Question about Bose Lifestyle V20 System - black Theater System
I have a Bose LIfestyle V20. The system worked fine for a week, but now when I press either the AUX or VCR keys, the sound plays for a second then stops. The sound plays fine from the expansion speakers outside.
  • 1 more comment
  • vsciascia Aug 26, 2010
    TV and DVD work fine. On the VCR and AUX modes, the sound plays for a second and goes off. Every time I switch between VCR and AUX the sound plays for a second.
    I have a Bose Lifestyle v20 system. The sound for the Cable and DVD are working fine, but the sound for the AUX and VCR only plays for a second then stops. When I switch between modes the sound plays for a second again. When I plugged the VCR and AUX devices into the TV outlet, the sound was fine. All speakers seem to be working properly. Is this a setup problem?
    Thanks for the help. After resetting the unit, it works fine, but now the Bose SA-2 amp for the outside speakers does not work at all. The green light on the back of the amp does not even come on.
  • 2,272 Answers
Did you changed any setting in trying reset.If not then unplug all the external connections and reconnect all the connections back and recheck.But if you have changed any setting then re-set it once again to the previous settings and then check out. Thanks.
Posted on Aug 26, 2010
  • 3,083 Answers
If the unit's still in warranty, have it replaced, first of all. It could be that your cpu needs resetting (unplug the unit for a few minutes). I've seen reports where the microprocessor can hang, and have to be reset. It sounds like a component is breaking down, and that will take some serious troubleshooting.
Not sure what AUX is hooked up to, or if there could have been an impedence mismatch that affected the unit.
Couldn't find a similar problem on the net, which means it's probably going to be tricky. Try unplugging the unit, unless you already have, and get a replacement, if you can. Here is Bose support:
http://www.bose.com/controller?event=VIEW_STATIC_PAGE_EVENT&url=/customer_service/owners/index.jsp
Good luck, thanks for using FixYa, and hope this helps.
    President:
  • 1,961 Answers
Check the your speaker there might be a problem on it such as the polarity of the speaker wirings make sure that the positive is conected to the positive termnal of the reciever next check the speaker cone this should be vibrating freely and not partially shorted..
  • Danilo Baraquiel
    Danilo Baraquiel Aug 26, 2010
    well then that is a mainboard issue the switching IC is
  • Danilo Baraquiel
    IC is not functioning well it would be better to bring your unit to a qualified service personel..
Bose lifestyle v20
Make sure the HDMI device (TV, Blueray player) is set up for audio output. Usually HDMI 1 is the only connection that has audio out. Also some TVa have to be configured for HDMI audio out.
Dec 07, 2013 | Audio Players & Recorders
Tip
Bose LifeStyle V20 Manual Download
Download Bose LifeStyle V20 Audio System Manual
Would you like to review the features of the Bose LifeStyle V20 Audio System?
Have you lost your Bose LifeStyle V20 Audio System Owners Manual?
Would you like a digital, searchable, pdf version of the Bose LifeStyle V20 Audio System Users Guide?
Follow this link (& click FREE) to download a pdf version of the Bose LifeStyle V20 Audio System documentation.
I hope that helps.
___________________________________________
on Jul 03, 2010 | Audio Players & Recorders
Tip
I hope that helps.
on Jul 03, 2010 | Bose Lifestyle V20 System - black Theater...
I have a Bose Lifestyle v20 home theater system and whenever I use the radio ( FM/AM ), no sound/music comes out. The rest are fine, but only the FM/AM ones dont work. It used to, but now its gone.
I hope you checked if the antenna wire is connected before reporting this defect.
All modern radios have automatic muting. No sound will come out unless the receiver gets enough signal strength to give you an undistorted sound, so if your antenna wire is disconnected you will get no sound.
Jun 15, 2011 | Bose Lifestyle V20 System - black Theater...
How can I add more base to the sound of my Bose v20 when playing cd's?
use a dedicated subwoofer unit rated at 500W rms, this should be enough to shake the house ;-)
Feb 03, 2011 | Bose Lifestyle V20 System - black Theater...
Tip
I hope that helps.
on Jul 03, 2010 | Bose Lifestyle V20 System - White Theater...
The remote for Bose lifestyle V20 system does not work with Apple TV. I have component video coming out of the Apple TV into the Bose V20 system and then HDMI from the Bose V20 to a Sony Bravia HDTV. I...
I had the same problem, and called Bose tech support. They put me on track to the solution. The code you need is under AUX, Music Player, Apple where you probably looked already. The secret is that you need to "unpair" the apple remote first. If I remeber right, in apple TV you go to settings, general, remotes and unpair your remote. It still works, but is no longer the only remote that works.
Gerry
May 01, 2009 | Bose Lifestyle 20 System
System Info from Bose not displayed on Samsung TV
Unplug the power cord and plug it rght back in, I had this same problem and was troubleshooting forever.
Jul 19, 2008 | Bose Lifestyle V20 System - black Theater...
Sound problems
Power down the media center for 20 seconds then power it back up. This will clear the problem.
Dec 23, 2007 | Bose Lifestyle 38 System
Bose Lifestyle V20 System - black Theater System Logo
125 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
