Question about Gateway Computers & Internet
If it necessary to conect the ethernet cable to the usb port on back of the One ZX 4000 series
  • 119 Answers
Ethernet cables don't go into the usb hub, they go into the Ethernet port on the back. So...no, an Ethernet jack won't work in a usb hub.
Posted on Aug 26, 2010
Computer does not recognise speedstream 6300
you try form USB or LAN interface \\Ethernet connection (recommended)
  1. Plug one end of the RJ-11 telephone cable into an unfiltered telephone wall jack (enabled for Sympatico High Speed Internet service).
  2. Plug the other end of the RJ-11 telephone cable into the DSL port on the back of the modem.
  3. Plug one end of the RJ-45 Ethernet cable into your computer's Ethernet port.
  4. Plug the other end of the RJ-45 Ethernet cable into the Ethernet Port 1 on the back of the modem.
  5. Insert the rounded end of the power adapter into the Power port and the dual-pronged plug end into your power outlet.
  6. Press the power button to turn on the modem.
USB connection
  3. Plug the small, square end of the USB cable into your computer's USB port.
  4. Plug the wide, flat end of the USB cable into the USB port on the back of the modem.
May 28, 2012 | Efficient Networks Speedstream 6300...
Where do you hookup the printer to the one zx series
Where you hookup your printer to your PC will depend in part on what interface your printer uses to communicate with your PC.
Some of the possibilities are the parallel port, the USB port or a lan port.
Most printers these days use the USB port.
There appears to be four USB ports on the back of your machine.
HTH
Jun 16, 2011 | Gateway One ZX190 PC Desktop
I have the Lacie Minidisk Ethernet 500 GB that contains all my house PC backup. I both an USB Minidisk Lacie (1 GB) in order to use MySafe feature but it never worked.
Hello Elio,
Use MySafe to back up the files stored on the Ethernet Disk mini Home to an attached USB storage device. This way, if files on the Ethernet Disk mini are damaged or accidentally deleted, you can restore them to their original locations.
There are three main steps to using MySafe,Connecting an external USB hard drive,Backing up files to the external USB hard drive,Restoring files to the Ethernet Disk mini (if necessary)
Before you can back up files, you need to connect a hard drive to your Ethernet Disk mini via the USB port on the back. Use a hard drive that is USB 2.0 compatible.
While connecting an external hard drive make sure your Ethernet Disk mini is turned on and connected to your network.Turn on the external USB hard drive.Connect the external hard drive's USB cable to the USB port on the back of the Ethernet Disk mini, just like you would connect the external hard drive to your computer.Confirm that the drive is properly connected. Log in and click on the Administer HipServ link. Click on USB External Storage under System.
To back up files, navigate to the file or folder you want to back up to the external hard drive and click on the disk icon in the "Backup" column of the file list.When you back up files to MySafe, the Ethernet Disk mini duplicates the file path in MySafe so that everything you back up is organized in MySafe just as in its original location. So, if you copy a file from MyLibrary, a MyLibrary folder will appear in MySafe, with all folders leading to the backed up file.
Always click the Safely Remove Drive button on the USB External Storage before unplugging your MySafe external hard drive. Wait for the interface to change and for the Use Drive button to appear before disconnecting the USB cable from the Ethernet Disk mini. Failure to safely remove your external hard drive before disconnecting the USB cable can cause data loss and/or damage the drive. Always use the Safely Remove Drive feature when disconnecting an external hard drive.
Jun 03, 2011 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
How to connect to smoothwall firewall using a cable modem
There should be an ethernet port on the back of the modem, and an ethernet port (labeled Internet) on the back of the router.
If the router uses USB input's only, then the modem will need a USB connector ("D" shaped), and you will need a cord with a D shape plug on one end, and a flat USB connector on the other.
No setup is necessary, it all just "works".
Dec 18, 2009 | Belkin (F5D7230-4) Router (587009)
Can you tell me what the difference is between the modem part for ethernet/usb adsl modems, 060-E240-061 AND 060-E242-A01. I would appreciate and info or direction to a specific web site for this info....
when your pc conect with ethernet port also say that LAN port and oter port is USB port
which one conect with ethernet/LAN port is
called ethernet Modem and which conect with
USB port called usb Modem.
Jul 06, 2009 | Computers & Internet
Wifi
Yes you should be able to with a USB cable. Most later models have either an Ethernet or USB cable port available on the printer.
Jan 03, 2009 | Office Equipment & Supplies
Trying to get router to work
that would be a settings issue for the router..the output of the modem should work on usb or ethernet..can you see the router from your desktop management application?
Oct 22, 2008 | Computers & Internet
HP Laser Jet 1320n series
The HP LaserJet 1320 has a USB port and a Parallel port.
The HP LaserJet 1320n has a USB port and an Ethernet port.
USB-to-Parallel converter cables, like this one, are designed to attach a parallel device to a computer's USB port.
But you need to do the opposite (attach a USB device to a computer's parallel port). A USB-to-Parallel converter cable will not do this.
Feb 29, 2008 | HP LaserJet 1320n Printer
Computers & Internet Logo
146 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
