Dell SX260...Wont Boot...Power Button Flashing Amber....grrrr!
I'm sure you see alot of these questions, so here I go asking for the thousandth time...I bought a used Dell SX260 3.2GHz...I plug in the power adapter to the wall...light on power adapter is yellow till I plug it into the machine...then it turns green. I try to turn on machine & front machine button flashes amber & motherboard light is amber too. My monitor light turns amber also. I know the monitor works. I tried unpluging everything....even the cd, ram & battery & let it sit for 1 minute....put battery back in & pluged power back in & still the same thing. I don't even have to push the power button for it to flash amber....just plug in power & does it all on it's own. Fan come on, but never hear any beeps. HELLLLLLP!LOLOLOL!!!
  • sobord May 25, 2008
    it use to work and any thing you do it flashes amber the monitor works but not the tower
Try these (un order of degree of difficulty) 1. Try replacing the battery on the system board. it is  typically a CR2032 button-style battery. This helps if the computer has been off for a long time.  2. Make sure all dust has been blown or vacuumed out of the computer. 3. Check to see if the USB pins are bent inside the connector on the back and the front of the computer. Straighten if possible. 4. Remove add-in cards, fans, shrouds, and heatsinks, then check the system board for leaky or mushroomed capacitors. If you would like, this may also be a good time to see if the processor is seated correctly or possibly short-circuited (burned black on the bottom, burnt or missing pins, etc). If it is any of these, you may need a new system board (motherboard) 5. It may be that you need a new power supply. Do your best to make sure that it will fit your computer case and have all the power connectors you need; they are not created equal.
Posted on Aug 30, 2008
Flashing amber light
Hi, on most Dells a flashing amber light on the power button indicates a problem with the PSU or a short on the main power rail, if this is the case you should have 2 flashing lights as well, 1 & 3.
May 05, 2014 | Dell OptiPlex 3010 MT Desktop Computer
Dell Precision T3500 wont boot 1-3 lights blinking
An amber light means your computer isn't reading the hard drive or CD right, Take it to a professional to get this corrected
Dec 16, 2013 | Dell Precision Computers & Internet
When I turn on my desktop the power button stays yellow and computer doesn't boot up.
A flashing Amber power button indicates a bad power supply. A solid amber means a motherboard failure or a failed component attached to the motherboard preventing post.
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
Jun 14, 2010 | Dell Dimension 2400 PC Desktop
Dell dimension 5100 - usb ports on motherboard are broken
Flashing Amber is normally power supply
The USB ports are part of the motherboard
Jun 08, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Tower power button flashes amber but will not start
Flashing Amber power LED indicates a bad power supply.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817822008&cm_re=atx_power_supply-_-17-822-008-_-Product
May 13, 2010 | Dell Dimension™ E510 PC Desktop
Dell gx280 powerlite flashing amber and won't power up at all unplug and plug back in still amber lite
Your power supply is bad. 100% bad. I sell these computers and run across this alot.
Mar 26, 2010 | Dell OptiPlex GX280 PC Desktop
Blinking amber light and wont boot up.
if the power button was blinking amber, unplug your tower, and hold the power button for 30 seconds to 1 minute, to use any excess power stored in the capassitors in the pc. this was told to me by a dell tech, it is a small issue with the 3100=E310, and 5150=E510 Dimension desktops
Sep 24, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
Booting XP
I would purchase an external cd rom drive and use it to boot the system.
Sep 18, 2009 | Dell OptiPlex SX260 (SX2607QV0521) PC...
Dell Dimension 5150 will not boot. Flashes amber light
I had the same issue with my Dell Dimension 5150 and I replaced the front I/O USB Audio Panel and it booted right up.
Feb 10, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
4600C no power, flashing amber light
FLASHING AMBER LIGHT FIX. This maybe in fact a motherboard issue, but actually its a bit more. You can and should replace the power supply with a more powerfull one as it will help overall, but the issue is Really the front USB ports and 2 issues concerning them, 1 some devices pluged into them have boot sequences of their own, (remember your boot seq goesfrom,USB,CD,ARRAY)etc.
So if the device isnt design with its own OS, the mis-boot will get stuck Hence the Flashing light. and 2. the front USB ports dont supply alot of power upon bootup. and the devices pluged into them will again cause a mis-boot. Simply unplug everything from the FRONT usb ports. You may have to shut the computer off and unplug the machine for about *15* minutes.
Enough to get the motherboard to downpower completely.
with the front usb ports clear, and the power cord unpluged, hold down the power button and plug in the machine. should boot no problem. So to sum things up. The motherboard is fine, it just not happy with so many usb ports (power wise). A larger power supply is a good idea but wont entirly fix the issue, Unplug front usb devices as they may have some form of bootup.
Jan 19, 2008 | Dell Dimension 4600 PC Desktop
Computers & Internet Logo
1,172 people viewed this question
David Payne
David Payne
