Question about Philips GOGEAR SA6045 MP3 Player
My Phillips MP3 GoGear Vibe 4GB player (Model SA1VBEO4K/17) was working very well. Now it will still play my music and audio, but only a lighted screen shows - nothing appears on it, so I cannot control which selections I want to listen to - I just have to listen randomly to whatever comes next, because no words appear on the screen. How do I get my screen to function again? I tried resetting (I put a paperclip into the little reset hole, but nothing happened.
yvonmagic
  • 82 Answers
SOURCE: need download phillips gogear 4gb software
Philips Support - SA3245/37 hi , this is the link to get sofwear, go there and download and after shutdoun the pc and plug your mp3 and start the pc , make sure you have a authentic microsoft windows licence to have window media 11 to make it work, and let me know yvon chow !!!
Posted on Dec 31, 2008
  • 3 Answers
SOURCE: i have a phillips gogear vibe 4gb mp3 player, and
I had the same problem until I installed the cd that came with it. Now it shows up right away. Hope this helps.
Posted on Dec 27, 2009
  • 218 Answers
SOURCE: gogear vibe 4gb cannot be turned on
check battery voltage
Posted on May 31, 2010
SOURCE: taking apart a gogear vibe 4gb
I was trying to find a way to take this apart as well, because a soda exploded inside my car while I was away for about 6 hours, and when I came back it was covered in sticky goo, inside and out. After a little fiddling, it was easy to take apart and reassemble.
On the back, remove the barcode sticker, there is a single very small screw. Remove that. You will need a very thin-shafted cross-headed screwdriver. After its removed, take a razor and slide it into the small crack in the casing closest to screw housing, and pop the back off.
After the back is off, there are 4 more screws to remove, 2 black screws near the bottom, and two smaller silver screws on the top, one on each side of the LCD screen. You may need tweezers to remove the smaller silver screws.
After all 4 screws are removed, take your razor and slide it in between the top of the LCD screen and the casing and pop it out. Take note at how it is removed, because it needs to be reinserted the same way.
If you need to remove the directional pad, its a bit tricky. I used my tweezers to pop the two tabs on the left out, and then popped the rest out going clockwise. It takes some time and patience, because the tabs might pop back in.
There you have it. Not difficult at all.
Posted on Jun 18, 2010
  • 32 Answers
SOURCE: i downloaded the philips media converter but it
hi, friend, the aHisoft Video Converter is just prepared for you, It is a Total Video Converter that can convert video to MP4/MKV/WMV/AVI and other popular formats such as: AVC, FLV, MP-1, MP-2, 3GP, 3GPP, Mov, M4V, ASF, SWF, VOB, DV, Super VCD, VCD, DVD and HD video.
so i think it will be helpful, you can search it on google
or visit http://www.downloadvideos-convert.com
Have a nice day, my friend
Posted on Aug 24, 2010
I have a Phillips GoGear Vibe MP3 player. How do I turn it off??
I suspect all models of the GoGear Vibe work the same way. You turn on and off the unit by sliding and holding the switch on the side. This switch is on the opposite side from the volume controls. If you simply slide this power switch in the opposite direction, you can toggle the button lock on and off. (This locks every function except the volume control.) (Look for the power and padlock icons near the switch.)
Documentation for the Philips MP3 players should be available from their site. The SA1VBE04K/17 documentation is here: http://www.usa.philips.com/c/mp3-media-player/gogear-vibe-4gb-sa1vbe04k_17/prd/en/;jsessionid=2F114FC33AAEE23A73C9DE3200F8E54F.app101-drp1?t=support .
I hope this helps.
Cindy Wels
Aug 26, 2011 | Audio Players & Recorders
Cannot play videos on my phillips go gear vibe /17 model what format does this device support
tthis device supports MPEG-4-based video formats such as DIVX, XVID, and WMV. Some players may also handle copy-protected videos. as for songs. this supports:
Apple Lossless: Apple (Mac) format for an uncompressed sound file
AAC: Advanced Audio Coding
ATRAC: Adaptive TRansform Acoustic Coupling
FLAC: Free Lossless Audio Codec
MPEG: Moving Picture Experts Group
OGG: Short for Ogg Vorbis, a free, open source music format
WAV: Uncompressed Windows standard for waveform audio files
WMA: Windows Media Audio
if you wan to watch a video that is not supported you always just convert it using http://www.soft29.com/freeware/smv_converter.html. this is a freeware meaning its a free website. with a free program. :) glad i could help
May 12, 2011 | Philips GoGear ViBE Digital Media Player
Power problem.
just get a small screwdriver and take off the back..look on the right side and you should see how the slider works..after that its easy to fix..i hope this helps.(:
Jul 15, 2010 | Philips GoGear ViBE Digital Media Player
Phillips go gear vibe 4gb mp3 says drm license expired owned it for only one month
Philips gogear vibe 4gb says its full then it says to delete some content. I deleted every thing and it still says that.
Mar 07, 2010 | Philips GOGEAR SA6045 MP3 Player
Help with loading videos on phillips gogear SA1VBEO4K/17 4G MP3
I don't know how to load music from computer to the mp3 player
Dec 01, 2009 | Philips GOGEAR SA6045 MP3 Player
Describe your philips GoGear Vibe model
Overview link for the GoGear Vibe SA1VBE04K/17:
http://www.consumer.philips.com/c/portable-video-player/gogear-vibe-4gb-sa1vbe04k_17/prd/us/
Selecting the support tab links to next site:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=SA1VBE04K/17&scy=US&slg=en
Select under Product support the required software & drivers.
Oct 29, 2009 | Philips GOGEAR SA6045 MP3 Player
What video format does gogear vibe use?
my mp3/4 does not play video when you click on vidio it says video format not supported
Jun 29, 2009 | Philips GOGEAR SA6045 MP3 Player
Philips GOGEAR SA6045 MP3 Player Logo
263 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
