I need help connecting a second computer to a Intellinet 5-port fast ethernet office switch. I have one computer up and running by setting up a new connection, how do i connect a second or third computer Please help, i am stumped. OS-Windows 7
    President:
  • 1,768 Answers
1.Log into router. Using either 192.168.0.1 ot 192.168.1.1 in a browser window that is ( internet Explorer or firefox)
2. Verify wireless router name( on the computer) >>> ( on/off) ( router status window)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address. This set up in the "security tab" in the router. using 192.168.0.1 or 192.168.1.1 to access through a browser.
6.Note router name you are connecting to.
7. try to log on to the internet.
This is for all routers to set up wirelessly.
Posted on Aug 26, 2010
INTELLINET+523301+power+light+is+yellow
Try the connection directly to your pc.
If works possible solutions are :
1-The device is fry
2-Update the firmware
3-call your ISP
Feb 04, 2014 | Intellinet Network Solutions Intellinet...
Cisco SD208P switch is slowing connections...please help!!
Try new CAT 5/6 cable or limited bandwidth. Plus NIC's respond differently withing Speed and Duplex settings. Test between auto and 100 full, and 10 full negotiation on PC. Network Connections > Right click > Properties > Configure > Advance > Speed & Duplex > Value. Might also be bottle necking as 10Mbs instead of taking advantage of of higher through puts.
Aug 09, 2012 | Cisco (SD208P) 8-Port Ethernet Switch
FS605 V2 5-port Fast Ethernet Switch 10/100 Mbps setup
Try repairing second by right clicking on network icon. Make sure drivers are ok in Device Manager. To verify IP's on machines use ipconfig /all from the command prompt. Get there from Start > Run > type cmd.
Aug 04, 2012 | NetGear Computers & Internet
I am trying to set up a switch between my PS3 and my PC. I have an external DSL modem. I purchased a 5 port switch(Rosewill RC405-x) but no luck. Can I use an ethernet splitter instead?
You did not explainhaow you connected all your equipment together.
Connect your PC and PS3 into the 5 port switch.
Connect your DSL modem into the 5 port switch, if there is a WAN/internet port on the 5 port switch then connect the DSL model into this port.
You may need to power off the 5 port switch wait a 1 min and power up the 5 port switch again so it can setup an IP address table for the connected ports.
If this still does not work the replace the 5 port switch with a normal 5 port hub.
Mar 20, 2012 | Rosewill RC-405 - Switch - 5 ports -...
Am asking for the default ip address for the router
You will get the default IP address for the router by following the instructions below.
1. Go to command prompt.
2. Type ipconfig and hit enter.
3. The address mentioned next to Default gateway is your Router IP address.
Note: Make sure that the router is connected to the computer using the Ethernet cable.
Nov 16, 2010 | Intellinet Active Networking Intellinet...
What wires go into the back of the Dynex 5 Port 10/100 Fast Ethernet Switch?
A switch is a device for networking computers printers or other devices with an ethernet port. Most common scenario would be to hook a cat5 cable from your broadband router's lan port to Port 1 and then connect your other ethernet devices to the remaining ports. In order for the devices to cmmunicate you'll want to make sure that they are on the same ip subnet. Usually, 192.168.1.x.
Your router may be 192.168.1.1, your PC 192.168.1.100 Printer 192.168.1.101. Each device needs a unique IP address.
Hope that helps.
Oct 21, 2010 | Dynex 5 Port 10/100 Ethernet Switch...
How can i connect the router? i got a intellinet 192.168.1.1 there is one wan and 4 ports are there.i have dialog broad band connection.how can i connect it?or iwant to install any software?
This is very easy to do and you should have no problems doing this. The first step to installing it connecting your router to your broad band router through the wan port. All you do it take your Ethernet cable that went from your broad band router to your computer and attach it to your new routers WAN port. next wile your new router is turned off, turn off your broad band router and then turn it back on wile it is booting up turn on your new router this is not always necessary but it will make sure that they sink together properly. And that's it your done just hook up all of your other computers to the remaining ports and they should work with out a problem.
PS. this is just the basics of setting up your router if it has wireless you may want to think about implementing some security measures such as encryption.
I hope this helped.
Thank you,
Norse
May 18, 2010 | Intellinet Active Networking Intellinet...
Bought a wireless router-intellinet 150n4-port router. i had cable internet hooked by modem to my desk top. i dont have a clue how to set this up. wanted the wireless for the wii game up stairs. hooking it...
http://www.intellinet-network.com/en-US
link above for manual find exact model 7 number & download, read up.
You hook up with an Ethernet cable, you type in the "Address" of the router, in manual, login, using default name and password, in manual, once logged in toy can then run the "Wizard" this will help you connect. You need to know your Internet Account login and password. Once all setup you save and now you can use it. it is all explained in the manual. It is a few pages so it was not possible to post here.
Mar 26, 2010 | Intellinet Active Networking Intellinet...
New topic about Intellinet Active...
You have a switch which is like a hub. You want a router, the router will assign IP addresses to each computer in your home. If you need to set up port forwarding then you do that within the router settings. For the most part newer routers have Universal plug and play which will handle the port forwarding for you.
May 31, 2008 | Intellinet Active Networking Intellinet...
Configure with utorrent
1.) To set up a static Ip address on your computer, click start, control panel, network and internet connections, network connections, right-click on local area network, click properties. In the window select tcp/ip, then click on the properties button.
Since your default gateway address is 192.168.2.1. Click on the selection titled 'Use the following ip address' Your Ip address should be 192.168.2.2, subnet mask 255.255.255.0, default gateway 192.168.2.1. Then in the next section click on the selection titled 'Use the following DNS server addresses' Preferred DNS would be 192.168.2.100 and alternate would be 192.168.2.200. click ok and you are done.
2.) As for the second problem, refer to the following link from the intellinet website. http://portforward.com/help/pfprogression.htm
Mar 05, 2008 | Intellinet Active Networking Intellinet...
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
