Question about RCA F36648 36" TV
RCA F36648 36' TV will not power on, makes a clicking sound when I try to power on
  • 4,234 Answers
This set has a number of problem detection circuits and safety shutoffs. The clinking you are heearing is the power relay turning on then off as a problem is detected and hte set shuts down. This is normal expected behavior when the set has a problem. The most common cause of this is a defective horizontal output transistor that has failed. Expect a parts cost in the $30 range for this repair.
Dan
Posted on Aug 27, 2010
  • 70 Answers
The standby power is working so relay is making click sound but main power is not working pls check power out put 140V available or not frm the power supply
RCA 36695BC wont turn on
Can you please provide the chassis number of this TV?
Jul 24, 2008 | RCA F36695BC 36" TV
I'm afraid this failure is not just a fuse failure in your TV since you still can hear the relay clicking. This fix might not be a DIY.
Where can I send you additional info on what could be wrong with your TV?
RCA Projection TV
that would be the inverter board, supplies power to the bulb, you would need to replace this part, but don't touch the board without wearing rubber gloves, as it can store a lot of voltage when they fail . when you get the board out discharge the capacitors to make it safe. cross the live and negative on the capacitors.
Jul 08, 2017 | RCA Televison & Video
LG 47" LCD TV - 47LC7DF Clicking Noise
I was told that these clicking noises (which happen on my Magnavox LCD too) were due to the "power required" at the internal switch. Seems that the power required to immediately turn on the TV is too much for a standalone household outlet, so it "surges" power in a series to get enough there. Hence, the clicking sounds are actually mini power surges to send more power to the internal circuits to turn the TV on.
If your set is like mine, these noises generally stop after a minute or two, correct?
Dec 13, 2007 | LG 47LC7DF 47 in. LCD HDTV
TV WON'T COME ON
All the reports are showing the same problem the TV is in shutdown mode.
Something is wrong and it is refusing to start it makes a chirping or clicking sound. Solution is that it needs to be repaired nothing you can do unless you want to try replacing the motherboard yourself.
Dec 05, 2007 | RCA 24V511T 24" TV
RCA tv makes licking noise when it turns on.
It sounds like you have an arcing solder connection somewhere in the power input to your TV. This is a loose connection somewhere. You might confirm this by jarring the set while it in operation. (Not too hard) If the problem shows up then a loose connection is confirmed. Also a component may be breaking down internally. You need to have a tech check it for you. Stargazer
Mar 14, 2007 | RCA 32V420T 32" TV
Rca p46771at won't come on post lighting.
Have you tryed to unplug for a while and plugging back in again.. Ff that dosent work, something most likly in the power suppply blew out from a power surge.. if your not a tech or have TV experience it would be best to leave this to a pro. Too much Hi Voltage inside these sets to fool around with and do any experimenting! good luck
Jul 25, 2006 | RCA P46924 46" Rear Projection Television
Have you tryed to unplug for a whiloe and plugging back in again.. if tha6t dosent work, something most likly in the power suppply blew out from a power surge.. if your not a tech or have TV experience it would be best to leave this to a pro. Too much Hi Voltage inside these sets to fool around with and do any experimenting! good luck
RCA F36648 36" TV Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
