Question about Mitsubishi Diamond WD-65831 65" Projection HDTV
I have a mitsubishi 68" hdtv projection tv. Just had a brief power outage and the tv won't power back up. The green (timer) light on the front control panel continually blinks. I tried the reset button (per instructions) and the green blinking light suspends temporarily, starst blinking again and never stops. Any suggestions?
mastersaintx
  • 928 Answers
SOURCE: Mitsubishi TV Model #ws65869 Blinking Green light
Sorry for the late reply I just got up.
From what I understand of your problem it is most likely a blown capacitor or main IC. Unless I can open up the unit and test the IC's and capacitors I can not be really sure which is why I hardly answer questions about TV''s as they are hard to troubleshoot without the unit in front of you. Ive found a site that can help you via a service manual since I could not find the exact service manual for you from my manual book. The site also has the parts that you will need if ever im right and it is the capacitor or IC. As for the IC's by experience is hard to test without an Oscope but you can do it by gradually eliminating the problem, again you will have to refer to the service manual regarding that. By the way the capacitors I mean is the one that goes to the main module as that is what powers the controls for the TV. the green light is just the "pilot light" which means you have power to the TV but the power is not going past the capacitors to the main controls or the main IC. So simply put the problem can be the capacitors (Which is what you check first) if they are ok then look at the IC via using a service manual. You can use a multitester for the capacitor first if they are dead then just change them and you should be ok. Let me know what happens or updates ill reply to them as well.
Posted on Sep 02, 2008
kevin000
  • 1847 Answers
SOURCE: the green light blinkig and does not stop, no picture
Did you try unpluge from the wall, and repluging back after 10 min.
Also run the self diagnosis by pushing the menu and device buttons on the front and let me know the code?
Thanks
K
Posted on Apr 23, 2009
Slinteriors
  • 8617 Answers
SOURCE: Mitsubishi TV green flashing timer light after power outage.
You will need to cahnge the capacitors on the DM board, very common problem. The V21 V19 DM repair kit at the following link contains the replacement capacitors and detailed instructions. Its listed under the repair kits catagory at the following link.
http://servicemanuals.vstore.ca/
Posted on Aug 29, 2009
SOURCE: Green blinking light on Mitsubishi WS-55813 HDTV
This link has the detailed procedure for the fix.
http://www.techlore.com/forum/thread/18565/Mitsubishi-WS-65711-HDTV-Green-Blinking-Light/
Posted on Dec 01, 2009
SOURCE: Green Light on Mitsubishi WD-62525 keeps blinking
Fluke solution: Press and hold Menu+Enter on front of TV...
WD-62525: My Green Blinking Fix!!!
http://www.avsforum.com/avs-vb/showthread.php?s=eb9ba9017a86fd9993de5feb77ee5f25&p=17646001#post17646001
Posted on Feb 09, 2010
Green light flashing won't turn on
Likely has bad 1000UF capacitors on DM module. this will prevent rebooting.
Apr 08, 2014 | Mitsubishi WS-65611 65" Rear Projection...
Yesterday we had a power outage. When the power came back on, my TV would not work. The green light on the front just keeps flashing quickly. I tried unplugging it, and I unhooked all devices from it as...
Thats caused by weak capacitors on the DM board. They drain when the power is lost then they cant recharge after power is restired. You can get the dm repair kit for your model at www.tvrepairworld.com it contains the repair instructions and the upgraded caps plus other service info on the cd
Jun 07, 2011 | Mitsubishi Televison & Video
I have a Mitsubishi WD-52725 DLP TV and green light (timer) is rapidly blinking after a power outage and set will not turn on. The bulb was replaced a month ago and it has worked fine since. Now it will...
Hello
make a System Reset process. To do this;
If the TV will not respond to either the remote control or the front panel controls and/or will not power Off, press the SYSTEM RESET button with a pointed item like the end point of a paperclip. The TV will turn Off and the TIMER light will flash quickly for about one minute. When the TIMER light stops flashing, you may again turn on the TV. The changes you made the last time the TV was on before you used the SYSTEM RESET button may be lost, however, the changes that were previously saved are not lost.
OK.
Apr 23, 2011 | Mitsubishi WD-52725 52". Rear Projection...
I have a Mitsubishi WS-55909 projection TV. There was a power outage and when the power came back on, the TV won.t turn back on again. There is this light (Timer) that keeps on blinking on the front panel...
Unplug,replug the tv back like 24 hrs later.That the whole tv is resetting itself everythings.Tv now should be working again.If still have the same problems,than ur tv DM power supply board is have dying parts,must repair the tv DM power supply board to fix the tv.
Mar 21, 2011 | Mitsubishi Televison & Video
MY GREEN TIMER LIGHT WILL NOT STOP BLINKING
The manual indicates that this can be caused from recovery after a power outage, although it doesn't indicate thow long this lasts.
I recommend two courses of action:
Disconnect the television from power and let it sit overnight before plugging it back in.
If this doesn't work, reset your TV according to the instructions in your manual.
Oct 24, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Aug 29, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Lamp light flashing green continually after power outage. have hit reset button, unplugged tv, nothing works
the timer light will continually flash green.on the dm pcb and fmt pcb you have 4 capacitors
that pooch out.replace the 4 capacitors on both boards.will require a tv professional to do
this.
Jul 18, 2009 | Mitsubishi WD-62725 62" Rear Projection...
The green light blinkig and does not stop, no picture
Thanks
K
Apr 23, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Blinking Timer light on Mitsubishi WD62725
get a ohm meter and check all fuses ,and diodes they should all read 0. the ones do read something are bad replace them that means solder them out and back in
Mar 13, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi WD-52525 52 in DLP.
You most likely need the V26 DM repair kit at the following link, that usually repairs the blinking led problem.
Nov 24, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi Diamond WD-65831 65" Projection HDTV Logo
109 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
