Question about MotorGuide Boating
I can not get reverse on my Cobra Stern Drive on a 1989 Mark Twain in Board out Board with a Chevy 3.0
    Problem Solver:
  • 19 Answers
Check linkage , it may be broken or more like to be a adjustment issue.
Remove linkage , select neutral on the gear box , then select neutral on the control handel.
Now go back to the linkage and check and adjust the linkage so it goes back together with out pulling or pushing on the cables.
Once done check to see if it still starts in neutral and then that it wont start in gear.
Posted on Aug 26, 2010
I have a 1985 chevy 3/4 ton with a turbo 350 that works in all gears except drive. put it in reverse, it goes backwards. put it in 2nd, it starts off in low and shifts to 2nd, and down shifts from 2nd to...
Very possible you have a internal fault in the drive gear only.I would suggest that you remove it and have it rebuilt.We have a local company that rebuilds them for around 300 dollars.
Feb 07, 2010 | 1989 GMC K1500
The transmission will not operate in reverse or
hey, im not a professional but ive dealt with crappy a4ld's for about two years. just from what youve said it sounds to me like youre pump may have gone. it happened on my first one. if you remove the bellhousing it is directly behind it. there are 6 or so bolts. a new one can be purchased at cobra transmissions, however if the pump seems intact it could be a million other things. if i were you and you have some know how, buy a stick shift ranger and swap it out. its really not hard. if you have any questions email me at mcdonaldmowing@aol.com good luck
Dec 22, 2009 | 1989 Ford Ranger
Why wont my reverse lights work on my 1989 chevy 1500 all my fuses are good
theres a switch at the bottom of seering collum under the dash its called a nutral saftey switch thy replacing that
Nov 21, 2009 | 1989 Chevrolet C1500
All the gear lube on my bravo III leaked out. The oil came out where the prop and the lower unit meet.
we had replaced the engine in our 87 4.3 star craft and when we put the omc cobra stern drive back in we now dont have foward gear, we have nuetral and reverse. could it be the linkage or could it be the shifter cable or any other idea's that could be the problem.
Nov 09, 2009 | Garmin Boating
Reverse light troubleshooting
It could be your drive selector is not alligned correctly. Is it a automatic and does the needle lineup with the R? IF NOT, REMOVE BOTTOM COVER PLATE AND TRY TIGHTENING THE LINE.
Mar 24, 2009 | 1989 Chevrolet C1500
My mercedes 2.6i 1989 e190 automatic only reverses no forward
Stage piston may have broke. It can be replaced with transmission in car.
Mar 17, 2009 | 1989 Mercedes-Benz 190
All gears are drive NO reverse park or NEutral. 1989 Chevy 2500
un hook the linkage and work it by hand see if it goes into park and reverse if it works thats your problem
Dec 24, 2008 | 1989 Chevrolet C/K 2500
Cobra 148
For most CB radios, some common components that fail and would cause a fuse to blow would be:
1. reverse protection diode located right after the power connector at the very rear of the board;
2. finals (2SC1306/7 or 2SC1969);
3. filter capacitor, 2200uF/16V;
4. audio amp IC located on the side of the chassis; and/or
5. 3 terminal voltage regulator (780X) or a zener diode.
Alternately, a wire (after the switch) might have been grounded.
Hope this be of some help/idea. Post back how things turned up or should you need further information.
Good luck and kind regards.
Nov 04, 2007 | Cobra 148 GTL 120-Channels Base CB Radio
Boating Logo
77 people viewed this question
Top MotorGuide Boating Experts
Mike
Phil Walker
Phil Walker
Angel Joseph Jr.
Angel Joseph Jr.
Are you a MotorGuide Boating Expert? Answer questions, earn points and help others
