Question about Elna 2007 Mechanical Sewing Machine
I have a old Elna machine. The air electronic SU 390 B. I have lost the manual and am trying to do buttonholes on a dress. I have forgotten the sequence of nob adjustments to complete the process.
  • Tally Girl
    Tally Girl Mar 03, 2011
    Just checking you have the air electronic SU model ? this has three knobs across the front and a little picture of stitches to the left of these? And the Elna-graph flap on top for the elna discs to go into?
    If so, I have the manual at home and can scan you the buttonholing pages. But from memory, there is a blue buttonhole icon on the stitch length knob and blue numbers 1-4 on the stitch width dial. So you set the stitch selector to zigzag, and then set the length to the blue buttonhole icon and start on the blue 1 on the stitch width. This sews the first bar tack, then switch to blue 2, for sewing down one side, then 3 for other bartack, then 4 to sew back up the other side. Then I think there was a blue dot to stitch a couple of stitches in place to lock off. There should be a buttonholing foot which is long slide with slot in the back end to hold the button so your buttonhole stitches out to the right length.
    Hope this helps, if you'd like me to scan you the right page, please ask.
    cheers
    Carolyn
  • Elna Master
  • 1,129 Answers
Is this the duplex model with the base that fits into a sewing cabinet?
My Elna booklet lists a SP "air electronic" duplex (CL.39), if so, then it would be same stitches as the 38, yellow front panel, 7 built in stitches and automatic knob with blue markings for buttonholing.
Here is the SU manual images for buttonholing, should be exactly the same for the SP.
I have a old Elna - tally_girl_4.jpg Instructions are:
use buttonhole foot. turn the 3 dials to buttonhole marked in blue (stitch selection, width and length).
Mark length of buttonhol on the material. Place work under foot with the mark in the middile fo the foot, the start being directly below the needle. sew the first side, raise the needle. Turn stitch width dial to 2, blue. Sew a few stitches for bartack. Raise the needle.
Turn stitch width dial to 3 blue. sew the second side. stop just short of the first side. Raise the needle.
turn the stitch width dial to 4 blue. sew a few stitches for bartack. Raise the needle.
Turn stitch width dial to "fastening off stitch" blue dot. Sew a few stitches, holding back the material by hand. Raise needle, lift pressure foot and remove work, triming off threads.
Open the buttonhole with your seam ripper (put a pin across the end to avoid any nasties).
Posted on Mar 07, 2011
  • Jane Kirkham Sep 03, 2012
    That was very helpful,but now my machine will only do the second side. I can't make another buttonhole and don't know what to do. Can you help?
I need an Air foot control # 436310-20 for my Elna Stella TSP air electronic. How and where I can get this part?
I'd suggest www.sewingpartsonline.com if you are in USA.
https://www.sewingpartsonline.com/air-foot-control-elna-436410-20.aspx
Or you could try the Elna Guru, White Sewing Center www.whitesewingcenter.com, he's the specialist supplier for all things Swiss Elna.
The air control foot is the same for all the Elna Air Electronics, whether Stella, SU, TSP, TX etc.
Mar 20, 2017 | Elna Sewing Machines
Directions for making a buttonhole with an Elna SU
A transcript from the Elna SU manual reads as follows, and the manual can be viewed on line at http://sewingonline.co.uk/instructions/elnasp/
First make a few trial runs with a scrap of material exactly as the buttonhole will be stitched, with the machine adjusted as you intend to use it.
1. Use the embroidery and buttonhole foot. It can be chnged without a screwdriver by using the fixation screw.- With the stitch width knob at "0", turn the selector to zigzag "1".
2. De-center the needle to the left.
3. Set the stitch width knob at 2, with the solid mark on top.
4. Set the stitch length dial between 1/2 and 1/4.
5. a) Mark the desired length on the material.
b) Sew the first side of the buttonhole. Stop with the needle in the material and the mark (right).
c) Raise the foot and pivot the material round the needle. Lower the foot and raise the needle.
6. a) Set the stitch width knob at 4.
b) Sew a few stitches. Raise the needle.
7. a) Set the stitch width knob at 2.
b) Sew the second side and stop just short of the length of the first. Raise the needle.
8. a) Set the stitch width knob at 4.
b) Finish off the buttonhole by sewing a few stitches. Raise the needle.
9. a) Set the stitch width knob at "0".
b) Sew a few stitches to fasten the threads, holding the material back by hand.
10. Open with the buttonhole knife, which you will find in the accessory box.
Oct 12, 2014 | Elna Sewing Machines
Hello. My 30 year old Elna electronic SU doesn't stop after I release the air pedal, from time to time. I have to tap two or three times on the pedal or simply turn off the machine to make it stop. Then,...
Sounds like the air electronic bellows sensor bit inside the machine is faulting, it can be repaired if you can find an old school Elna technician. Mine would do this too, and I did the same as you, worth putting up with as I love my AE SU machine.
if you are technical yourself and you do want to see if you can repair it, I would suggest joining the Yahoo Group called Elna Heirlooms, the members are very good at sharing knowledge on repairing the Swiss made Elna machines and I'm sure Ive read a thread on this fault.
Jul 04, 2014 | Elna 2007 Mechanical Sewing Machine
Manuel elna su air electronic
I have a manual for the SU Air Electronic if you are still looking? you can email me on tallygirl98 at yahoo dot com and I'll send you a scan
Jun 23, 2014 | Elna 2007 Mechanical Sewing Machine
Buttonhole function
Bar tack
left side
bar tack
right side
Jul 10, 2012 | Elna Sewing Machines
Elna Carine Electronic Sewing Machine
You should be able to buy a manual online but it may be a cd or image pdf file. Try www.sewingpartsonline.com or www.sewusa.com. If they don't have the Carina but have the Air Electronic SU, model 68 then this will be almost the same. Main difference is the Carina has the needle up/down button.
Here is threading up images to get you started.
Sep 21, 2008 | Elna 8007
Elna 2007 Mechanical Sewing Machine Logo
996 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
