Question about Siemens Gigaset 8825 Cordless Phone
The phone rings on my Siemans 8825 phone set (I have the base set and 3 remotes), but you can't pick it up. It begins to alternate the ring and the beeping sound until the caller hangs up. But it does work correctly intermittently about 50% of the time. I have unplugged each remote, but the issues remains occuring at the base sent.
  • 944 Answers
This is a normal bug which is present in 8825 model.The phone settings is corrupted,
You have to restore the phone to factory settings and set the settings whatever you like to.
Restore steps at base station:
1)Press menu.
2)Scroll to "system settings?" and press select
3)Enter the system PIN and press Select(Hope you remember the PIN)
4)Scroll to "RESET SYSTEM DEFAULTS?" and press select
5)At the promt "Are you sure" press select .the displa shows "settings reset to default" and you will hear a confirmation beep
Restore steps at Handset Defaults:
1)Press menu
2)Scroll to "Mobile settings" and press OK
3)Scroll to "Local settings" and press ok
4)Scroll to "Factory default" and press ok
5)Enter the handset PIN and press ok.The display shows "setting reset to default"and
you will hear the confirmation beep.
If you don't have the manuals click here
to download it and use it to set the ringing and tone set up.
If you forgot the Pin code you can use default pin:
Complete the following steps to reset the PIN on the 8825 back to 0000.
1. Press MENU.
2. Scroll to System Settings but do not press SELECT.
3. On the keypad, enter *65# (Star, 6, 5, Pound).
4. It will display "System PIN Reset" and return to the idle screen.
post a comment for further assistance.
thank you for using fixya have a nice day:-)
Posted on Aug 26, 2010
# of rings
The place to set rings to answer is # 506 (VMS hunt delay)selecting either 1 for the day schule or 2 for the night schedule. You'll also want to check #507 (VMS hunt schedule) to make sure your line is in the correct schedule and not following the alternate schedule.
May 12, 2010 | Lucent PARTNER18 Corded Phone
Can you please tell me how to shorten the amount
Got it, and you can set it for 2, 4, or 6 rings on incoming calls.
1. Press MENU/CLOCK on the base to enter setup.
2. Press MENU/CLOCK repeatedly to select RING TIME.
3. Press VOL:/SELECT to set the number or rings at 2, 4, or 6.
4. Press SET to save the setting.
You can download and print the operating manual for youir phone system at
http://www.uniden.com/pdf/DXAI8580-2om.pdf
Dec 11, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
I have a gigaset 8825. I have a "distinctive ring" problem
I have the same phone system, and *think* you may be able to fix the problem by adjusting the amount of rings before answer on each unit. This assumes there is an auto answer system engaged. Hope that helps some.
Ken Lundberg
Jun 19, 2009 | Siemens Gigaset 8825 Cordless Phone
Phone won't ring with incoming calls
I just bought a new Uniden DECT 6.0 phone and had a similar problem. It wouldn't ring when plugged into my Linksys voip router, but my old 5.8 GHz did ring. It would get a dialtone and make calls, but when called via an outside line, it would appear as if it was ringing. If I picked up during this "silent ring," it would answer and take the call. It wasn't a ringer volume issue. I called tech support, they said on the main headset, unplug the battery, then unplug power from the base, then unplug the phone cord from the base. Wait 15-30s. Plug the phone cord, then power, then reinstall the battery. Press the End button on the phone. Put the phone on the base for 15-30s. Pick up the phone. Press and hold the Find button on the base. Do this Find thing 3 times. Put the phone back on the base. Wait 10-15 minutes. Then try calling it to see if it rings. Worked for me, finally got it to ring before I decided to return it.
Jun 02, 2009 | Lands Phones
Gigaset 8825 message system won't work
guys- empty out your call log and your mailbox. This timeout and reset isssue seems related to memory- that should do it-
Chris
Mar 06, 2009 | Siemens Gigaset 8825 Cordless Phone
Siemans Gigaset 8825 BaseStation
Is the line blocked in settings at the base? This would be the only solution I can think of - hope it helps!
Dec 01, 2008 | Siemens Gigaset 8825 Cordless Phone
FAX JX500
Mary:
Given that the last question I responded to for you related to a Fax JX200 - and this to a JX500 - I am not certain which model you are actually asking about. The information that follows relates to the JX500. Further, if you need information in this regard on the prior post in order to feel that the previous response was a FixYa level response, please let me know. I responded based on the information you provided...
Based on the fact that you are getting a constant 5-ring situation, it appears that the machine is in TAM (tel-ans mach) mode. The purpose of 5 falls into remote recovery of messages - toll saver results in the phone answering after 2 rings if there are messages to retrieve, and 5 if there are not. This is done to prevent long-distance charges if there are no messages.
Two ways to accomplish an 8-9 ring objective. (1) Place the machine in manual mode, which means answering every call and sending faxes to the machine. Additionally, a "fail-safe" on this mode is that it will switch to TAM/automatically answer (if there is a recorded greeting message) after 15 rings - below. (2) The incoming ring - ring count - can be set (under Fax/Tel Auto) to ring 10 to 60 seconds before the fax picks up. (3) Alternatively, the Incoming Ring ring count can be set to have the fax ring 2 to 30 times, depending on the country specific parameters.
Re TAM: When the fax is set to <MANUAL MODE> and <MAN/AUTO SWITCH> has been set to <OFF>, TAM MODE will be activated if the fax rings 15 times and the call is not answered (only when an outgoing message has been recorded). When the call is disconnected, the fax returns to <MANUAL MODE>.
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding your specific needs, and I will gladly help you until we have reached a definitive solution. Thank you for using and rating FixYa!
Aug 04, 2008 | Canon FAX-JX200
Ringer settings on 8825 base unit
You can adjust the volume and pitch of the ringing by pushing Menu, scroll forward to Desk Station Settings, push Select, scroll to Ringer Volume and you can adjust the ringer volume, and in that same area adjust the pitch. So you might want to make line 2 ring lower, and with a different pitch so it is not distracting, but still notifies you of an incoming call that is not line 1. The same goes for the handset.
Apr 18, 2008 | Siemens Gigaset 8825 Cordless Phone
Siemens 825 Gigaset
I have the same problem with mine - a Siemens 2420 base. The calls come in, all the lights flash, then the thing clicks and resets. At this point, it can only be used for outgoing calls. i think i'm going to retire it. Too bad, cause the speakerphone was one of the best ever.
Nov 28, 2007 | Siemens Gigaset 8825 Cordless Phone
Siemens Gigaset 8825 Cordless Phone Logo
232 people viewed this question
Top Siemens Lands Phones Experts
Greg Cann
Greg Cann
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
