Question about Black & Decker String Trimmer Cordless 12" 18V
The 3 screws in the guard keep pulling out of the thin plastic. Any solution? I have tried using longer screws but even they don't hold.
    Champion:
  • 313 Answers
The plastic orange housing are stripped..its needs to be replaced.
Posted on Jun 08, 2008
I need a description for how to open and clean the grinder. I keep getting fill beans message and it has beans.
I have not done it, but I believe you simply remove the two screws you can seen when you look into the coffee bin.
I used to get "fill beans" messages when there were beans in the hopper. Eventually I determined this was due to my choice of beans: oily (ie. shiny) beans seem to clog up frequently, "dry" beans (beams without a sheen) rarely clog up.
Since the beans are gravity fed, oily ones tend to stick to one another
May 01, 2015 | Jura Capresso Impressa S9 Coffee...
Coffee beans are not going into grinder.
Your grinder is probably blocked.
It may happen if your coffee is greasy or oily.
Try to empty the coffee bin and using your vacuum cleaner, removed has much as possible the grounded coffee around the grinder.
Also, from the inside, look where the coffee grind should drop from the grinder to the brewer unit and removed any grind that could block and prevent coffee to drop.
Jun 10, 2014 | Saeco Odea Giro Plus Coffee Maker
Maxtra chainsaw parts
We added an O-ring to the gas cap, used a Goof-Off cap to replace the bar oil cap, added a flat-washer to hold the plastic saw cover. Since the pole joints slip out of place, he used very short self-tapping screws (made for steel studs) to fasten more permanently. He started the holes with the screws, but then backed them out and shortened them by grinding off 3 threads. Then he tightened them.
Mainly, we just found the problem that solves the start / fuel issues many have had on the Maxtra Pole Saw!!!!!!!! My husband noticed the carburetor seemed giggly. He had removed the air cover and been starting it by pouring a little mixed fuel directly into it, It would run a little bit, then die. I watched the fuel line, and even after pumping it up, it would get air bubbles in the line while it ran, and then drain completely. The fuel line is really short so we both thought it just might not be far enough into the fuel -- but that was not it. He saw the two nuts inside the breather and decided to remove those and the carburetor. A little tricky if you have NO mechanical skill at all, but really pretty easy, take photos if you need to remember how it goes. He found that the manifold piece behind that had 2 bolts holding it and they were VERY loose. This created a horrible air gap. He gently tightened those bolts with a hex bit keeping in mind he did not want to strip them. (Now we wish we had used Lock-Tite). We put it back together, pumped the primer AND IT STARTED ON THE FIRST PULL!!!! First pull, ran continuously, and even idled!!!! We are going to replace the fuel line with a little longer tube tomorrow. This baby will hum now!
Apr 22, 2014 | Maxtra Trimmer 30cc 2-stroke Gas Pole Saw...
How do you take the plastic clip off that hold the tone arm
Well be very carefull, since they breal soooo easily. You can get if bu unscrewing the imbuscat the side and the internal you desolder your tonearm wires and with some effort you can pull out the pivot after unscrewing the the height adjustment screw at the the side. They are crappy things and i just glue them together woth some thin bare thin wire to keep it in place, after that i use some kevlar/carbon fibre with the right glue, but not a lot of glue holds on it.... annoying part.
Jun 18, 2012 | Vestax PDX-2000MKII PRO Turntable
Maytag bravos washer making a grinding noise. It seems to make this noise when the drum is moving, any suggestions?
Unplug machine and tilt it back. Pull down the white insulation board. remove the two screws holding the white/clear plastic guard in place 5/16 nut driver. and check the gear and belt ours had come off. Now it works just like new you will need a 13mm hex for putting the gear back up.
Apr 28, 2012 | Maytag Bravos 3.8 Cu. Ft. Washer
I have been trying to fix my brothers laptop for him (Toshiba Satellite L305-S5891), I had to replace his original plastic DC Jack with a new one made of metal. just trying to solder the stupid thing to...
I suggest you try the shortest screw in a hole first, if it does not work then try the next longer screw and if this does not work then the longest screw.
Jul 01, 2011 | Toshiba Satellite L305-S5891 Notebook
For Danze Sheriton/Plymouth tub/shower faucet, I am finishing the wall with ceramic tile and have set plumbing so plastic guard face will be flush with finished tile. One drawing in the instructions shows...
Don't cover area where plastic guard should be. Make it flush. Some trim is designed to recess into the wall before it's flush. Screws, adapters, trim etc. all will need to be installed when tile is set. Make sure you have nipples extending out from shower head and spout area's as well. If you do this and think ahead a little, you will have fewer problems assembling trim.
Apr 23, 2011 | Danze & Single Handle Tub And Shower...
Replace headlight bulb on 2003 Mazda6
IS IT XENON? IF XENON TURN OFF IGNITION. 25000V. TURN WHEEL TOWARDS ENGINE ALL THE WAY AND REMOVE TWO PLASTIC SCREWS FROM THE FRONT BUMPER HOLDING PLASTIC UNDER THE MUD GUARD. PULL BACK THE PLASTIC FOR ACESS TO THE HEAD LAMP. REMOVE COVER. TURN IGNITOR, REMOVE HOLDING WIRE AND LAMP.
Nov 07, 2010 | 2003 Mazda Mazda6
Will a timber bandsaw cut thin plastic or will i need a plastic cutting blade on my clarke bandsaw. The teeth are very fine on the timber saw thats in now thanks
Hi, yes it will cut plastic, but if its a brittle plastic you will need to guard against splitting. To guard against this you can brace the plastic with a thin sheet of plywood underneath whilst cutting.
Aug 31, 2010 | Garden
Kenmore whispertone 100 model 116. powerhead no
  • The motor / cord compartment cover must be removed to access the cord reel. There are four screws that hold the cover to the chassis. Two of the screws are found under the cord-retractor-foot-pedal on the top back of the canister. To access these screws the pedal must be removed. To do this, press the pedal down and look (from the top) for the four plastic clips that attach/hold the pedal hinges to the cover. There are two at the end corners and two in the middle. Using a long, thin flat-head screw driver (or similar instrument) press each clip to unhook/popout the hinges. Note: the foot pedal spring will also come out when the pedal is removed.
    The other two screws are found under the curved hinges of the vaccum bag compartment cover. To access these, lift the cover as if accessing the vacuum bag. Keep pulling the cover back until the hinges release from the motor cover. Don't worry, it is disigned to do this and will not break but it may require a little force. A long phillip-head screw driver will be needed to access and remove each screw
Jul 18, 2009 | Panasonic Kenmore Canister Vacuum Vacuum
Black & Decker String Trimmer Cordless 12" 18V Logo
Top Black & Decker Garden Experts
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
