Question about Dryers
My dryer runs but wont dry clothes,theres no heat
    Champion:
  • 245 Answers
THIS IS ONE OF THREE THINGS. YOUR ELEMENT COULD BE BAD, OR ONE OF THE TWO THERMAL CUTOFFS IS BAD, OR ONE SIDE OF YOUR 220 BREAKER HAS TRIPPED. I WOULD CHECK YOUR BREAKER FIRST(FREE), THEN CHECK YOUR THERMAL CUTOFFS BEHIND REAR PANEL. THEY COME AS A SET FOR ABOUT 25.00. IF YOUR ELEMENT IS BAD THEY RUN ABOUT 80.00 BUCKS. IF YOU HAVE A MULTIMETER PUT IT ON RX1 AND CHECK THE RESISTENCE. THE THERMALS WILL OHM OUT INFINITY(0) YOUR ELEMENT WILL READ ABOUT 10 TO 12 OHMS. GOOD LUCK! RATE ME IF I AM CORRECT!
Posted on Aug 26, 2010
Dryer drum loose not lining up properly making a huge thumping sound
Identification of Dryer Problems
Signs that an electric dryer may need some repairs include the dryer not heating, clothing not drying fast enough, overheating of the dryer, the door not locking shut and the dryer not starting at all. Any of these are signs of an underlying problem that can usually be solved without the help of a repairman.
Effects of Dryer Issues
If an electric dryer doesn't heat properly, it prevents the clothing from becoming dry in most cases. Restricted venting can cause clothing not to dry fast enough, as the dryer will cycle the heating. Overheating dryers can ruin clothing or cause burns. If the door on a dryer wont close, it is impossible to get any laundry dried. A dryer not running at all can be very frustrating and lead to owners needing to use a laundromat.
Considerations for Solving Common Problems.If the dryer wont heat up, owners should check the circuit breaker to see if it's down. The voltmeter at the wall plug should read 240 volts. Checking the power cord can show owners if the wires are burned where they meet the dryer.Clothing not drying fast enough and overheating are signs of restricted venting. Removing the vent hose from the dryer can help owners decide if this is the cause of clothing not drying. If the hose is removed and the dryer runs normally, the vent should be cleaned.White plastic or thin foil ducts can also lead to overheating. Only metal ducts should be used with dryers. Kinks in the vent hose can also lead to heating issues. Overheating can also be caused by a shorted heater coil, a bad operating thermostat or worn drum seals.If the door on an electric dryer will not close, it is usually a problem with the door catch. This can be solved easily by purchasing a replacement door catch for the dryer.
When a dryer wont run, it could be a number of issues. The circuit breaker may be down or the wires at the plug may be burned. It may be an issue with the door switch. The door switch should click when closed. The thermal fuse should be checked for any issues.
Preventing Dryer Problems
The electric heating element, thermostats, fuses and thermal cut-off should be checked regularly for continuity. Dryer vents should not exceed 18 feet without a helper blower in the duct. Vents that are run vertically need to be cleaned out once a year. A meter can be purchased and used to diagnose problems with your electric dryer.
Warnings and Tips.Inexperienced people should never try to fix electrical problems at home. A professional should always be used if dryer owners suspect a more serious problem. Dryer owners can purchase kits to make cleaning dryer vents easier.
Mar 11, 2011 | Whirlpool Dryers
Dryer pauses several times and takes 6 hours or more to dry it does not heat.
so it is drying clothes but is taking forever:
http://www.applianceaid.com/dryertip.html
http://www.partselect.com/dryer+wont-dry-clothes+repair.htm
so the dryer is not heating:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
these should fix the problem Good Luck Tim
Feb 19, 2011 | Danby DCD5505W Electric Dryer
My gas dryer is running but there is not any heat coming out to dry my clothes
Hello
When the dryer wont heat up and dry clothes it means that the thermostat is bad and needs replacement. This part is located on the blower wheel housing inside the duct, please get back to me if you have any other questions.
Kevin
Nov 24, 2010 | KitchenAid Dryers
Gas dryer wont dry close
replace the gas valve coils. they sit right on top of the gas valve. they are black and round, and clide down over a shaft. remove screw from plate holding them, and slide them up and off, replace, and it will run....turn gas off while working on unit:)
Sep 16, 2009 | KitchenAid KGYS750LQ Gas Dryer
Whirlpool LEN100PQO electric dryer wont shut off/no heat
if your thermal fuse is blown you will not recieve heat. if you put your dryer on sense load it will keep running because it is not sensing that the clothes are getting dry which in return your timer does not
advance
Jun 20, 2009 | Whirlpool LER5636P Electric Dryer
I have a Frigidaire Dryer model GLER331AS1 and one day it was all lite up with heat I had to manually turn it off, after that it will run but it wont turn off if it's not on the minutes drying time it just...
hi Gwen. I can help you.
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Jun 08, 2009 | Dryers
Dryer heats, tumbles clothes, blows air out exhause vent, but wont dry clothes
what type is this electric or gas? have you removed the exsaust from the wall and ran a load like this? if you have heat and this is an electric dryer it sounds like you have a blockage in your house. if the dryer runs fine without the exsaust attached then that is your problem. let me know
Jun 02, 2009 | Kenmore Dryers
Gas dryer wont trun off after drying
May 08, 2009 | Dryers
My indesit widl126s
my washer works fine but the dryer wont heat up or dry the clothes it goes onto dry but all the clothes are still coming out wet and the drum is cold
Apr 01, 2008 | Washing Machines
Dryers Logo
49 people viewed this question
Top Dryers Experts
