Question about RCA 27V550T 27" TV
Estoy en mexico, pero ya habia usado la tv sin problemas, solo que ahora no se ven los canales del cable (la señal de cable no tiene consola como en USA). la tele trae configuracion para USA y ALASKA, me pide un codigo postal o algo asi, como la configuro para poder ver la señal de clable (solo logro ver los canales de la tv abierta) I'm in Mexico, but had already used the TV with no problems, only now they are not cable channels (the cable channel has no console like in USA). configuration brings TV to the USA and Alaska, I asked a postal code or something like set up to see the signal clable (only get to see the tv channels open)
    Top Expert:
  • RCA Master
  • 75,157 Answers
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Type in this key phrase " my service table today " in the search box at the top right of the the home page, to get gathered some pages which has the details of practical experiences of the author of that site. The search result might display about 20 Nos of related posts. Press the "All posts" at the bottom of the list, then you can select them one by one.
Posted on Apr 06, 2017
4 Suggested Answers
SOURCE: necesito data eeprom de tv rca 27f634t chasis a al encender pocos
cambiale el flyback y ponle la memoria original de vuelta. cuando encienda trata de ajustar el control de screen en el flyback hasta el punto en que cuando cambies los canales no se apague. creeme que esto me tomo mucho tiempo en encontrarlo pero al fin lo arregle. The Tech
Posted on May 15, 2009
yambo
  • 230 Answers
SOURCE: tengo un tv que tiene la falla en la convergencia de colores
Hola, gracias por visitatar fix ya.
Mira, tienes un fusible abierto, que no te permite entrar a los ajustes.
A un lado del fly back hay tres pastillitas colo cafe ( fusibles), el de enmedio es el que tienes que cambiar (400ma), pero tienes que resoldar toda el area del fly back, por que ahi tienes falsos o loose connections.
Si tienes alguna pregunta, aqui estare.
Gracias.
Posted on Jul 26, 2009
SOURCE: El tv tiene audio y señal pero no hay
Checa una bobina que va entre las patas del transistor horizontal y resoldala muchas veces ese es el daño
Posted on May 18, 2010
Tengo un plasma sanyo 50 pulgadas modelo dp50747m lo que tiene es que: no prende y le cambie los fusibles que estban quemados pero ahora se oye que prende pero no se ve nada solamente se enciende el...
Amigo yo tengo el mismo problema con el mismo plasma..y no encuentro solucion...Tu ya pudiste arreglarala?? Ojala pudieras decirme como lo resolviste o cualquier info al respecto...gracias.
Sep 05, 2010 | Sanyo DP50747 50 in. Plasma TV
Como le ago para programar los canales en la television ya lo puse para escanear pero no los escanea la tele
Necesitas poner el cable de señal en el combo y de ahi a la television para que puedan grabarse en el combo ya que es el quien va arecepcionar la señal que quieres grabar no la tv la tv solo va a estar en modo video o en el canal 3
May 18, 2010 | Sylvania DVR90VE DVD Recorder/VCR
LA consola arranca , y se escucha el sonido PERO NO SE VE
la buena noticia es que sirve todavia y solo es un problema de video.. tienes que quitar el ps3 todos los cables de atras y volverlos a conectar despuyes de un minuto y si es posible conectalos en otro input del televisor.. si no cambia el cable por otro.. o tratalo en otro televisor.. por ahi esta la solucion ya me ha pasado antes.. por favor dale click a que mi solucion te ayudo.. me avisas
Dec 27, 2009 | Sony Playstation 3 (PS3) Console
No enciende
Los "pi" que escuchas en tu computador son codigos que la tarjeta madre envia para comunicar que hay algo que anda mal.
Dependiendo de la cantidad de "pis" y el intervalo entre ellos se puede descubrir cual es la pieza dañada.
Mencionas 6 "pi", y deben tener un intervalo quizas de 1 o dos segundos entre ellos.
Eso es definitivamente daño de memoria.
Para asegurarte cual es el modulo dañado, solo remueve toda la memoria que tienes instalada, y enciende tu computadora sin ellas..
Veras que los mismos "pi" siguen apareciendo.
Aprovecha y limpia los conectores de polvo etc.
Si tienes solo un modulo, entonces reemplazalo para que se solucione tu problema.
Si tienes mas de uno, instala uno a la vez para detectar cual es el bueno.
Asi tu computadora trabajara otra vez.
Jun 14, 2009 | HP Compaq dc7600 Convertible Minitower PC...
Silvania
Ulises realmente es un caso extrano, pero bueno todo puede pasar.
Fijate si no hay ningun boton en el televisor donde se pueda hacer un Reset
Esto seria de gran ayuda. Generalmente los botones de Reset no se ven, no estan a la vista, a los cuales se accede con algun pin u objeto.
Oct 20, 2008 | Televison & Video
Ayuda
Sabes que pasa esta anulada porque quedo pegada la funcion de los ajuste en la pantalla.
Pero esa es la clave de la solucion.
Cuando estes viendo los valores esos que no conoces hay un comando en el control remoto que sirve para ajustar, o cambiar esos valores generalmente es (ADJ) pero en tu remoto no se cual es, fijate que debe haber una tecla que te haga salir de ese menu que es el que estas viendo.
Puede ser o la misma tecla MENU, o la tecla ENTER o la tecla de los canales < > o la del volumen, la que ajusta esos valores, y asi como hay una que los ajusta hay una que te saca de ahi.
Lo unico que tenes que hacer es tratar de salir de ese menu fijandote cual boton te saca.
Ese es todo el problema
Proba de nuevo
Cuando apretas la tecla de volumen
Oct 19, 2008 | Air Tools & Compressors
No funciona
Ulises,
A ver si me entendes, el televisor se ha descalibrado con el control remoto.
o por la tecla que apretaste o por algo que paso.
Para que funcione nuevamente simplemente debes volverlo a programar.
Ya se que no anda, y ya se que probaste mil veces.
Ahora empeza de nuevo y programa el control remoto como si empezaras desde cero
Para ello necesitas el codigo de tu TV para ingresarlo en el control remoto.
Los codigos normales del Silvania son 0054, 0030, 0020, 0096
Si estos numeros no funcionan dame la informacion que te pido abajo
modelo de tu Sylvania
modelo de tu y marca Remote
Oct 19, 2008 | Vehicle Parts & Accessories
Hola que tal!
Hola,
Tu pantalla tiene 2 sintonizadores, por que no intercambias tu antena y pruebas si de misma forma la falla se sigue comportando, o por lo menos cambia... ejem: que ahora falle el recuadro mientras que el principal ya no. De ser asi, acorralamos en mucho la falla en el sintonizador ya que un sintonizador es primario y el otro es secundario para funcion recuadro.
Prueba y me dices aprovecha, en este momento tengo una identica a la tuya en servicio!!!!
Si resuelves el problema, no olvides calificar mi asistencia
saludos y suerte.
Adonisito
Mexico
Mar 13, 2008 | Mitsubishi VS-50609 50" Rear Projection...
Problema para configurar internet wireles
dependiendo de c?mo conecting wirelessly, por el tipo receptor o PCi o tipo conexi?n del usb del cuaderno de PCMCIA, necesitar?s los conductores para todos los ?stos, pero no permites que a Windows los gen?ricos los funcionen pues no son siempre compatable. Si los has instalado, quitar el adaptador sin hilos si no se construye adentro pues no dices si tienes una PC del cuaderno o del tablero del escritorio, reinstalas el software, entonces vuelves a conectar el adaptador sin hilos. si es un cuaderno despu?s va al encargado del >device del panel de control y mirar en la lista para cualquier marca del exclamation como esto significa no hay conductor compatable, si no y ves que tu adaptador sin hilos lo enumer? est? trabajando muy bien, ut que puedes enderezar para chascarlo encendido uninstall selecto de la American National Standard y para recomenzar el cuaderno para que se reinstale otra vez para ver si soluciona el problema
Sep 13, 2007 | Computers & Internet
RCA 27V550T 27" TV Logo
43 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
