Question about Samsung SyncMaster XL2370 23" wide TFT Screen (2ms)" 23 inch Monitor
I feel dizzy in front of my led monitor. Why? It is brand new but i will have to return it to the store unless i can ajust it to make it like my old lcd monitor.
I just took my blood pressure it was 111/70 I am 78 yrs. old Is this good or low?
Sounds just about right how do you feel.
Blood pressure is just one indicator of your health I find the more I check the sicker I feel.
If you have a good energy level are eating a good diet don't get dizzy when you stand up or faint or feel like you're heads busting open when you do stand up or move quickly then your blood pressure is probably just fine.
Listen to the signs are body is giving you.
Good luck and stay active.
Nov 22, 2016 | Health & Beauty
Remote control not working
vizio remotes are junk. I have 70 inch led smart tv and both remotes are junk. I have no idea what brand is better to replace it with.,
Sep 19, 2014 | Vizio M422I-B1 42IN LED LCD Smart TV Full...
My View Sonic VX2250-wm-LED monitor has suddenly gone pink. I work on a Mac Mini and the monitor has always looked beautiful. I just recently bought this brand new monitor within the last 4 months. ...
I would replace the cable that connects the monitor to the computer. If that doesn't fix the problem then return the product, it should still be under warranty.
Good Luck!
Feb 28, 2011 | ViewSonic Computers & Internet
My monitor runs for about 4 seconds then blacks out. turn it off and on again an it comes on for another 4 seconds before blacking out. Any ideas? Larry
larryz 10, Did it work ok before this "black screen of death" started to occur?? Have you done any OS changes to the pc? Is unit still covered by warranty? Will "known good" old monitor work ok with pc? Have you performed the "flashlight test" that all cold cathode fluorescent lamp back-lit lcd monitor owners should know and understand the results of when black screen of death rears it's ugly head??? If BSOD not caused by software, could be problem with the monitor's internal "switch mode power supply/ccfl inverter supply" going into partial shut down (you see very faint image when flashlight is 1 inch from screen) or full shutdown ( no see image)!!! If +12v dc rail goes to shut down, then CCFL tubes will go off!!! No white light! If you do not know how the new style, screw-in curlie-Q, energy efficient, CFL light bulbs work, then go visit YOUTUBE for some video clips of ANY BRAND of CCFL back-lit lcd monitors having their SMPS/inverter supply being repaired. Remember this: Your lcd monitor isn't any different than any other brand in it's basic engineering design and mode of operation!!! If and when the "white LED" back-lit monitors hit the store shelves, then and only then will the CCFL electronic (600vac to 1000vac) ballast become history. Do some reading at this very old (2005) blog, even though not your model hp display. http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ After you do your research, return here if you require more help or feel you have been helped by this response and would care to give it a rating on fixya. Good luck with the repair. 12fixlouie north of Windy City.
Oct 19, 2010 | HP Q1859 18 inch Monitor
Where do i get a power cord for a proview monitor? Model: 780 Date: 2001 Product #: pl 765. 12vdc 5A. On the front the brand name that is on it is proview. That's it.
Hello there:
Almost any monitor or computer power cord can be purchased at a electronics store like walmart or staples or even a second hand store like goodwill that is where i get all of my spare cords for the computer repair buisness that i have and i only pay about 3 dollars or less for them most monitor cords are compatable with any computer unless it is a special brand ok I hope this helps you out
Best regards Michael
May 14, 2010 | Computers & Internet
I got a new sony high Def TV Hooked it up and now my GTD-120 comes up with Wrong region when i put any disk in that played on the old TV
Return it to the store. Once set, you cannot reset the region unless you search far and wide for the hack to reset. The hack usually requires you to push a series of buttons on the front panel to pick new region.
Mar 15, 2010 | GE GTD120 System
Blue power led has gone out
Its a simple fix if you know anything about electronics. You can pick up a replacement led at just about any Radio Shack. It envolves un soldering the old led, cleaning out the holes and re soldering a new led in. If you dont feel confortable doing this, check with your local electronics repair store and see how much they would charge. If the unit over all is working fine, I would not bother with the led.
Aug 24, 2009 | Pioneer Audio Players & Recorders
RE: no picture and no sound
the store wont exchange it, you have to get it from microsoft. if it new, save your reciept, unlkess its not older than 30 days, then take it back to the store
the store should replace it, some stores have 15 days return policy
good luck
Jun 16, 2008 | Microsoft Xbox 360 Console
Monitor is busted!
If your pc works on another monitor. I would recommend you buy a new LCD monitor or a used CRT.
The best solution if your computer works is to buy a LCD screen, I've thrown out my 17" crt screens they aren't worth anything these days. You can get a used crt from ebay
Over here where I live I bought a used crt for 25usd thats was over a year ago.
Theres really no point in trying to repair the screen if its broken, buy a working one or a brand new lcd.
Good luck.
May 21, 2008 | Gateway FPD2275W LCD Monitor
LG old but brand new blank screen green light making a tik,tik,tik sound.
Nothing you can really do yourself with that. I would call manufacture and get solutions from them. When it comes to monitors, unless your skilled in repairing them you will only do more damage to them. If you really feel like jumping into it and have nothing to lose you should be able to find a service manual on this monitor here http://www.eserviceinfo.com/most_popular/list_8400.html and rip it apart to find the piece to replace.
Jul 17, 2007 | LG L2010B (Grey) (Gray) 20.1" LCD Monitor
Samsung SyncMaster XL2370 23" wide TFT Screen (2ms)" 23 inch Monitor Logo
59 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
