Question about RCA F32730SB 32" TV
When the power button is pressed you hear it turn on then back off then on and off again but shows no picture. Any ideas?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 61 Answers
Its sad to say that your TV has a faulty operation.... check up the power supply section....check all the connections, re solder the circuit board we never disregard the lose connection of solders especially your TV is too old...thank you
Posted on Aug 26, 2010
How to change the channel my Sony Trinitron TV turns on to?
hit menu button on your remote, navigate to channel setup menu. on the sub-menu, set channel fix to your channel that you require. now when your tv powers up this will be the default channel. if this doesn't fix your issue then try cycling through video inputs tv/video button on your remote.
Nov 10, 2013 | Sony FD Trinitron WEGA KV-24FS120 24" TV
I was using the tv as a monitor on a laptop. When I restared the laptop, the tv screen showed multiple imagmes on top of one another. When I turned off the tv, it would not show a power light and will not...
I've got a Polaroid TV and have had nothing but issues with it. Try unplugging it and leaving it for 10 seconds then plug it back in.
You might also have pressed the PIP/POP (Picture in Picture / Picture on Picture)button, which basically tells the TV to display one input on top of another. I could have the name of the button wrong but it's something similar. If you get it to power up again, try hitting that button till it looks "normal" again.
Thanks
Moza805
Aug 30, 2011 | Polaroid TLA-01911C TV
I don't know how take a picture?
It's actually a lot easier than you'd think. You don't tell us what kind of camera you've got, but here are some general tips for beginners:
1. make sure the camera has charged batteries in it, and a memory card.
2. find the power button. It's probably on top, near the shutter "take a picture" button. Press and hold it until the camera comes on. It should show you the current 'view' on the screen.
3. If there's a selector dial on the top... turn it to the green one; that's 'easy shooting'.
4. fully press (squeeze) the button. Most kids who moan that 'it didn't take' it's because they only half pressed it. When it takes, the display will show the picture for a few seconds, before going back to the live view.
5. to see your picture, find a button that has the little triangle icon pointing right, like a 'play' button.
6. to go back to taking pictures, press the shutter button again
7. to turn it off, press the power button until it turns off
If that doesn't work for you, tell us what kind of camera you have. That'll make it easier (just a bit!)
Mar 26, 2011 | Cameras
IT TURNS ON BUT THE PICTURE WANT SHOW...
Try the following steps :
Step 1. Turn the PS3 into standby mode (red light on)
Step 2. Press and hold the power button. It will beep when you first press it, then beep again 5 seconds later. Let go of the power button when you hear the second beep
Step 3. Wait for the PS3 to start up
What this does is force the video resolution to revert back to standard definition and should hopefully solve your problem
Thanks for using FixYa
Aug 15, 2010 | Sony Playstation 3 (PS3) Console
How di I reset my Pixma printer MP150 from
Use this method with your own risk!!
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
Reset E27 Waste ink absorber full or platen waste ink absorber full
First way
turn off printer.
- put your finger and hold on/off with reset/stop button together
- turn on printer power switch
- release on/off button but in the same time still hold stop/reset button and then press on/off button again and hold.
- wait at the moment
- relese stop/reset button 2X.( your will see alarm led blingking for 2X)
- relese on/off button.
wait until your printer digital screen shows number 0.
- after printer panel screen shows number 0.
- press reset button 4x
- press on/off button 1x
wait until your hear printer roller is moving
after your hear roller moving, wait until your dont hear anything from your printer :)
then turn off and turn on your printer again and your will see your printer back to normal.
Second Way
turn off printer.
Good Luck
Jul 18, 2010 | Canon Office Equipment & Supplies
Hi- we are having a problem with our ps3....it just started overheating....we forgot to open the door...I heard the fan kick in...so we turned off the ps3 to let it cool down....now the ps3 is running...we...
try video reset
when ps3 is in standby mode(red light)
press and hold the power button till you hear a second beep.
standby mode press hold power........"beep"......"beep"..release power button
then try rebuilding the database and the file system in recovery consol
to get to the recovery consol press and hold the power button when ps3 is in standby mode(red light) till you hear a double beep. sometimes the ps3 does a beep then another beep and goes back into standby thsi is fine just release the power and quikly press and hold it again till you get double beep.
like on my 80g system it goes like this
ps3 standby...press hold power.......beep .........beep........stanby again....release and hold power again.......beep .........double beep...release power now you should be in recovery menu.
Oct 20, 2009 | Sony Playstation 3 (PS3) Console
My ps3 stopped showing picture ,it was working i turned it on i saw user screen then nothing,already replaced video cord
try video reset
No picture on lcd screen only when taking pictures
Did you accidentally press the DISP or DISPLAY button on back (it turns the screen off to save batteries). If so, press this button again to turn your LCD screen back on.
Oct 07, 2008 | Canon Cameras
Help please
called h.v. shut down call tv repair shop
Sep 18, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Televison & Video Logo
20 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
