I have 3 JBS air conditioners. (Model HRS35PCM-1) Remotes are interchangeable and operate on two only. Faulty air conditioner will not turn on. Have checked outside switch - is in the 'on' position. Is it possible that the remote sensor receiver unit is faulty? If so, how do I detect? Any assistance you offer is appreciated.
  • noeladrury Aug 26, 2010
    Units are three years old. Unit only operates by remote...no manual setting and no reset button. Breaker box has not tripped and electricity to unit is OK as far as I can assess. Digital read-out available on remote from two other units but no read-out on faulty unit...hence I'm wondering if remote sensor is faulty. Thanks for your previous reply. Hope this gives you more info.
  • 139 Answers
Is their a reset on the cord>? if so push reset .is their power at the outlet?is the breaker triped in the breaker box i need a little more info to help..is it a digital readout? how old are the units ?does it turn on by manually ..pressing buttons or turning switch on the a/c?let me know ..good luck/joe/
Posted on Aug 26, 2010
  • joe harper
    joe harper Aug 27, 2010
    no its the main circuit control board on the unit that is faulty then
How do I program a universal remote to my haier air condioner I lost my original remote
Most universal remotes won't have a code for an air conditioner. You'll need one that is made to work with A/C systems. See: http://www.amazon.com/HQRP-HWR08XC7-T-HWR10XC5-T-HWR10XC6-T-Conditioner/dp/B00VQ1NEUU or http://www.electronicadventure.us/Merchant2/merchant.mv?screen=prod&store_code=EA&product_code=AC-5620-30 for remotes that will work with the HWR10XC6 and some other Haier air conditioners.
I hope this helps. Please add a comment with the model and manufacturer of the universal remote you have. I'll try to confirm the available codes and how to program the unit.
May 27, 2016 | Haier hwr10xc6 Air Conditioner
Need a remote. Mine stop working
There are several vendors of replacement OEM remotes on the internet.
May 22, 2016 | ACE Artic King Window Mount Air...
Does any one have a Digital Sanyo air conditioner remote rcs-ks-1 for sale ?
If Sanyo cant supply one, try any Air con parts store or electronics store. There are universal air con remotes on sale that you programme in to suit your make / model.
Jun 26, 2014 | Sanyo Split System Air Conditioner
Mt timer butoon is stuck on timer so unit wont work
All LG room air conditioners should be able to be operated without using the remote, by just using the controls on the unit. Replacement remotes are available from an LG service provider.
Jun 05, 2010 | LG Electronic Window Air Conditioner
I have the J.B.S air-conditioner . Can you tell me how to use it in winter for heating
you could install electric heating coils. to change over to a heat pump you would need to change the controls and install a reversing valve at the evaporator.
Apr 17, 2010 | Heating & Cooling
REMOTE WONT TURN ON AIR CONDITIONER TRIED ALL THE
If the remotes work on other like units but not on that one, it probably has a bad control board.
Jan 16, 2010 | Heating & Cooling
Kelvinator Split System Air Conditioner not turning on.
On some remotes there is a reset button which is pressed by using the nib of a pen. Or if this does not work you should look under the cover for a manual button, most units have one, and see if the aircon responds. I suspect your remote sensor is faulty, but try the previous suggestions first.
Jan 18, 2009 | Heating & Cooling
Remotes won't work
There is a reset button in your remote try to reset it then try the remote to your unit. If it wont work then the receiver board is defective.
Jan 04, 2008 | Heating & Cooling
Air Conditioner will not turn off with remotes
Remote control has a reset button found in front or at back inside battery compartment. If you replace your remote control with battery or your remote control is malfunctioning you to reset it.
You don't have to go outside to turn off the unit, you can "on" or "off" the unit using the emergency operation switch.
Jan 02, 2008 | Heating & Cooling
Heating & Cooling Logo
64 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
