Question about NetGear WGR614 Wireless Router
Laptop shows wireless signal is available. DSL cable, all lights burn green on the router. Can access google, when I try to access a web address, the page will not load
  • 724 Answers
In explorer > < tools > < internet options> <delete> all your temparary internet files.
now try accessing google.
On the router the only lights should be blinking are the connected ports Wan to the WWW the conneccted Lan ports to the intranet.
Powercycle the router and the reset button on the back.
Try a direct wire and see if the access to the net works.
Reconfigure the WIFI of the router by the instruction book
Posted on Aug 26, 2010
I don't have internet access and seem to have lost my connection to my Linksys Wireless-G. What do I do?
check your wireless router if it is turned on.
see if it is getting a signal from your cable or dsl connection.
you can also connect via cat 5 from your laptop and see if your getting a IP on the WAN.
reset your cable/dsl modem if your not getting any signal or IP address.
Mar 20, 2011 | Linksys Wireless-G Broadband Router
Currently Connected to internet with to Telefonica through ethernet, and SMC Wireless router will not work. Router worked a few days ago, but now will not function either via ethernet or wireless. Our...
It appears the SMC router is faulty. The router is getting an IP address from the IPS because they can can PING your router and get a reply BUT the router's PPoE/DSL light is not on, it means it is not connecting with the ISP's WEB server and therefore you cannot get into the Internet.
Feb 25, 2010 | SMC Barricade g SMC2804WBRP-G Wireless...
When the router stopped working the dsl light and the internet light were green but the power light went to red
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. . here are the steps u need to do:
1. press the reset button on the back of the router for 20sec..while pressing the reset button, unplug the power plug and after 2secs while pressing the reset button plug it back in and press for 30secs after that unplug the router for 15secs then plug it back in..once all the lights are solid and ok
2. connect the ethernet cable to port1 of the router and the other end to the lan port of your computer..
3. pull up ur browser then type at the url:192.168.1.1.or 192.168.0.1 or u can check the routers default gateway by right clicking the network icon on the lower right of your task bar and click on status and it will show the ip address of the computer, subnetmask and default gateway, the default gateway is the routers ip address, once u type in to the url, it will ask u the username and password, by default the username is admin and the password is 1234 or just leave it blank
4. it will show the setup page of the router. u can set the router on the specific internet setup that u have.
a. if ur isp is a cable company, normaly u need to do a mac clone on the router setup page by cloning the computer that is reg to the cable company, how to determine it. ex. the computer that is reg to the cable company is a desktop or laptop, if this computer is connected to the modem directly and u can access internet.
b. once u determined it u need to connect this computer directly to the router and do a mac clone and set ur internet settings to auto-dhcp..then save the settings and after that, unplug to the power of the modem and router, plug in 1st the power of the modem then once all lights lit, plug in the router, then once all lights lit, try to pull up a browser that ur computer is connected directly to the router.. ur cable connection shud be, cable from the modem will go to the WAN port of the router and connect ethernet cable on port1 going to the lan port of the computer..once u can access the internet, u can now access again the setup page of the router by typing at the url:192.168.1.1 and u can setup the wireless settings, u need to create a ssid or wireless name and a security..
5. If ur isp is a dsl normaly they give u a username and password to connect to the internet, ur settings on the router should be PPPoe
6. If ur isp gives u a static ip address settings, u need to set the router to isp setup.
a. how to check the isp of the isp given to u..
1. click on start
2. run
3. type cmd
4. it will show a dos prompt
5. from the dos prompt type ipconfig/all
6. it will list the ip address, subnet, default gateway, dns server
this settings should be type in to the settings on the router for static ip addressing..
7. Once your done on the internet setting, go to your wireless connection settings and you can create a wireless network name or ssid, set a security by selecting wep, wpa, wpa2.
8. once all is set. save the settings and to check if your laptop can access the wireless network that you did, turn on the wireless switch of your laptop, once its on, it will show the wireless network icon on the lower right of the taskbar, right click it and select on view available network, the network name that u did should list, just select it and connect and it will ask for the password, just type the password and connect, you should be connected to the wireless network and have internet access..
9. If you are going to hook up your desktop to the wireless connection, you need to install a wireless network adapter, install the driver and do the same thing as u did to the laptop, for the desktop no need of turning on the wireless switch, once you install the driver correctly, it will show a network icon..
if you have any query pls feel free to get in touch.. good luck
Nov 28, 2009 | Actiontec GT704WG Wireless Router...
Wireless light is on but when I bring in my laptop it doesn't find my network. Just quit working. ??
Turn the router off, and unplug the AC power.
Turn the router on, and wait until the lamps show that it's fully ready.
Be sure that you have _not_ disabled your laptop's wireless networking.
On your laptop, click to "view available networks".
Does the router's "SSID" show up in the output?
Connect an Ethernet cable between the Ethernet-port on the router and the Ethernet-adapter on your laptop.
Click Start
Click Run
Type 'cmd' and press ENTER.
In the "black" window, enter 'IPCONFIG'.
Find the line showing the IP-address of the "Gateway", probably something like '192.168.xxx.yyy'.
Start your web-browser, and enter: http://192.168.xxx.yyy
to connect to the router's web-interface.
Click to run the "Wireless Network Setup Wizard".
The router should restart.
Disconnect the Ethernet cable.
Repeat the "Show available wireless networks".
Or, try some other wireless-ready laptop or wireless-ready iPod Touch, to see if these devices can "see" your router's SSID.
Oct 21, 2009 | Linksys Wireless-N WRT150N Router
My laptop shows full signal but refuses to connect to the router. The wireless phone rang two days ago and knocked me offline on wireless. Can someone please help? Nobody else's wireless device works...
It sounds like the wireless setup in the router may have gotten corrupted. From the wired PC, using a browser type 192.168.2.1 to access the router. It will ask you for a password. The default is to leave it blank. If you've set one, you'll need to give it the one you set. That'll get you into the router. Check the wireless setup. Everything else should be ok, or you wouldn't be able to access the internet from your wired PC.
If you can't find anything wrong, you can try rebooting the router and the modem. Shut both down as well as your wired PC. Wait 30 seconds. Boot the modem, the router and the PC at 30 second intervals.
Jun 11, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
D-Link DI-524 works with desktop, but laptop can't get signal
Try opening internet explorer and typing in http://192.168.0.1 in the address box
If this doesn't work try http://192.168.1.1
For the username and password put admin for username and leave the password blank
Now look for an option for the Wireless Settings and change the channel from usually channel 11 to channel 4 your laptop may now see it. Otherwise try another, channels available in the uk are 1-12, I think it's 1 to 11 in USA
Feb 28, 2009 | D-Link AirPlus DI-524 Wireless Router
Connection using DSL-2640T
Try diagnose and repaire the connection if that does not work Reset your modem it should go back to default manufacture setup.Then turn modem off and connect any computer or laptop to the modem with ethernet wire turn the modem on go back to your computer that you are connected to modem with wire go to network connections and disable the wireless Network connection and enable local area connection once you see you have connected and have internet working go to start menu you can do this on the start search bar with vista or run with any other windows version type cmd and press enter, it should bring a DOS command menu and then type in ipconfig and enter scroll up and down to where you see default gateway type that ip address to your internet browser it should take you to login screen username should be administrator password admin setup your WEB key make the wireless access available DO NOT FORGET to write the web key down, give a name to the connection and change the default password from admin to something you can remember. save the settings and turn that off keep the laptop on. Then unplug the ethernet cable and switch the network connectiion again enable wireless disable local area also you need to scan the available wireless internet and pick the one you just named use the webkey to access and save when the connection in made.
Feb 18, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
I have tried to install router strait from modem to router to toshiba l30 laptop belkin shows up on laptop showing excellent signal but when i try to go on web it cannot make contact
access your routers administration by right clicking your network icon and using your gateway IP to access http://*gateway*
un - admin pw - (none), admin, public
look at your status in the belkin administration settings and see if you have an ip and gateway for your ISP.  The ip and gatway on your computer is for your belkin.
Try directly connecting the laptop to the router with a cable and see if it's on the net. If it is then you have wireless settings wrong. See belkin.com for more infor about router.
James Mac
Aug 02, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Solution 1 didn't work
Your Verizon DSL modem might be set to BRIDGE MODE. Try connecting the router again. Connect your pc to your router. Access the configuration page of the router. Set the INTERNET CONNECTION TYPE to PPPOe. You need to enter on that page the USERNAME and PASSWORD for your VERIZON DSL. Hope this helps.
Good Day
Mar 12, 2008 | NetGear WGR614 Wireless Router
No internet connection
You didn't specify if you're using DSL or Cable internet.
With DSL, keep in mind the software1.gif on the PC is what "dials out" to the ISP with your name / password, and you MUST set the name and password in the router. Otherwise, ONLY the computer that has the software installed (verizon, etc) will be able to connect.
If you're using a cable connection, you don't have to do this, however, most newer Linksys routers come with a 'setup' disk, which MUST be used regardless of connection type.
Dec 31, 2007 | Linksys Wireless-G WRT54G Router
NetGear WGR614 Wireless Router Logo
71 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
