Question about Acer AC713 17" CRT Monitor
When i turn my laptop on, i always get a white screen. i just need to know how i can fix it myself because the warranty has expire and i need to know what i can do to fix it myself.
    New Friend:
  • 76 Answers
Go on craigslist and buy a cheap flat panel for like 20 bucks and save yourself the headache
Posted on Aug 26, 2010
When I turn on my Dell XPS M1530 laptop, it shows a white screen that then fades slowly to gray and blue, instead of showing the bios. An external monitor shows the same. Anyone has had this issue and...
It seems you're having issues with the internal video card or motherboard.If you're not able to boot to bios it means your laptop didn't pass the POST (Power On Self Test). tried running the dell diagnostics.
here are the steps:
1. turn off the laptop.
2. while the laptop is off, press and hold down the FN key then press the power button. The dell diagnostics should come up. If nothing happens, you should call Dell to check more options.
Good luck,
Ryan
May 23, 2011 | Dell Computers & Internet
I have a Eee PC 1005 with Windows 7, when i put it on, i can only open the screen up to a certain height before the screen goes white and blank, if i close it slightly then the wriing comes back again. ...
Ann Marie, I'm almost certain your problem is a short in your video connection. This happens in all types of laptops, including the minis, since the tiny cable carrying your video signal from your screen to the board inside your computer actually runs through a plastic / metal channel inside one of the hinges (usually the left). A new cable should cost less than $20 on eBay, so see if your warranty covers this issue--if your warranty provider does not cover 'accidental', as many don't, remember to tell them this is a common issue, as I've said. I've repaired many of these myself--the cable is shielded, but still given to bending and eventual shorting, causing your problem. Mike Denney The PC Doctor hope this helps, glad your warranty is still in place!
Apr 15, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Bottom Half of Laptop Screen quickly fades to white!
1. you can replace it with a new screen. (expensive) 2. have a technician to repair the board of the screen, the cable, the IC's, etc. (save you money but the length of repair is very long. maybe it will take a week or two.)
your choice.
May 24, 2010 | Dell Studio 1737 Laptop
Screen is always white. Will record picture, but plain white also
The image sensor (CCD) is dead. This is a known manufacturing problem and may be repaired at no charge, even though the warranty has expired. Here's a link to a detailed explanation; http://www.imaging-resource.com/badccds.html
Aug 08, 2009 | Canon PowerShot Pro1 Digital Camera
Right half of screen is Black with a White vertical stripe
Yeah, I have this exact same problem, except my mom slammed my laptop shut in frustration around half an hour ago, so that's why it's like this. The right half of my screen is black with two colorful stripes (mostly white), but the left half is visible. I've researched a bit and found out that this is because the LCD in your monitor has burnt out, and since you don't have a monitor to attach, the only thing you can do is to go to where you bought the laptop and either get it fixed for free or return it for a brand new one (if your warranty still stands). If not, you might as well get a new laptop. I think my warranty has expired, so I'll get a new laptop, hopefully.
Hope this helps!
~Sam.
Jun 08, 2009 | HP Compaq FP 7317 17" Flat Panel LCD...
Scratched screen
it can only be fixed by replacing the screen.
Mar 26, 2009 | Acer Aspire 6930-6771 Laptop
Tractor sounding noise when I turn printer on
This has to be fixed by a technician. The feed gears probably need replacing or another gear could be suspect in your copier.
Jun 06, 2008 | Sharp AL-1655CS Laser Printer
Blank Screen on HP Laptop
HP has identified a issue with the DV6000Z and monitor. I just reported the same problem to HP and even though off warranty, they will fix free. Power up of DV6000Z you will get 3 beeps and no monitor display. External monitor does not work either. This is a known issue woth the DV6000Z.
May 06, 2008 | HP Pavilion dv6000z Notebook
LCD Display
This service manual will show you how to disassemble your laptop to replace the LCD screen.
The procedure starts on page 114.
http://h10032.www1.hp.com/ctg/Manual/c00374392.pdf
Please let me know how you make out..
thanks.
Jan 29, 2008 | Computers & Internet
Gateway laptop vertical dotted lines across the screen
Sounds like a problem with the LCD assembly or cable. You may want to reseat the LCD cable at the LCD end. It could be a loose internal connector in the LCD assembly.
Ron-
Dec 13, 2007 | Computers & Internet
Acer AC713 17" CRT Monitor Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
