Question about HP Photosmart C6180 All-In-One InkJet Printer
Copy problem Unable to copy, cannot cancel the copy command and cannot even shut the printer down. The window says "shutting down" but it never happens.
    Genius:
  • 3,587 Answers
Hmm..sounds like a case of fractured drivers..
get fresh ones here, after removing the old ones from your computer
Posted on May 07, 2008
MY HP printer can print but does not copy
Same thing just happened to my fairly new 7520 Hp.
I shut my machine first with the shut off button and then unplugged
it for about 5 minutes. Sounds like you tried this and I believe this did not work for me either so I just went into the HP official site and downloaded my printer again. Downloading your printer from their
site is easy and quick instead using the cd. It automatically removed my old printer and installed the printer again. The problem has not returned.
Another problem I just had and because I think one of my new
cartridges (yellow) is somehow damaged. I got a black line down
my pages with a note that my yellow ink is missing. Had black line only when printing and not copying. I reinserted the yellow ink and took a light damp qtip and slightly wiped the machine screen on each ink cartridge.(this screen meets the new opening from each
new cartridge. The black line left.
Hope this helps.
Jan 02, 2015 | HP PhotoSmart Office Equipment & Supplies
Keep printing old docoments / will not print current docoment / printing seem to be strunt
Follow these steps to fix your problem :
Method A :
Press the cancel button or use the cancel menu command on the printer
The most obvious way to cancel a print job is to find a cancel button or a cancel menu command on the printer and to press it. So, if you have not already done this, try this method first.
If this method worked for you, you are finished with this article. However, you may want to read the "Prevention tips" section to avoid this problem in the future.
If your printer does not have these items or if this method did not work for you, try Method B.
Method B:
Turn the printer off and on
Next, try turning the printer off and then on. With certain printer models, this cancels the print job.
If this method did not work for you, turn your printer off, and then try Method C.
Method C:
Use Control Panel to cancel printing
This method is a bit fancier. We will use Control Panel to try to cancel printing.
But what exactly are you trying to do? Are you trying to cancel printing only a single document, or are there other print jobs that you want to cancel? And are all the print job yours, or are there print jobs that other people have sent to the printer? If you have to cancel documents that other people have sent to the printer, you must have Computer Administrator status or you must have permission to cancel the print jobs. If you are using your own printer, you most likely have Computer Administrator status. If you are printing to a shared printer, you might have to ask the system administrator to cancel the print job for you.
To cancel one or more print jobs, follow these steps.
1. Click Start, and then click Run.
2. In the Open box, type control printers, and then click OK.
3. Right-click the icon for your printer, and then click Open.
* To cancel individual print jobs, right-click the print job that you want to cancel, and then click Cancel.
* To cancel all print jobs, click Cancel All Documents on the Printer menu.
Note If you cancel a print job that you did want to print, make sure that you send the print job to the printer again.
If this method did not work for you, make sure that your printer is turned off, and then try Method D.
Back to the top
Method D: Stop the print spooler and delete all spooled files
If you tried Methods A through C and you were not successful, Method D should work for you. If you came to Method D immediately only to delete a print job, some of what we say here might not apply to you, so please bear with us.
Method D is somewhat more complex and will require a bit more work than the other methods, but don't worry. Method D looks much more difficult than it really is.
First, in case that you don't know how printing works, here is a short explanation. Print jobs are sent to the printer as spooled files. This means that the files are put in a temporary location so that the printer can access a print queue and print jobs at its own speed. If you stop the spooler and its files, most of the time, you both cancel printing and delete the print job.
Note To use this method, you must have Computer Administrator status. If you are using your own printer, you most likely have Computer Administrator status. If you are printing to a shared printer, you might have to ask the system administrator to cancel the print job for you.
Step 1: Start Notepad
To stop the print spooler and its files, we will have you create and run a script file that will automatically stop the service. This sounds difficult, but it really isn't. Just follow these steps carefully.
2. In the Open box, type notepad, and then click OK. Notice that a blank Notepad document opens.
Step 2: Copy a command script to Notepad
Now we will have you copy and paste some commands to the Notepad document.
1. Carefully select (highlight) all the following text:
net stop spooler
del %systemroot%\system32\spool\printers\*.shd
del %systemroot%\system32\spool\printers\*.spl
net start spooler
2. Right-click the text that you selected, and then click Copy.
3. In Notepad, right-click in the blank document, and then click Paste.
4. Carefully select (highlight) all the following text:
C:\DeletePrintJobs.cmd
5. Right-click the text that you selected, and then click Copy.
6. In Notepad, click Save As on the File menu.
7. In the File Name box, right-click, and then click Paste.
8. Click Save.
Step 3: Run the command script file
Now that you have created the command script file, you will run it. To run it, you will copy and paste the name of the command script file in the Run box.
3. Click Start, and then click Run.
4. In the Open box, right-click, and then click Paste.
5. Click OK.
6. Notice that the Command Prompt window opens to run the command script file that you created. Notice also that this window closes automatically when the command script file has finished running. If you do not see the Command Prompt window open, check that you saved the command script file by using the correct name and that you entered the correct command script file name in the Run box.
If this method does not work the first time, or if you cannot print anything after you use this method, restart your computer, and then try again.
Nov 20, 2010 | Lexmark X2500 All-In-One Printer
How do i cancel a print job?
Method A: Press the cancel button or use the cancel menu
loadTOCNode(2, 'resolution');
Method B: Turn the printer off and on
Method C: Use Control Panel to cancel printing
printing.
steps.
    • To cancel individual print jobs, right-click the print job that you want to
    • To cancel all print jobs, click Cancel All
If
future.
files
us.
it really is.
print job.
loadTOCNode(3, 'resolution');
    net stop spooler
    del
    del
    net start spooler
    File menu.
    then click Paste.
    Note Notice that
    this file name differs from most other file names that you might have seen. That
    is because this file is a command script file.
  8. Click Save.
    click Paste.
  5. Click OK.
    Run box.
Note If this method does
Oct 08, 2010 | Pitney Bowes AddressRight DA300 Printer
Error Code: 39,003.40:133671 Yesterday the copier/scanner would not work. I shut the printer down and restarted it and received the above error code. I shut the printer down again and restarted it and...
this is a scanner problem that can be associated with the scanner lock under the scanner bed. make sure the lock is in the 'unlocked' position. it is easy to move this when lifting the scanner bed to reload the ink blocks. if this does not solve the problem you may have to replace the scanner assembly. hope this helps.
Aug 19, 2010 | Xerox WorkCentre C2424DN All-In-One Laser...
Used copy ink now it wont print
see if this works, its worth a shot. not correct code but may help . Shut down your printer by pressing Simultaneously Cancel + OK + Black + Color
Apr 29, 2009 | HP Photosmart C5180 All-In-One InkJet...
HP 7180 ALL IN ONE WON'T PRINT
Take it back. It's under warranty. Check scanner is not good
Mar 10, 2009 | HP Photosmart 3210 All-In-One InkJet...
Cannot get print operation stays on answering machine.
turn off your printer. then you chose start option from your windows. and click printer and fax option from above of hlep and support switch. and you can chose that printer in which you faced problem. and open that printer option. then you will see pending list of your printer. on that list you select all and do right click on that list and click cancel option.after cancellation of all the pending document. you turn on your printer. right now you can print as per wish.
regard
priyabrata (Be in IT)
Feb 16, 2009 | HP OfficeJet 4215 All-In-One InkJet...
Printer keeps printing the copy over and over and over
Shut down, unhook the USB cable, turn computer on, shut down, reconnect the USB cable, turn on computer.
Jan 03, 2009 | HP PSC 1210v All-In-One InkJet Printer
Hp printer will not effectively cancel print
Solution by www.freaksmania.org,
We cannot turn off HP printers when the printing job is going on or it runs out of paper,Paper Jam or Cartridge runs out of Ink or any other reason,ie power failure.
To Cancel printing easily,
1)First plug out the Power Cable(the System tray icon will now disappear).
2)Plug out the USB Data Cable
3)Reconnect the power Cable and turn the printer on.
4)Turn the printer off again and Connect the USB Data Cable.
5)Turn on and then your existing printing Job will be Cancelled.
Solution provided by Team Freaksmania
http://www.freaksmania.org
http://www.freaksmania.org/forum
http://www.freaksmania.org/coderz
http://www.freaksmania.org/graphics
Nov 08, 2007 | HP PSC 1315 All-In-One InkJet Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
35 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
