Saw your response for a mitsubishi Projection TV WS-55819 which powers up and shuts down in about 2 seconds... I ran the diagnostic and you suggested and got a error code 2 1... help would be appreciated.. I'd like to fix it tv only has a couple hundred hours on it...THANKS
  • 4,889 Answers
Error code 21 indicates failure of the X ray protect circuit. It is located near the CRT. The protect fault may indicate failure of one or more High-resistance resistors(of the order of 50000-100,000KOhm) . In any case its best to leave this repair to a qualified tech. The CRT circuit handles voltages of the range 20K-30K which I am sure you don't wanna mess with , without proper training.
Posted on Aug 26, 2010
What does a 2-3 dignostic code on a Mitsubishi 55819 mean?
2blink-then 3 blink---------deflection circuit problem
It is a little misleading but means something in Horizontal or high voltage circuit (covers a lot of area inside the set) is bad.
Going to need a service manual, etc to try to track it down.
Entire chassis for this set can be removed====called a light box.
May 28, 2012 | Mitsubishi WS-55819 55" Rear Projection...
WS 55819 Mitsubishi HDTV , the tv turned off itself. The power light on for couple of second then off again. What is wrong with the TV?
This is a classic switchmode power supply, shutting down to avoid a fire, explosion, or both. This set had developed a problem, that is so severe that the set must be shut down, This set should be removed from the Power, and in my professional recommendation, you should get a "Quote" for repair, from, an Akai, Approved Service Center, this point is very important for a good result, Always contact, their local, "Head Office" Now, when you get the information you want, then you can decide as to repair of replacement. The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand, also sometimes, there has been a service bulletin in issued and the repair may be subsided or even free.
http://www.retrevo.com/support/Mitsubishi-WS-55819-TVs-manual/id/276bh851/t/2/
http://www.mitsubishi-tv.com/pdf/ownersguides/WS-55819.pdf
http://service-manual.eu/model.php?id=2703
Above, a service and repair manual, above that are two user manuals.
May 09, 2010 | Televison & Video
Mitsubishi WS-55819 TV Wont turn on.
code stands for loss of vertical. I had one of these if you can check pico fuses, check the ones on the main power board the one with the 2 convergence amps if any of them are blown then most likely the convergence amps have shorted out.
Aug 10, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubish WS-819 Protective Shutdown. 2 blinks, pause, 2 blinks
Over 95% of the time a 2 - 2 blink code on that model is a convergence output problem. You need to replace both of the convergence output IC's and perhaps the pico fuses feeding them voltage. The pico fuses are F9A04 and F9A05. They are on the same board with the convergence outputs.
May 29, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi WS-55819 power issue
No, that'll do it. Once you've changed em you'll know right away if somethin isn't right. But take faith and fire that puppy up. If the pix is good you did good. If something is amiss. I'd be happy to walk you through it. My money is on you though.
May 27, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi WS-55819 Won't turn on
If F9A04 and F9A05 are open the convergence ICs will need to be replaced as well as the two pico fuses. You will need two STK392-570 Convergence ICs and two 5 amp pico fuses. You ca get the replacement parts at the following link with free installation instructions. heres thelink.
http://servicemanuals.vstore.ca/
Jan 22, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi ws-55819
Code 22 indicates that your set is in shut down due to what is called Short Protect. The most likely cause is the Converge Ic's drawing too much current and opening one or 2 fuses. Normal repair cost varies by area and servicer. Expect 250 to 350 plus the service call. I normally do this on site.
Nov 16, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Can the WS-55819 be reset through a reset button?
Code 22 is short protect. Recheck your work. Did you check and replace open fuses and/or Convergence IC's. The Conv. IC's normally open at least one fuse when they go out.
Nov 02, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Mitsibushi WS-55819 power problems
Wade, My dad has this same set and had the same problem -- Sears came out and replaced the power switch.
Sep 10, 2007 | Mitsubishi WS-55819 55" Rear Projection...
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR LEAKY C9A60 470 PF 1000 V PART # 154P400030, PARALLEL TO D9A57 ON THE POWER PCB (NOT SHOWN IN THE SCHEMATIC). 2. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. 3. SELF-DIAGNOSIS INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB
Aug 12, 2007 | Mitsubishi WS-55819 55" Rear Projection...
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
