Question about Frigidaire Refrigerators
A large amount of water is collecting in bottom of refrigerator under vegetable box even when you remove the box and leave it out. It occur everyday, I changed the temperature. there is no water collecting in the tray over the motor. in the bottom of the refrigerator. I see no water in the drain line
  • Frigidaire Master
  • 43,501 Answers
Here is a tip that I wrote about how to fix your freezer so that the drain hole does not keep freezing up.
Water Running in Refrigerator from Freezer
heatman101
Posted on Aug 28, 2010
Water collects in the fresh meat compartment (in refrigerator section). Ice forms on the bottom (under the fresh vegetable bins) of the refrigerator.
Your drain is likely plugged and not allowing the defrost water to drain out. You will need to remove the rear freezer panel and thaw the drain. I would recommend installing a drain heater while you have it apart. They are inexpensive and easy to install. They come with installation instructions.
Kelly
Mar 23, 2011 | Refrigerators
What would cause a refrigerator to collect water under the fruit and vegetable drawers?
hi there, refrigerators have condensation that forms and generally goes down a little hole that is usually under the fruit and vegetable drawers. This water should go down this whole into a condensation pan that is under the refrigerator and then evaporates. Sometimes food gets in the hole under the drawers and keeps the water from being able to travel where it needs to. Try to run a pipe cleaner of something through the hole to clean it out and maybe a very small amount of HOT water. If there is no hole there, it is unusual and it is possibly something else. This is usually the problem I have. Hope this helps!
Jan 15, 2011 | Kenmore Refrigerators
Model CTX18GAZBRWW - (Hotpoint) no-frost - freezer on top Water collects under the vegetable drawers and must be removed every day.
Something to try....on the back wall of the fridge nearer to the top is a little cup like part sticking out. There is water in it but it usually runs down an attached tube inside back wall and ends up under the fridge and gets evaporated. If that tube or the little cup thing is plugged then it will drip in the fridge and collect on the inside bottom of the fridge. So the trick is to clean them out. Check it out ...may solve the problem.
Sep 07, 2010 | GE 18.2 Cu. Ft. Frost-Free Top-Mount...
My refrigerator is collecting water under the vegetable drawers
The defrost water is supposed to go into a drain hole below the evaporation coils. The hole is clogged and the water goes down the back side of the refrigerator to the bottom. Seen it. You gotta clean out that drain hole. Shop vac works great.
Jun 12, 2010 | Kenmore Refrigerators
Large amount of water collecting inside refrigerator
water drainage passage and pipe is blocked stop the refrigerator and clean the pipe
Sep 08, 2009 | Whirlpool Refrigerators
There is water collecting inside my refrigerator.
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Aug 11, 2009 | Maytag MSD2756G Side by Side Refrigerator
Water collects in bottom of refrigerator under fruit/vegetable bins
When a fridge goes in to defrost it melts the ice on the coils in the interior of the freezer. Often times there is a drain that runs to a sliding tray under the fridge. If this is clogged you will get water building up under the bins.
Jul 10, 2009 | Refrigerators
Water/liquid collects at bottom of refrigerator under vegetable drawers
For water collecting inside of a refrigerator, there is usually something leaking inside, or perhaps the door seal is letting moist air into it.
Jul 08, 2009 | Kenmore Refrigerators
Model 78182891 Coldspot with excessive water Collecting in Refrig
a plugged or frozen drain is a common problem that occurs from time to time in just about all refrigs so the answer is yes it may occur again in the future. But folllow theses directions and it will probably not occur again for 2-3 years.
  • Unplug refrigerator
  • unload food from freezer
  • remove icemaker if present (there are 3 screws remove the one on the bottom and loosen the 2 on top of icemaker then lift it off the 2 screws unplug from wiring harness)
  • remove 2 screws holding rear cover in place
  • move cover to the side or remove from unit altogether
  • defrost any and all ice from bottom of freezer and aluminum drain pan that is now exposed
  • flush drain hole that you will see once ice is cleared with warm water. (sometimes I use a large syringe or turkey baster to forcefully flush hot water thru the drain tube)
  • reassemble in reverse order
Post back if you have any questions and I'll gladly help you out Thanks Peyton
Mar 17, 2009 | Kenmore Refrigerators
Refrigerators Logo
182 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
