Question about Sony MHC-GX450 CD Shelf System
Power button flashes but will not power up. speakers not shorted
  • 158 Answers
Unfortunately a flashing power button indicates a shorted output ic.. anotherwords the amplifier is defective and will need to be replaced
Posted on Aug 30, 2010
My Sony home theater DZ290K had a push power protection on the display screen how can I fix it?
The "PROTECT" and "PUSH POWER" messages will flash alternately when the protective device of the amplifier has been activated because a strong signal was input, or if there is a short-circuit detected. Press the POWER button on the unit to turn off the system, and check the following items after "STANDBY" disappears.
1) Are the + and - speaker cords short-circuited?
2) Are you using only the specified speakers?.
3) Is anything blocking the ventilation holes of the system?
You may also refer to the following link for additional troubleshooting steps.
PROTECT and PUSH POWER flash alternately on the amplifier screen
Aug 26, 2015 | Sony Audio Players & Recorders
Kenwood VR 605 power light flashes
CHECK FOR CLEARED COOLING VENTS & FOR PROPERLY WORKING COOLING FANS. THIS WILL CAUSE SHUTDOWN OF THE UNIT. IF ITS ALL CLEAR, YOU PROBABLY HAVE A POWER SUPPLY ISSUE.
Dec 10, 2013 | Kenwood VR-605 Receiver
MY SONY HBD-DZ810 HOME THEATER IS CONSTANTLY SHOWING PUSH POWER PROTECTOR
Dec 20, 2012 | Sony DAV-HDX500 System
Shut off on volume 25, and protection light comes on and starts flashing. i unplug it and demo stays on forever till i hit the power button and comes on for 2-3 sec. then shuts back off with red light...
Try reseating all wires in the speakers, you could have it shorting out. If that doesnt work try change the cables. If that doesnt work then try plug one speaker in at a time on different channels to test if it is a short within the speaker or the speaker output.
-Dubkingz
Jun 12, 2011 | Sony MUTEKI HTDDW1600 Theater System
Denon avr 788 power switches off by itself quickly with power standby button flashing
Could be a short on one or more of the speaker outputs. Try disconnecting all speakers and turning the unit on. If that works without a power-down then you have a short in one of the speaker connections. Re-connect them one at a time to detarmine which one it is, and then you should be able to correct the problem.
If that is not the cause then you have an internal problem with the avr which would be difficult to diagnose here.
Jan 17, 2011 | Denon AVR-788
The kenworth radio has a button flashing saying protected and wont make a sound
Your unit is either locked with a code, or there is a short. If you have removed power before this problem happened then your radio is locked and you will have to call the manufacturer, if not then your speakers are shorted.
Aug 15, 2010 | Car Audio & Video
Hello, I have a prob with my Sony HCD-RV999D I just bought it from a friend, I plug the outlet everything is normal, I press the power button, the system turns on normally, but after 3 second it turns...
The reason this happens is because it takes about 3 to 5 sec. for the output circuit relay to kick in after power up, im sure at this point is when your receiver shuts off and flashes red. You have a bad output Transister its shorted to ground and the sony's protection circuit kicks in and shuts it down. Unless you are a electronic Tech. you will have to take it in to be repaired its going to be about 120 dollars to repair. Now im assuming your speakers are ok, if you have them hooked up when you do this try disconnecting them and try to power up if it does you have a shorted speaker, but normally Sony just displays overload protection on the display. Im sure you have a shorted Trans. sorry for the bad news good luck.
May 18, 2010 | Sony Audio Players & Recorders
Power light is flashing and power won't turn on
these a couple things you can try to reset,if resetting dont work you will have a amp problem.Try pushing and holding down these 3 buttons s.speaker b and att and exit buttons for at least 3 sec or more.should reset.If not also try pushing and holding down mult speaker and exit and att buttons together for at least 3 or more seconds.if still shuts down you will have shorted transistors inside of unit.
Apr 17, 2010 | Marantz SR4002
The dvr99 3 dvd home theater receiver will not stay on
Protect kicks on commonly when it over heats or when the speaker wires are crossed and it detects a short on the output. Your symptom sounds as though it may be a speaker wire because it happens right after the power is turned on. Check the speaker wire carefully, it has a habit of breaking inside the connectors of both the receiver and the speakers, especially after 5 years of service.
Feb 27, 2009 | Audio Players & Recorders
Power went off last night and our phone stopped working
I had power outage last night now corder at&t 1855 led's keep flashing keeps telling me about power outage before every new message. How do I get rid of the flashing?
Apr 14, 2007 | Uniden CLX485 Cordless Phone
Sony MHC-GX450 CD Shelf System Logo
522 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
