Question about Watches
How to set a Zeemax 2000 watch - Watches
  • Jewel
    Jewel Aug 26, 2010
    Thank you for contacting FixYa. Sorry, but never heard of Zeemax and a search online produced no results. Jewel
I replaced the battery. The watch started time from Jan. 1
You have to set the year, the month and the date. Then you set the time zone. After that you can set the local time. You may also have to set the Daylight Savings Time.
The watch has a built in calendar that may run from let's say January first 2000 to the year 2070 (just a guess). If you set the calendar correctly you do not have to adjust the date when a month has 30 days, or when it is a leap year.
Sep 27, 2013 | Casio GW330A G Shock Solar Atomic Watch
I want to know how to change the clock. Tag Heuer 2000 Classic Silver Dial Steel WK1312-0
Hi! your watch probably has a screw down crown which is a feature found in well made watches. Turn the setting mechanism on the watch until it unscrews then pops out a little , pull it out two clicks to set your time, and one click to set your date. The one click setting can tricky it is what we call a halfway setting but you will feel it pulling the stem in and out. Then make sure to screw the crown back in this is a water resistant feature. Thank you! hope this helps:)
Sep 06, 2011 | Tag Heuer Watches
Just trying to find an instruction manual for a wittnauer 2002 watch
This Watch has no Batteries Its a manual Automatic 15 jewel watch.
It has a perpetual calendar that is set manually by turning the bottom right stemIt has day which is set from center winding stemIt has date which is set by pressing the top right press pin
The easiest way to set the calender is to match the small red numbers(year 2000 and up)to the month at the bottom using the lower right stem.The top calender should show the right day against one of three dates
Value for a good one Up to 200 dollars in original box
Jun 04, 2011 | Watches
Casio GW-2000-1AER watch manual
Hi, If you don't have the manual, Try this link:
http://world.casio.com/wat/download/en/manual/
Take the four-digit module number from the back of the watch, enter it, and download a PDF of your watch setting-instructions/manual.
I hope this helps you. Thanks, Bill
Sep 03, 2010 | Watches
Setting my citizen watch
i need to set the time on my citzen eco drive modle number 550198. the hands will move but once have set the time it will not run.
Jan 19, 2009 | Watches
Tag Heuer Ladies Professoinal 2000
Hi Dude, it's one of those things your going to cuss once you know. Just unscrew the Bezel.Thats it. Steve
Mar 15, 2008 | Tag Heuer cj1110.ba0576 Wristwatch
How to adjust the date in tagheuer watch
Some TAG models have a date "quick set". Pull crown out just a wee bit to position #1. Turn counter clockwise to advance date. Pulling out the crown to position #2 stops the watch and sets the time.
Dec 05, 2007 | Tag Heuer 2000 Aquaracer WAB2011.BA0803...
Citzen watch navisail America's cup stars and stripes 2000
I suggest you go to this website and pay particular attention to finding your watch movement and then you can find your manual.
http://www.citizenwatch.com/COA/English/settings.asp
Oct 11, 2007 | Watches
Watches Logo
37 people viewed this question
Top Watches Experts
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
