Question about Refrigerators
Freezer drain line freezes up Ice builds up in freezer THIS HAPPENS ABOUT EVERY 6 WEEKS model # ET1CHMXKQ
  • Anonymous Mar 23, 2014
    Freezer section builds up with ice
    President:
  • 2,712 Answers
Check to see that the thermostat setting are correct. If the freezer temperature is too low and the fridge section is kept high, then the cold air from the freezer does not circulate properly causing the ice build up in the freezer. The freezer compartment is where all the cold air in the fridge is created, and its blown from here to the other compartment by the evaporator fan. Ideally, the freezer should be about 10F and the fridge should be 35F. Remember that any changes in the thermostat controls takes upto 24 hours to take effect.
If you find that the freezer drain is freezing, you can try adding some salt to try to melt the ice. Or carefully poke through it using a chop stick or thin blade screwdriver. Be careful not to damage the tube. You can then flush this out with hot water.
You can even install a defrost drain strap kit to prevent drain freeze ups...In any case, I'd recommend that you get a profession to asses and diagnose the problem.
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 05, 2008
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    This thread has gone 14 days or more without a response.
    Please close the thread with a “FixYa” or “Helpful” rating.
    Or post back with latest developments, what steps you took,
    etc. and I will assist you further as best I can.
    Thank you.
    IrishDruid
    Genius:
  • 1,073 Answers
If the machine is less than 1 yer old call whirlpool and let them know about the issue, it has a restricted drain tube, it can not be repaired and will have to be replaced, there are some drain tube heater kits ou there but i can not recomend one since it is an aftermarket part and all i can do is use the factory parts
Leaking water on floor
Remove contents from bottom of freezer. Turn ref/freezer off. Use the handle end of a screwdriver and carefully break up the ice build up from the bottom of the freezer. Find the condensate drain and remove ice build up. Find the condensate drain and remove ice or any kind of restriction from the drain line.
Or you can turn the refrigerator off for a day , mop up the water and blow out the condensate drain
Jan 18, 2016 | Maytag Refrigerators
Ice build up in the bottom of the refrigerator.
some drain line is plugged . our Amana does the same thing and we use a hammer to break the ice out weekly
Mar 12, 2015 | Frigidaire Refrigerators
Why is water in bottom of freezer
there are 3 problems I've come across with water leaks on this model. if there is ice build up on the back of the freeze it could be a drain problem or if its around the ice maker it could be that the supply tube is too long. also watch out if you push the unit too far back against the wall the gray water supply line could snap off ( replaced 6 of these)
Jul 31, 2014 | Whirlpool Freezers
My LG 693 LTR fridge freezer model no P247STSL is freezing the food in the fridge and building up ice in the fridge on the left side of the drawers on the wall on the side of the freezer, sometimes the fan...
The reason why fan is making loud noise is because of the ice built up on the coil because of freezing.
You can check your drain line to see if it's clogged and clean it out .
There are several video on you tube showing you how to clean drain line.
Hope this help
Jun 02, 2017 | GE PSS25SGN Side by Side Refrigerator
I have a Roper Frost Free top freezer model Model@RT16DKXXW06 Serial#EB2423742 Type#16ATR92 Mfg 06/92 the pats 6-8 weeks it has been leaking water on the floor I assume from the defrost cycle. What can I...
yes the drain is in the rear of the freezer ..you will need to remove the covers on the bottom and the back to see the drain..remove all the ice buildup on the bottom ..then use hot water to thaw drain...the reason for the line freezing up is freezer is set to cold freezing leftover water from defrost..let me know good luck/joe/
Aug 27, 2010 | Roper Refrigerators
Every few weeks the ice in my freezer melts. It
You will need to remove the bottom freezer crisper and check the defrost drain , to see if it is iced over . If so , then use a hairdryer to melt the ice ( hot water also helps ) . When you see the drain , ( could be obvious obstruction from plastic ) , use a small hose inserted into the hole , to blow thru , to remove any unseen debris blockage .
You may have to remove the rear inside freezer panel to access this drain , depending on your model number . So make sure the drainhole is open. When it happened to mine this was the problem.
Oct 24, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Hotpoint FFS70S fridge drain pipe blocks with FROST in a few days after clearing. I suspect that the drian pipe is too close to the freezer compartment. Is this a common problem. More to the point, is...
I have the same problem. Engineer said most likely problem with insulation and since pipe is moulded onto the back, it cannot be fixed easily. Defrosting is a temporary solution only. Luckily I kept extended warranty going, they are going to replace it with a new one.
May 17, 2009 | Hotpoint FFS70 Bottom Freezer Refrigerator
Freezer coil and back of freezer full of ice, never defrosting
Low on freon or the blower fan has stopped
Apr 11, 2009 | Refrigerators
GE Profile TCC18 Refridgerator freezes Up regularly.
I had the same problem. I changed the defrost thermostat and that has solved the problem. Just to make sure the problem is not recurring I drilled a small hole in the back of the plastic drain(behind the fridge) so that I can put a long screw driver inside to determine if there is any ice build up. None so far after 3 weeks.
Feb 28, 2009 | GE GBS22HCP Bottom Freezer Refrigerator
Refrigerators Logo
1,795 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
