Question about Ecoquest Fresh Air Air Purifier
How do i clean the eco-quest air purifier? I have some ammonia. what parts do I soak with it?
Follow this:
http://www.youtube.com/watch?v=0RV4rsAHnmk&feature=mfu_in_order&list=UL
Posted on Dec 08, 2010
Eco Quest Living Air XL 15S Classic Air Purifier Cleaner Ozone Ionizer USA
Ozone is not good for you. If you can smell it, it is set too high. Look at it in dark room and check for blue orange glow inside the fan louvers. If you see the glow, it is working
Jan 10, 2017 | Air Air Purifiers
How do i clean the eco-quest air purifier? Mine is the Breeze AT model.
take the back filter off and blow out the dust really well a q_tip may help with the tight spaces that will be a very tedious task check owners manual too
Nov 18, 2010 | Ecoquest Fresh Air Air Purifier
We have an alpine air purifier and the plate needs to be cleaned- should it be soaked in ammonia and reused?
Take a 1 part ammonia and 1 part water solution and an old toothbrush and dip the brush in the ammonia solution and scrub the metal grid on the plate to remove the deposits. Do both sides and then rinse with water and allow it to completely dry before reinstalling. Hope this helps.
Nov 05, 2010 | Alpine Air XL-15 Air Purifier
I have SYNAIRG4 ....digital readout said 'perform cleaning'....I did....to out filters washed and replied, put in new ceramic plate...restarted it.....digital read out...'perform cleaning'.....what now? I...
The metal contactors and the wire spade connectors get pretty corroded and can cause continuity problems . I have had to replace those spade connectors and clean the metal contactors with emry sand cloth. Another trick is to soak the plate in ammonia to reduce the corrosion present on the grids
Sep 28, 2010 | Ecoquest Fresh Air Air Purifier
Our Eco-Quest Breeze no longer works. I cleaned
I've seen several like that and found the wire connections corroded off. Easy to fix if that's the case. Make sure the unit is UNplugged before taking it apart.
Sep 03, 2009 | Air Purifiers
I have an ecoquest fresh air purifier and the end of a red wire was corroded so I replaced the end with a new one, but the unit doesnt seem to be producing any ozone smell or sanitizing. It seems as if...
That corrosion is oxidation for the lug connecting the grid plate.Metal contact fingers make contact on the plates metal grids.The same corrosion exists on those metal contact fingers and the plate itself. Clean the fingers,ensure good connections as the other wire connector spade for the other contact finger is probably compromised. You might de-oxidize the plate by soaking in pure white ammonia.At any rate,I agree about the quality of the machines and you might be faced with a small parts order from eco-quest.Do include the plate, a bulb and the bulb starter. I run 5 of these in a commercial setting and they are fairly enjoyable to work on.
Jul 25, 2009 | Ecoquest Fresh Air Living Air Purifier
Eco quest Breeze AT - Air purifier -Voltage varying, going haywire, unable to adjust controls
Call toll free 1-877-710-0057 between 8: 00 AM and 5:00 PM Eastern time and they will gladly help you.
May 27, 2009 | Ecoquest Breeze AT Living Air Purifier
Plate error
the metal contactors and the wire spade connectors get pretty corroded and can cause continuity problems .i have had to replace those spade connectors and clean the metal contactors with emry sand cloth.another trick is to soak the plate in ammonia to reduce the corrosion present on the grids
Apr 08, 2009 | Ecoquest Fresh Air Air Purifier
Cleaning of Eco Quest?
I located this telephone number on Google for an Ecoquest dealer. I apologize for not having more info. Lakeland, FL‎ - (863) 816-7707
Mar 06, 2009 | Ecoquest Fresh Air Air Purifier
I need to clean my Eco Quest Living Air purifyer plate...
clean with 50/50 ammonia/water, scrub with toothbtush, clean contacts with q-tip
Mar 01, 2009 | Ecoquest Breeze AT Living Air Purifier
Ecoquest Fresh Air Air Purifier Logo
95 people viewed this question
Top Ecoquest Air Purifiers Experts
fordexpert
Michael Youngman
Michael Youngman
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
