Question about Texas Instruments TI-86 Calculator
My calculator has randomly stopped operating. i put in new batteries and there is nothing turning on. is there any way to get it repaired? as you know its pretty expensive and don't want to buy a whole new one
  • kakima Aug 30, 2010
    Before sending it in for repairs, try this.
    TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
    Does this do anything?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
Having gone a month without a reply to my query, I assume the suggested contrast change fixed the problem.
Posted on Oct 01, 2010
TI-92 intermittently turning off
Yes it does sound like you have a bad solder joint somewhere. A Tv repair shop should be able to help you out. These are fairly expensive so a repair maybe worth the $. I only recommend a repair if the cost is less then half the price of replacement.
Jan 24, 2014 | Texas Instruments Office Equipment &...
My TI-83 PLUS wont turn on
Remove one battery from the calculator and then press and hold down the CLEAR key while re-installing the battery. While continuing to hold down the CLEAR key, press and hold down the ON key. If this doesn't work, then hold DEL and then ON. If unsuccessful, remove all the batteries, including the lithium watch battery, and leave the calculator like that for a while.
This is documented in the TI-83 Plus Guidebook, but unfortunately, not many people know about it.
If that doesn't work, send it to TI for repair. They probably won't even charge you!
Mar 20, 2017 | Texas Instruments TI-83 Plus Calculator
My screen turns on but when you do anything it has random numbers, line and letters on it and i need to get it fixed immediatley
I've had this issue before with my TI-83 Plus. I'm not sure exactly the solution I used, but these steps progress through the mildest to most extreme methods of fixing the calculator.
Solution 1: Take the batteries out.
Odds are you've tried this already, but it bears mentioning.
With the calculator on, remove the triple A batteries housed in the back. After a few seconds, replace them and turn the calculator on.
Solution 2: Clear the RAM.
Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR], reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message.
Solution 3: Reinstall the operating system
Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now"
Here is the website to reinstall your OS. First you'll need the TI-Connect software.
Solution 4: Remove all sources of power. This is a risky move, but if your calculator will absolutely not work after you try even reinstalling the operating system, it might be your last hope.
Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
May 12, 2011 | Texas Instruments TI-83 Plus Calculator
My ti 83 will turn on when i press the clear thing but when i try to put something in nothing happens
Hi imagenius1,
You need to free up some memory. Try clearing your RAM memory. Your calculator should operate properly afterward.
Press [2nd] [MEM] [7] [1] [2]
If the steps above did not reset the memory to your Ti 83 family calculator try the procedures below.
Please be prepared to re-install the calculator's OS if you run through this process.
If you have a straight Ti 83 without the Plus or, Silver Edition label goto (Procedure 2) below. If your Ti calculator is a Ti 83 Plus or better goto (Procedure 1).
(Procedure 1).
  1. Try a new set of AAA batteries.
  2. Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR], reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the [CLEAR] key and, then press [CLEAR] one more time to remove the message.
  1. Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system.
  2. Steps to re-installing the operating system:
    ~Connect the TI Connectivity cable between the PC and the calculator.
    ~Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader
    ~Follow the on-screen directions to reinstall the calculator's OS. If you could not install the new OS on your calculator goto step 4.
  3. Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
  4. If the above process did not reset your calculator. Try re-doing (Procedure 1) and, extend the time in step 4, by 5 minutes to 10 minutes before you put all the batteries back in the calculator.
(Procedure 2).
For a straight Ti 83 without the Plus or, Silver Edition label try the procedure below.
  2. Remove one of the AAA batteries. Press and hold the [ON] key for 20 seconds. Reinsert the AAA battery and then turn the calculator on.
Jan 06, 2011 | Texas Instruments TI-83 Plus Calculator
My ti-83 stopped working after i used rechargeable battteries. Now i realized I'm not suppose to use them. Now whenever i turn the calculator on, i can't turn it off. I will try to press letters or numbers...
I'm thinking the calculator itself froze (stalled), or the circuit board is taking a long time to process the your command (telling the calculator to turn off). Maybe you should wait a few hours or so and see if it's still on. Did you perhaps take the batteries out while the calculator was still on? You may have damage the circuits inside of the calculator by taking the batteries out while the calculator itself was still on. Maybe if you put some new batteries in the battery compartment and press the "ON" button, it might function properly. This is a suggestion and I hope this works.
Oct 08, 2010 | Texas Instruments TI-83 Plus Calculator
My TI-81 has completely stopped working. I have put in new AAA batteries along with a new CR1620 battery. Any suggestions?
If this doesn't do it, please append a comment to this post and we'll go on from there.
Sep 07, 2010 | Texas Instruments TI-81 Calculator
I put new lithium triple aaa batteries in my TI-83. Nothing happened . days later it turned on worked for a little while then stopped. would it help to change the round lithium battery? Do you know what...
The button cell backup battery keeps the memory electrically refreshed when the calculator is turned OFF. The necessary power for regular use is supplied by the 4 AAA batteries (main power). That nothing happened when you put in a fresh set of (expensive) lithium batteries may be due to the screen being too dim to see anything.
If the calculator displays RAM CLEARED each time it is turned on, it may be due to a depleted backup battery. The battery model number is CR1616 or CR1620. On my TI84PLUS the backup battery is of type 303 (Sony) or SR44SW (Maxell).
Sep 05, 2010 | Texas Instruments TI-83 Plus Calculator
When I turn on the calculator, I get a screen full of random black pixels. The AAA's and the lithium batteries are both good. Nothing I do will change the screen, except turning the calculator off.
Try to reboot your calculator to see if it helps by doing this:
*Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR], reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message. *
Let me know if it helps or not.
Aug 19, 2010 | Texas Instruments TI-83 Plus Calculator
Ti 84 Silver Plus won't turn on
ti-plus doesn't turn on at all put new batteries in nothing and it is only a year old when I bought it
Sep 10, 2009 | Texas Instruments TI-84 Plus Silver...
My TI-84 Plus always turns off randomly
Try resetting the calculator to what I will call the "factory settings", do so by holding the "CLEAR" button, and while holding it, take out the batteries, then put them in
Apr 18, 2008 | Texas Instruments TI-84 Plus Calculator
Texas Instruments TI-86 Calculator Logo
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
