Question about Whirlpool LEQ8000JQ Electric Dryer
Dryer was heating, the motor running. heating element is not gettin hot but we have power.
    Champion:
  • 245 Answers
CHECK YOUR BREAKER BOX FIRST. THEN MOVE ON TO THE DRYER VENT THEN THERMAL CUTOFFS THEN ELEMENT. THAT IS ALL OF YOUR HEATING PARTS. GOOD LUCK RATE ME!
Posted on Aug 26, 2010
Hi, i have a whirlpool duet sport wfw8400tw03. When i run to normal cycle, it stop no error code no light. The washing machine just shut down. I can run it on delicate or sanitary.Is a balance trouble
if u can run it on delicate or fluff cycle with cool air more than likely its ur cycling thermostat or the hi limit thermostat going defective test it with a meter for ohms..
1. On gas and electric dryers that have an "Auto Dry" cycle, the cycling thermostat is often used to advance the timer as well regulate the drum temperature. Essentially, thermostat will alternately turn on the heat source or the timer motor when the temperature has been satisfied. To check this thermostat, you will have to check for power to the timer motor with a multi-meter, during a cycle. This is a live voltage test and caution should be used.
2. Some dryers will use a cool down thermostat to tumble the clothes without heat, at the end of the dry cycle. Power is routed through this thermostat to the drive motor to keep it running until the drum temperature has dropped to a specific temperature. If this thermostat fails it can cause the drum to turn indefinitely or until the door is opened. You can check the thermostat for continuity with a multi-meter. This test should only be made with the power removed from the dryer.
Lastly check the moister sensor for OHMS according to ur schematic as it must show a certain amount of ohms as per ur unit. When unit has been on short while
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot or not heat at all. . If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
HI LIMIT THERMOSTAT DEFECTIVE? SHOULD SHOW OHMS AT ROOM TEMPERATURE
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
GOD IS still GOOD !!!! SO MY ADIVE IS FREE
Whirlpool Kenmore Dryer Won Heat Test Replace Heating Element 279838
Apr 17, 2017 | Whirlpool Washing Machines
Dryer will run about 10 minutes then shut off. Try to turn it back on and it just will buzz
Either a motor with bad windings,. or an over heating problem?
Dryer runs then shuts down wont start up for an hour:
Bad motor windings
GOD IS GOOD !!!!
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
Sep 30, 2014 | Dryers
The dry will not start the display or dig. Controls wont engage anything the start button keeps flashing was just working great
Bad Heating Element
Most clothing dryers heat up and dry clothes with a heating element inside the appliance's body. Maytag dryers are no different and sometimes these heating elements break down or burn out, making the dryer cease to get hot. Make sure the dryer is unplugged and the breakers that run the dryer are switched off before inspecting so you don't electrocute yourself. The heating element is in the bottom panel of the dryer and is often a silver part which heats up when the dryer is on. Sometimes the heating element will be cracked or burned out, which means it is broken. Other times it won't look damaged but may not be working. Replace the heating element if this occurs, to see if this is the main problem.
Broken Motor
Maytag dryers have motors which turn the dryer drum, tossing the clothes so that air and heat can help dry them out completely. When the dryer drum is not turning it means there is something wrong with the motor or that the motor is not getting power. Unplug the dryer and take it apart to inspect the motor. Once you have found the motor, plug the dryer back in and use a meter to see if the motor is getting power. If it is, and isn't working, then there is something wrong with the motor and how it is operating. If the motor isn't getting power, then there is something wrong with the circuits or fuses which disperse power to the motor itself.
Bad Switch
When Maytag dryers won't tumble or heat the clothes which have been put inside of them, this means there could be a number of different things wrong. However, sometimes there's a simple solution to this problem: The switch on the door of the dryer itself may be faulty or not making the electric connection it should to allow the dryer to run. This is a cheap fix and worth troubleshooting before tearing your Maytag dryer apart. Remove the switch and inspect the two leads to make sure they haven't broken or are still transferring electricity. If they aren't you will have to replace the switch
Mar 11, 2011 | Maytag Dryers
Not getting hot
  1. There are a number of different problems which can occur with models of Maytag dryers resulting in them not heating and drying clothes properly. A variety of parts could have broken or been worn out over the course of the time you have been using your dryer or something could just malfunction, as appliances tend to do from time to time. Check warranty information before trying to repair the Maytag dryer yourself.
  2. Most clothing dryers heat up and dry clothes with a heating element inside the appliance's body. Maytag dryers are no different and sometimes these heating elements break down or burn out, making the dryer cease to get hot. Make sure the dryer is unplugged and the breakers that run the dryer are switched off before inspecting so you don't electrocute yourself. The heating element is in the bottom panel of the dryer and is often a silver part which heats up when the dryer is on. Sometimes the heating element will be cracked or burned out, which means it is broken. Other times it won't look damaged but may not be working. Replace the heating element if this occurs, to see if this is the main problem.
  3. Maytag dryers have motors which turn the dryer drum, tossing the clothes so that air and heat can help dry them out completely. When the dryer drum is not turning it means there is something wrong with the motor or that the motor is not getting power. Unplug the dryer and take it apart to inspect the motor. Once you have found the motor, plug the dryer back in and use a meter to see if the motor is getting power. If it is, and isn't working, then there is something wrong with the motor and how it is operating. If the motor isn't getting power, then there is something wrong with the circuits or fuses which disperse power to the motor itse
  4. When Maytag dryers won't tumble or heat the clothes which have been put inside of them, this means there could be a number of different things wrong. However, sometimes there's a simple solution to this problem: The switch on the door of the dryer itself may be faulty or not making the electric connection it should to allow the dryer to run. This is a cheap fix and worth troubleshooting before tearing your Maytag dryer apart. Remove the switch and inspect the two leads to make sure they haven't broken or are still transferring electricity. If they aren't you will have to replace the switch.
  5. please comment on there by rating or voting how helpful.
Dec 23, 2010 | Whirlpool Dryers
Dryer will not dry clothes.
I assume it runs and this is from that stance. If it doesn't the motor has to be checked and the power coming in. In fact the dryer can run and still not have the correct power to opperate the heater.
Assuming you have a volt meter and know how to use it properly.
These are the steps that the power and machine have to take to operate properly
A. If the dryer has all of these things it has to be heating and an air flow problem (kinked or dirty dryer duck, motor fan clogged with lint, vent flapper not opening...) is suspect.
B. ELECTRICAL
1. power is correct (USA 220V across line and 115v to ground/neut) 2 hot lines with potential between them and a neutral and possible a ground
2 Door switch is closed
3 Timer switch closes and ready s power to heating element through centrifugal switch in the motor circuit after the motor is running.
4 the heating element is assumed to be good and have 220v at this point. Checking for voltage at the element will assure all before are ok and at least allowing the heater to work.
5 the heating element is controlled by 1 or more thermostats and a safety thermostat. If either of these switches do not close when the dryer is "cool" they are bad. NOTE some dryers could ahve 3 wire thermostats. These can read closed on one set and open on the other. And this is how they should be if good. But tracing the wire diagram will tell which set is closed and when.
6 if you have power, the timer contacts to the motor and the heater (separate circuits usually)are "closed", the motor runs, the cent switch "closes", the temperature operating thermostats are closed, and the heating element is good you have to have heat.
1 Check for 220V power into the dryer. If not check breakers and turn off and on several time pushing them firmly. If this is ok and 220V present step 1 is done.
2 This assumes the motor will run
Nov 01, 2010 | Whirlpool LER4634J Electric Dryer
The Dryer is starting, but shuts off after 10-15mins. It seems to be very hot. Is there an overheating element or something that can be easily replaced?
This certainly sounds like an overheating element. The problem is that the element is working. Something is allowing the element to get too hot. Then your over-limit switch is sensing the fire hazard and shutting down the system. Safety in action.
I suspect your blower fan is not running. This fan keeps the heating element from over heating by blowing the heat to the clothes in the drum. This is easily checked. The very next time you attempt to dry a load, start it and go to the exhaust vent outside. Put your hand close to it. See if it is blowing air or not. No air blowing = shut down in 10 minutes.
The blower motor should not be too hard to replace. Surely easier than the element itself. Before you pull the motor, use a multimeter to confirm that power is getting to the motor first. Power yes, motor running no, replace it.
Could also be something simple, like a wire broken or pulled off of the motor. That is why you check first. Good luck
Dec 06, 2009 | Dryers
Kenmore Heater continues to run when motor has stopped
It sounds like you have a grounded heating element. If the dryer can be turned off but the heating element continues to get hot, that indicates a grounded heating element. Be Very Careful. There could be power running thru the dryer case. I would unplug the machine and check out the heating element. Hope this helped and best wishes.
Aug 22, 2009 | Kenmore 63942 Dryer
The dryer will not get hot.
hello check all wire connections are tight then check heat sensors .all the best
shaun
Aug 04, 2009 | Dryers
Dryer not putting out warm to hot air. What is the issue?
Hope this info helps, ps don't forget to give me a rating thanks!!
For an electric dryer that runs but doesn’t heat, follow this repair roadmap:
Flip the circuit breaker off and then back on. Electric dryers run on a two-pole, 240v breaker. A common problem is for one of the legs to break which cuts the 240v that the elements need to heat up but it still supplies the 120v for the motor. The result is that the dryer runs but doesn’t heat.
If the breaker checks out, then it’s time to do some surgery. Unplug the dryer and open it up.
. Use your ohm meter to test the thermostats. All should show continuity.
Measure the resistance of the heating element with your ohm meter. Normal readings are in the neighborhood of 30 ohms.
In rare cases, the centrifugal switch in the motor can fail which breaks the power circuit for the heating elements. If this is the case, then the entire motor must be replaced since the centrifugal switch is built into the motor.
May 07, 2009 | Dryers
Kenmore dryer 400series electric not gettin hot enough to dry
you might have a open heating element. ohm out your heating elements.
Feb 20, 2009 | Kenmore 62602 Electric Dryer
Whirlpool LEQ8000JQ Electric Dryer Logo
19 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
