Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
My LG washer Tromm is always giving me the message ***LE*** and stop working and I don't know why... What is the problem and how can I solved it. Thank you for your help sorry my english is really bad I know...
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. LE' error message indicates the control board has detected that the motor is either not turning, or has locked up for some reason. Monitoring the motor is the job of the Hall Effect sensor board which constantly determines the direction and speed of the motor and feeds that information back to the control board. If there is a problem between what the motor should be doing and what the hall effect sensor says the motor is doing, the 'LE' will be displayed and the cycle will be stopped. The hall sensor is rather easy to replace, and is covered by a seven year part warranty (in US). It only takes around half hour to replace it with a new one. Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 26, 2010
I have an LG Tromm washer. I start it up it start
LE code stands for locked motor error. When this error code appears in your front load washer it indicates a fault in the motor unit.
1 . Check the connections to the Coil/Stator at the rear of the unit possibly it should be something like a broken wire.
2 . Coil/Stator Assembly will be defective preventing the drive to operate.You should go for a replacement of that assembly.
Thank you !!
Jul 25, 2010 | LG WM0642H Front Load
My washer say LG what dose that mean
My washer stopped and displayed the LE error code. I turned off the power button and tried again, but after a few seconds it want back to LE. Finally, I unplugged the power cord, plugged it back in, and the washer ran normally.
Dec 21, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG Tromm washer is not working with getting LE message.
LE code means locked motor error. you need to check the Hall Sensor. unplug the power, remove the rear washer panel, locate the Hall sensor connector on the stator behind the rotor. you can test it with an OHM meter for failure. it may just be an unstable connection.
Nov 07, 2009 | LG WM2688HWM TROMM SteamWasher
LE Tromm Washing Machine
i think you mean LG Tromm washing machine ... and the error code is LE ... thats a common failure with this machine .. often its cause by a defective " Hall effect sensor" this is used to detect the position of the wash basket ... if you are handy with tools then you can change it yourself at low cost ... but it does require removing a big bolt, the spin basket and several small bolts ... not difficult for a mechanic but probably more than aunt martha would want to tackle .. the URL listed below will give you good information on how to do that job ..
http://www.howtomendit.com/answers.php?id=28214
Aug 18, 2009 | LG WM2688HWM TROMM SteamWasher
LG Tromm has the error code LE what is it?
unplug the machine or turn power to outlet off. wait five minutes. turn all back on should solve problem
Mar 15, 2009 | LG WM-2277HW Front Load Washer
Washer stops in the spin cycle with message LE
LE means overload in motor it usually comes on because you have an unbalanced load
Feb 16, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My LG TROMM reads a blinking LE message
motor locked...not and easy fix but if you want to give it a go let me know...onthejob
Jan 25, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
I have a LG TROMM washer.It is not washing properly.
LE stands for overload in motor. Wait 30 minutes before restarting. If it happens again try again without a load.Good luck. Please rate me so I know how I'm doing. Thanks.
Dec 30, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
50 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
