Question about Jacuzzi MAGNUM FORCE POOL PUMP TWO SPEED 15 HP 115230V ()
The franklin electric motor is noisy (model 1104351449) for the Jacuzzi IMAG-U-S/A pool pump. Can I replaces just the motor? and where can I find a dealer?
  • 366 Answers
Sounds like the bearings are going. You can definitely replace the motor. There should be a dealer near you. You should google or look in the book for a pool supply company. You will need a shaft seal or probably would be better to get a "go kit" for that pump, the supplier should be able to help you with that. If not, most pool companies have good techs that can come out and replace the motor for you.
Posted on Aug 26, 2010
How do I replace the on/off switch on my jacuzzi pool pump
you might not be able to replace the switch parts might not be available jacuzzi is out of business you might be able to replace the motor if not get a new pump they can cross reference for you
Jul 28, 2014 | Jacuzzi Pool & Spa
I have an 11 year old Jacuzzi Magnum Force 1227 pool pump model 15UMFS. I want to replace it, but don't know how many horsepower it is. Can you tell me?
Probably 1.5 HP but if you can read any of the nameplate data on the motor it would be helpful to confirm. A better approach might be to size the new pump to the volume of water in the pool.
If all you are going to replace is the pumps motor then can you provide at least the amp ratings off the motor? Those should help verify what your old unit's horsepower really is.
John
Apr 14, 2011 | Jacuzzi MAGNUM FORCE POOL PUMP 2 HP...
My electric motor went bad and i am trying to replace it but can't remove it from the pump housing
you do not want to replace the motor only, the pump is handled as a unit... there are seal issues, etc.
Sep 05, 2010 | Jacuzzi Magnum Force Series Pool Pump 1...
I have a Hayward max-flo ii pool pump and it is very noisy. I already replaced all seals because it was also leaking. Are the bearings the cause of the noise? If so how do I replace bearings?
The bearings have likely lost their lubrication and have failed. You may be able tot find a local electric motor repair shop to replace the bearings. It really is not a diy project. However, if you can't find a local shop to do it, most folks replace the motor.
May 15, 2010 | Hayward 2HP Pool Pump Motor A O Smith...
Hi I have a magnum 1000 Jacuzzi pump for my
alot of companies use to have a damper ring on pump shaft which would knock down some of the noise a pump motor made pumps make noise and the bigger the pump the louder the noise if its not vibrating or clunking then its running as it should
Apr 21, 2010 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Jacuzzi Magnum 1000 - overheating & looking for manual
Loosen the motor and impeller from the pump by backing off the large plastic nut and take that whole section to an electric motor repair shop for inspection. If the motor is salvagable, they can quote the repair or replacement.
Jul 05, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Jacuzzi pump not pumping
I would probably say that the pump is clogged up or frozen. The motor humms until the heat sensor clicks it off. Try taking apart the front of pump and see if it turns and you should see the problem. Parts are available at most pool stores. Pumps are usually cheaper online.
Jun 25, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
I have a jacuzzi magnum 1500 pool pump which leaks. I changed the O-ring and it still leaks. If I have to change the seal on it, how do I change it. I tried undoing everything on this pump. Thanks!
You need a 201 seal for the pump. Most electric motor shops that work on pumps and of course pool store carry these. If you are unfamiliar with how to change the seal, the charges to have it done are usually low. We charge $15 - $30 depending on how much of the pump is brought in and therefore remains to be taken apart to replace the seal. The seal is about a $5 item.
If trying yourself, you will need to completely disassemble the pump, lock the motor shaft at the rear of the unit, spin off the impeller, and replace both halfs of the seal.
Jun 07, 2009 | Jacuzzi MAGNUM POOL PUMP 1-1/2 HP MAGNUM...
Pump stops running on high speed
You have a magnetek motor and it is overheating and cycling its thermal overload. A local electric motor repair shop may be able to fix it however it will likely need to be replaced. It is to costly to repair the motor if the damage is in the windings.
Assuming at that low a horsepower it is 115V, the likely replacement motor is a catalog #BN37. We sell it for $157. You are usually better off replacing the seal when you replace the motor and most Jacuzzi pumps are either a 200 or 1000. They should be around $5.
Jun 07, 2009 | Jacuzzi Pool & Spa
Jacuzzi MAGNUM FORCE POOL PUMP  TWO SPEED 15 HP 115230V () Logo
127 people viewed this question
Top Jacuzzi Pool & Spa Experts
Jay Finke
Jay Finke
Mike
john h
Are you a Jacuzzi Pool and Spa Expert? Answer questions, earn points and help others
