1998 Saturn SL Logo
Posted on Aug 26, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I cant find the low pressur port on my saturn sl 1998 can u help me please
Anonymous
Level 2:
New Friend:
  • Expert 81 Answers
  • Posted on Aug 26, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
81
Questions
Helped
22886
Points
251
If you are recharging your A/C the recharge can dial hose will only fit on it, follow the lines from your A/c compressor
99 saturn ac compressor makes noise
kinda rough indicates excessive gas in the system or excessive high pressure
the orifice tube is in the evaporator ( TX valve)
best if you take it to an accredited ac professional and have the pressures tested with gauges
tip
I have a 2001 saturn i have changed the fuel pump and it has fuel pressure and...
Your email provider likely uses a variety of filters to ensure that spam doesn't reach your inbox. Sometimes, however, your email provider might block emails that you want to receive, such as emails from FixYa.
To avoid any unwanted blockage of your FixYa emails, add [email protected] to your email address book or white list. Please follow the instructions below to do this on some common email providers.
For Gmail users:
1) Log in to http://www.gmail.com
2) Click "Contacts" along the left side of any Gmail page
3) Click "Create Contact"
4) For email, enter "[email protected]"
5) Click "Save"
For Hotmail and MSN users:
1) Log in to your Hotmail or MSN account
2) Click "Options"
3) On the left side of the page, click “Mail,” and then click “Junk Email Protection”
4) Click “Safe List”
5) Enter fixya.com into the field provided, then click “Add”
For Yahoo users:
For the older-style Yahoo mail:
1) Log in to http://mail.yahoo.com
2) Click the “Addresses” tab
3) In the “Quick Add Contact” section at the bottom, for Email enter [email protected] and then click the “Add” button
For the new Yahoo mail:
2) Click “Contacts” on the left-side menu
3) Click “Add Contact” at the top
4) For Email, enter [email protected]
5) Click the Save button at the top right
If you ever find a FixYa email in your Yahoo Bulk mail folder, open it and click the “Not Spam” button
on May 11, 2010 • Computers & Internet
I am trying to locate the low pressure port on my 2000 Saturn LS. there is no cap on the only visible and accessible port I see. It is located in the front of the engine compartment (passenger side) but...
The high pressure port is much larger than the low pressure port. It is impossible to hook a charging hose to the wrong port. If the charging hose is leaking, it is either because it is not clicked all the way on the port or the charging hose connector is defective.
The high pressure port is located on the discharge hose just to the rear (driver's side) of the A/C compressor.
How to hook up the air condition refrigerant to the car itself on a 1998 saturn sl thankyou
You will need a hose to connect to the can of coolant and to the low side fitting in the car. There will be 2 lines coming from the A/C compressor, the low side is the line that is larger in diameter of the two. Follow that line and you will find the fitting to connect the hose to. I would get a hose that has a pressure gauge included.
1helpful
2answers
I have a 1998 saturn sl1 with a code PO452 how do i fix it
CODE PO452 IS FUEL TANK PRESSURE SENSOR CIRCUIT LOW INPUT CONDITIONS.YOU COULD HAVE A FAULTY FUEL TANK PRESSURE SENSOR.
1helpful
2answers
AC for Saturn sl
The one from the rear of the compressor is where you recharge from.
Coolant Leak 98 Saturn SL1
Do a coolant pressure test, if its leaking someware you will see it.
Top Saturn Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Saturn Expert? Answer questions, earn points and help others
