Question about Neovo F-417 17" LCD Monitor
Opening F-417 monitor
I'm having trouble opening my monitor to get to the video cable so I can replace it... any tips? I removed all the visible screws, but it seems like there's something else holding it together.
  • ruubke Oct 16, 2008
    I have idd the same problem also. Can you send me those pictures?
There are plastic tabs running along each side of the monitor. 4 on the top and sides, 2 on the bottom. Removing the case is more than a little unnerving, very snappy! I did it with a flathead screwdriver and quite a lot of force.
I have some pictures that may help, I'll post them if you still require help.
I think the idea is to press down on the tabs to disengage them from the front of the monitor.
Posted on May 17, 2008
  • rudvorak Oct 03, 2010
    You need to unscrew all the 6 screws to open this monitor, 4 in the corners, and the remaining 2 fixing monitor to weighty stand. Then you can dilate monitor on its sides, top and bottom, starting in its corners, using flat screwdriver and considerable force.
My monitor says :"No signal" What is the problem?
To help you troubleshoot the monitor 'No Signal' issue, please find the steps given below:
- Turn off your computer.
- Unplug the cable running from your monitor to your PC and plug it back in, making sure the connection is firm. The most common cause of this error is a loose cable.
- Re-attach the cable running from your monitor to your PC. If the monitor is still not displaying a signal after firmly reattaching the cable, the problem could lie with the cable, especially if the cable has visible damage.
- Replace your monitor with another monitor if possible. If the 'No Signal' error still appears, the problem does not rest with the cables or the monitor, but with your PC.
- Open your PC case and locate your video card. Remove the card and then replace it firmly in its slot or, if possible, insert the video card into another slot on your motherboard. A video card that is not making a firm connection will not display images to the monitor. Close your PC case and test the monitor again.
- Replace your video card completely. Your video card may suffer from internal damage that is not allowing it to output a signal.
If issue persists, it is recommended to contact your monitor manufacturer for further assistance.
GuruAid.com
Jun 13, 2016 | AG Neovo SX-17P SX-17P 17" LCD Monitor 3...
Power light off
Power surges are damaging spikes of voltage in an electrical systems, caused by lightning strikes, changes or problems with the electrical grid, or large appliances.
Power surges damage or destroy computer hardware by overheating circuit boards and other components.
Surge protectors and other devices are used to protect computers and other electrical devices from power surges.
If damage occurs to a computer from a power surge, a process of trial and error is used to replace the damaged components.
Replace the surge protector or power strip.
If neither was attached to the computer, it is highly recommended that one be used.
Follow the user's manual to open the computer.
The computer manual may have shipped with the computer in book or CD form or may be found online.
Examine the system and make note of any visibly damaged components.
Damaged components may show visible burn damage or no damage at all.
Follow the user manual to remove the power supply.
You will need to unplug the power connections to each device in the computer as well as the system board.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards.
Removal is generally achieved by removing the holding screws and lifting the power supply out of the system.
Follow the user manual to install the new power supply.
Plug the power cables into the computer components and the system board.
Close the case.
Do not re-insert the screws.
Plug the power cable into the computer and attempt to power the computer on.
Replace the power cables to the monitor and computer.
Examine the monitor.
If the monitor does not power on, it will need to be replaced.
Determine if both the monitor and computer power on.
If the monitor powers on but the computer does not replace the system board.
If both power on but there is no video signal, replace the video card.
Boot the system into Windows.
Go to the "Control Panel" and double-click on the "System" icon.
Click on the "Hardware" tab.
Double-click the network card, sound card, and other peripherals that are listed in the hardware tab.
If you replaced the system board, ensure that the device drivers are in place for the peripherals. Replace any peripheral that is still non-functional.
Computer Repair Tutorial Help and Tips
http://www.thepcmanwebsite.com/computer_repair.shtml
Dec 08, 2013 | Dell Vostro 410 Desktop Computer
My Neovo F-417 started to get lines across the screen then the images fragmented - 10 minutes & it lost power totally.
Chris,
Try unplugging the monitor from any video cables. Only have the power cable plugged into and then turn it on. You should see a message that indicates there is no video source. If you do not see this message then the monitor has failed, and you'll need to call it in on it's warranty. (If it is still under warranty.) To call neovo - the number is 866-333-3686.
If it is out of warranty - it's going to be cheaper to buy a new monitor.
If the video message that there is no signal does display, then try plugging the monitor in with a different video cable and see if that has any results. If not, try plugging the monitor into a different computer. If it works on a different computer, you may have a bad video port on the computer you are plugging the monitor into.
Hope that information helps!
Nov 21, 2011 | Neovo F-417 17" LCD Monitor
Why does moniter keep saying check video cable when turned on it is connected right
It is quite common for new flat screen monitors to report this as computer boots up. If it comes back on each time and continues then just ignore it. PC's switch the video output on and off as they power up. This is normal. New monitors are just impatient. Ian.
Sep 18, 2011 | Neovo F-417 17" LCD Monitor
My HP compaqnx9600 laptop screen display verticle lines, how can i remove them
Here are some steps that you can try.
- Hook up an external monitor.
- If the line is visible on the external display, try to update your video card driver. But if updating the driver will not remove the vertical lines, you are certainly having problem with the video card of the laptop.
- If the line is not visible, then the problem is with the LCD of the unit. Either you have to replace or check the connections of the LCD inverter or LCD cable.
- However, if you don't have any external monitor, go to BIOS setup (by pressing F10, or whatever key is designed to access the BIOS on your laptop) and check if the line is visible, if yes, you're having an LCD/screen problem. Either you have to replace or check the connections of the LCD inverter or LCD cable.
Hope this helps.
May 30, 2011 | HP Compaq NX9600 17.0-inch WSXGA+...
Blank screen HP DV1000 I can get video on an external monitor though
Your laptop may have video options:
* only internal LCD screen
* only external monitor (leaving your screen "dark")
* both screens.
Try toggling through the above 3 options.
After that, there's no part in the LCD screen that you can repair, by yourself.
So, if the computer is still under warranty, contact HP to exercise the warranty.
Otherwise, take the printer to a qualified technician, for proper trouble-shooting & repair.
Dec 10, 2010 | HP Pavilion dv1000 Notebook
I have Flat screen 14" monitor When I switch the power on the screen is blank but it changes through the four main colours and the Monitor power switch will not turn off . The Monitor is 5yrs old
It's not detecting the computer, Have you tried removing and reconnecting the vga cable usually has a blue tip on it with two screw looking apparatuses that twist.
try that first, second trouble is to check the video card.
Sep 14, 2010 | Dell Computers & Internet
My Acer x193w monitor is powered ON but goes blank
Is the display going dark, but if you shine a light on the display you can still faintly see an image? If that's the case, the monitor's backilight is going off. That's frequently because of capacitors that fail. You can open the monitor and check them, replacing any that are visibly bad or below their marked value.
If the display is going blank meaning there's no image but the backlight is still on, capacitors might still be to blame, but the might be other electronic parts at fault. The problem might also be in the cable. A bad wire or bent pin making a poor contact can cause the monitor to go blank. Examine the cable carefully or try another one if it plugs in at the monitor.
If the trouble's not something obvious and relatively simple, like the bad capacitors or a faulty cable, it's usually more economical to replace the monitor than to try fixing it. It's often hard to find service information for troubleshooting, and monitors are quite inexpensive now.
Hope this helps. Thanks for using Fixya!
Feb 26, 2010 | Acer X193W LCD Monitor
F-417 working inconsistently after power fluctuation/outage.
You may want to check the VIDEO cable that goes from the monitor to the computer. Make sure its in tight. If the montor still continues doing this, it could be caused either by A) a faulty monitor, or the monitor is going bad B) the video card inside the computer is going bad. If you have another monitor in the house, try it and see if you have the same problems. If you do it's most likely the video card inside the comptuer going bad. If you don't, then replace the monitor. Was the monitor plugged into a surge protector? Let me know how it turns out... THANKS
Dec 20, 2008 | Neovo F-417 17" LCD Monitor
Neovo F-417 failure
When troubleshooting another problem with this monitor i had it open and noticed that all thought this monitor has a "fixed video cord" once the unit is opened up it actually plugs in just like any normal video cable for a monitor. If the monitor video cable is the problem(bent pins, twisted to much, left kinked) then replacing it is an option. Simply open the monitor carefully(so as not to break any clips) and remove the EMI Shield. Once you do this you will be able to see where the video cable plugs into the monitor and replace it.
Jan 29, 2007 | Neovo F-417 17" LCD Monitor
Neovo F-417 17" LCD Monitor Logo
710 people viewed this question
Top Neovo Computers & Internet Experts
Questman
Questman
Level 1 Expert
Dimitar Todorov
Are you a Neovo Computer and Internet Expert? Answer questions, earn points and help others
