fast because the belt is slipping. Tightening or replacing the belt is fairly simple with normal tools and there are plenty of pages/videos out there on how to do it. Hope this helps! Good luck!
Apr 05, 2014 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool whitemagic pro 700h
The model no is Whirpool whitemagic pro 700H fully automatic top load
Dec 19, 2013 | Washing Machines
On the display there is blinking S and F and cycle stops and it's beeping. Once I use rinse cycle sometimes there is some water left inside the machine and it has to be spinned ome more time. Many...
Hello mi_wilk64,
If you still need assistance with this concern, please reach out to us, we have a local rep for you to speak with, here is our link: http://www.whirlpool.eu/
Thank you Whirlpool Social Media
Aug 01, 2017 | Whirlpool AWM9000 Front Load Washer
WHIRPOOL washer model LSR8010PQ0, WHEN LOADED WIT...
If large items in the machine create an imbalanced load the machine is designed to switch off...Towels are notorious for doing this because they hold so much water. Jeans don't soak up much water. Wash towels with towels alone and the problem should be reduced....Good luck....Nomess
May 16, 2010 | Washing Machines
Whirpool washing machine it won't spin after it drains water
Check if there looks like black powder under machine
This would be the coupling falling a part
It is worth fixing and not to hard
The part is under $10
Jun 06, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirpool Duet - Soap not getting into wash cycle
O.K. Is the water draining out properly? If the filter is blocked then your washing will be churning in dirty water as the machine will drain for a maximum time then rinse etc. in the used water.
May 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My top load whirpool washing machine leaks during spin cycle.
it only does it on the small load? does the water drain out before it goes into spin?
Nov 13, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
ThinTwin cabinet access
a little awkward atfirst but shlould be a problem. remove the angular panel along the rear of hte washer top youll see two brass clips an inch in on both sides, with a screwdrier "pop" these clips off, and if i remember correctly there are (2) 5/16 screws directly behind them (sorta on the frame of unit just below the rear lip of the top) the main top then will slide toawrd you and rigth off. a screw secures the front panel on both sides adn it too lifts up and off. acess to pump is right there. reverse order nad your good to go.hte brass clips will SNAP right back in place when lined up correctly
Mar 07, 2008 | Whirlpool LTE6234D Top Load Stacked...
Leaks water from the bottom
Your pump is probably leaking. It's mounted right at the front of the cabinet to the motor. It's held on by 2 clips and 2 clamps, very easy job. Part number for the pump is 3363394.
Oct 08, 2006 | Whirlpool Ultimate Care II GSW9650LW Top...
Washing Machines Logo
96 people viewed this question
Top Washing Machines Experts
