Question about Cameras
C:13:01 Memory stick formatting error - Cameras
  • 687 Answers
Try to format this card in your PC first using a standalone read/writer then place back into the Cybershot DSC-W320
This can happen sometimes after you have wiped the card using Google Picasa
Posted on Oct 01, 2010
  • SpideRaY
    SpideRaY Oct 01, 2010
    You might find the the MS Pro stick will still work it might only be the SD card that can't be formatted OR read in the camera.
I have Sony DSC-S40 camera with MS 1Gb, when i switch it on i have "access" then error message says" Memory stick error" and flashing "C:13:01" and I can't take photoes or...
Hello and Welcome to Fixya!
C:13:01 memory stick error message indicates a Self diagnostic message.In C:13:01 the issue may be with the Internal Memory or with the Memory Stick.
To solve it try the following solutions
Format error with the Internal Memory which can be corrected by formatting the Internal Memory.
If it is issue with memory stick then turning the power off and on again or taking out and inserting the "Memory Stick" several times may help in resolving the issue. Error may be because of Unformatted "Memory Stick" which can be resolved by formatting the Memory Stick in the Camera If it not remove by formatting in the camera then connect it to PC and tried to format it again but either FAT instead of FAT32 which is the regular format and then reinserted the memory stick and formatted it with the camara. Now it will be solved if it still exist then it means Memory Stick is broken or not compatible which can be resolved by inserting a new compatible Memory stick
I hope this solution helps you
Your token of appreciation in the form of four thumbs and testimonial will be esteemed.
THANK YOU and Keep Visiting FixYa
Apr 09, 2011 | Sony Cyber-Shot DSC-S40 Digital Camera
When I switch it on, I get this error: Memory Stick error C 13:01 camera Sony cyber shot DSC-P73
I hope it will help you
Your Rating as Four Thumbs which are given below to this solution will appreciate me
Thanks
Mar 02, 2011 | Sony Cyber-Shot DSC-P73 Digital Camera
Says error on formatting memory card.
The camera may display a FORMAT ERROR if the inserted media is not formatted or if the media was formatted on a computer. This error may also display if the inserted media is not supported by the camera.
Try to remove and re-insert the Memory Stick media several times.
Make sure that the inserted Memory Stick media is compatible with the camera. DSCW310 Camera is compatible with the Memory Stick Pro Duo upto 32 GB.
You may also try formatting the Memory Stick media to resolve the issue. Format the Memory Stick media using the FORMAT option in the camera menu.
Formatting will erase all stored data, images, movies, etc., from the Memory Stick media. FORMAT option is available in the Memory Card Tool Menu of the Camera which is in the Settings Menu. Please back up the data by inserting the Memory Stick in the Computer Memory Card slot.
This may also happen if the terminals on the Memory Stick media are dirty. Remove the Memory Stick media from the camera and use a soft dry cloth or pencil eraser to clean the contacts. Make sure there are no residual particles on the Memory Stick media before re-inserting it into the camera.
The data on the Memory Stick media or the Memory Stick media itself is damaged. Try using a different Memory Stick media in the camera.
This should resolve the issue. If the error continues to display, the media may need to be replaced or the camera may require service.
Jan 23, 2011 | Sony Cybershot DSCW310 Digital Camera
Hi I have a sony cyber shot camera when i tried to ON it The memory stick error appears saying " INSERT MEMERY STICK" inspite of memery stick is inserted also i get this error.And when i tried to format it...
The Reinsert Memory Stick error message appears when the inserted Memory Stick is corrupted or not in a correct Format. This issue can be resolved by trying the steps mentioned below:
  • Remove and re-insert the Memory Stick in the Camera.
  • Check if the inserted Memory Stick is compatible with the Camera.
  • Format the Memory Stick in the Camera. Do not Format the Memory Stick in the Computer, as this will damage the Memory Stick being used in the Camera. The Camera will not detect the Memory Stick again, if it is formatted in the Camera.
  • Clean the terminals of the Memory Stick by using a soft dry cloth.
  • Remove the Memory Stick from the Camera and check if the Internal Memory is working fine.
You may also try power resetting the Camera. Power resetting can be done by removing the batteries from the Camera and then press and hold the POWER BUTTON of the Camera for 15 seconds and then reinsert the batteries after 1 minute.
If the issue persists, service may be required.
Thanks,
KenSolutions
FixYa
Oct 21, 2010 | Sony Cameras
13:01 error
The C:13:01 error code indicates the issue with the Media used in the Camera.
This may be due to the:
Format Error of the Internal Memory.
Un-formatted Memory Stick Duo.
Broken Memory Stick Duo.
Memory Stick Duo type error.
When the Camera cannot Read or Write the data in the Memory Stick Duo.
This can be resolved by Formatting the Internal Memory and Memory Stick Duo.
If not resolved, try inserting a new Memory Stick Duo which is supported.
Try power resetting, remove and reinsert the Memory Stick etc.
This will resolve the issue, if not the Camera may require service.
Aug 06, 2010 | Sony Cyber-Shot DSC-F717 Digital Camera
When i turn on my camera it appears "error formating memory stick"
I inserted adapter and memory stick in my sony cyber shoot camera and keep getting format error. How do I format the memory stick
Jun 28, 2010 | Sony 1GB Memory Stick PRO Duo Memory Card
When i turn the camera on it says format error and i cant take any pictures
Please take out memory stick from camera and power up camera and check still gives format error?
If no further error then put memory stick back in camera and press Menu >> Format >> OK to format memory stick. That will delete all data on memory stick and refresh it for new photos.
May 17, 2009 | Sony Cyber-Shot DSC-S500 Digital Camera
Format error on my sony cybershot dsc-s730
Format error comes because memory stick has an error. Please format memory stick by going in to Menu>> format>>OK
If error still comes then memory stick is bad and need to be replaced with new one.
Apr 09, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
'Format Error'
Seems memory stick has some file error and camera firmware sense it.
Please format memory stick by going in to camera Menu, Format, OK.
Feb 03, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
Format error
i have orignal memory stick but i am also getting same error.. have forated stick on camera but no effect on error. so plz can u tell me how can i format my memory stick ... SONY GURU
Jun 07, 2008 | Sony Cyber-Shot DSC-S500 Digital Camera
Cameras Logo
755 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
