I have an RCA 32 inch TV around 5-8 years old that won't stay powered on. When you push the power button it turns back off as soon as the screen comes on. It used top stay on after doing this 5 or 6 times but now it just won't stay on. Any ideas?
  • 1,476 Answers
Markroland1,
It sounds like you have a bad capacitor in the power supply. I have a tip at http://www.fixya.com/support/r4425277-basic_direct_view_tv_troubleshooting which explains how to do basic troubleshooting on TVs. This should help you solve your problem.
Thanks for using FixYa and for the great rating!!
hardrocko
Posted on Aug 26, 2010
I have a 52" RCA
sounds like the power supply capacitors CP150, CP120 and CP114 need replacement. You can get the RCA repair kit by that same name from www.tvrepairworld.com which has the caps and the CD with repair instructions.
Aug 05, 2011 | RCA HD52W56 52" Rear Projection HDTV
My 32 in rca entertainment series tv power button flashes on and off trys to power on but doesnt can feel static come threw the screen thats about it
hi,
you can try taking the back off and dust the innards with compressed air from a air compressor. make sure you get the screws right around the a/v hoookup area in the back. stay clear of the thick yellow or red high voltage line and the box it goes to on the motherboard. If it still does it and your sentimental, take it to the tv shop for an estimate. Pawn shops have those 32 inch 200 lb monsters for cheap, dont forget the hand truck!
jm
Nov 07, 2010 | RCA 32F531T 32" TV
Looking to buy a Polaroid TDA-03211C the needs repair
I have a 3 year old TV with the same problem as shema_ross.
Aug 16, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Stays in standbye and will only flash green (power on) twice before staying in standbye
The 6 inverter transformers on the bottom of the picture is the problem and what need to be tested.
Unplug the 6 wires that goes to the LCD screen. Use a multimeter to test for resistance from each output plug on the board. The one without the resistance is the bad one.
If this doesn't locate the bad one this way, Each plug should give out DC voltage if working properly. Test each plug for voltage.
The TV will automatically turn off in a couple of seconds like before. You'll have to keep pushing the power button to test each output plug for voltage.
Soon as you find the bad Inverter Transformer, just solder in a new one and the TV should work fine after that.
The part # for the Inverter Transformer is LTZ2PC0MS008.
Here's two places to get them:
http://www.partstore.com/Part/Funai%20Corporation%20Inc/Funai/LTZ2PC0MS008.aspx
http://www.encompassparts.com/products/?LTZ2PC0MS008
Apr 23, 2009 | Televison & Video
RCA 32" 32V420T
YOU AVE TO CHANGE PROSESSOR IC I THING THE PARTS NO. IS TLC-A27VO2-TO, AND ADJ. YOUR SET WHIT SERVICE MENU.
Jul 02, 2008 | RCA 32V420T 32" TV
Power button is green - no blinks / no picture / no sound
Unplug it from the wall, wait 2 minutes and plug it back in. if problem still exists, its probably the main pcb.
Jun 19, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
TV Problem
The first thing is to check to see if the fuse is blown,if so replace with a 5 amp fuse,fuse is located near were the power cord connects to the board,make sure set is disconnected from power.
Feb 28, 2008 | RCA F32672SB 32" TV
RCA TV stopped working
Time to go to BEST BUY and nuy a better tv
Oct 13, 2007 | RCA 32F531T 32" TV
Turns on and off
You have a shutdown problem. The 3 times is a "3 strikes and your out" RCA feature that says there is something latching the set up. You will have to have a technician look at it. In this case it might not be worth it.
May 02, 2007 | RCA F32649 32" TV
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
Electro Med Services...
