Question about Galaxy Radios DX-2547 40-Channels Base CB Radio
2547 channel led is dim - Galaxy Radios DX-2547 40-Channels Base CB Radio
  • 64 Answers
This is a common problem with a lot of Galaxy, Cobra and similar radios. It usually occurs from one of two things the radio has been operated on a higher voltage than it was designed for ( Called Volting) and has damaged the LEDS or it can occur from poor connections to the display board either the 8 Volt line or the Grounds check for the proper voltage at the display. Note if you ground your meter somewhere besides the display ground you may get a correct voltage reading but still not have the correct voltage reaching the display so be sure to ground your meter at the display and read the voltage there as well.
Posted on Sep 12, 2010
Additional channels
theres viagra boards for that type of radio
Dec 21, 2013 | Galaxy Radios DX-2547 40-Channels Base CB...
How do I add channels to the Galaxy DX 2547
you have to buy a switch at radio shack that will let you add channels I think its a # 275-1386A .Then the fun begins . Heres where to go to get the rest of the information so if I print one thing wrong you can't yell that I told you to do it. These are the correct directions @ www.cbtricks.com look for galaxy 2547 and then look for freq conv and it all yours.
Jun 15, 2012 | Galaxy Radios DX-2547 40-Channels Base CB...
I WANT TO BUY A GALAXY 2547 CB RADIO. I FOUND ONE AND IT SAYS EXPORT USE ONLY . WHAT DOES IT MEAN, CAN I USE IT. THANKS
Normally, this radio will only work on CB frequencies. I suspect the radio has been modified to get channels below and above the regular 40. If so, the radio is no longer type-accepted by FCC. It is unlikely you would get into trouble using the radio.
....Don at NTCB, Inc.
Jun 25, 2011 | Galaxy Radios DX-2547 40-Channels Base CB...
Hum In The power supply
do the lights dim when transmitting? if so probably needs replacing if not there's nothing you can really do as far as i know but replace it.
Dec 16, 2010 | Galaxy Radios DX-2547 40-Channels Base CB...
Channel led very dim and only 11 volts to meter light
Hi, my name is John. Check your power supply, should be about 13 volts. hope this was helpful...
Aug 26, 2010 | Galaxy Radios DX-2547 40-Channels Base CB...
Galaxy dx 2547
Hi Joey,
It sounds to me that the power supply you are using may be a little under powered. It's not really a bad problem as long as the voltage doesn't drop below about 10.5 - 11 volts. As for the Galaxy. I'm not real certain of the question but a Galaxy will usally use more current to make it work properly, so I would suggest a bigger ( more amps ) power supply.
Good Luck and I hope this has helped some
Ed ( Radio Man )
NC Electronic
Mills, Wyoming
307-266-4675
May 05, 2008 | Galaxy Radios DX-2547 40-Channels Base CB...
Galaxy 2547 no transmit
HI,
Sorry, the best I can do is recommend you to Galaxy as they are the sole repair station for your radio. ( according to them ). Here is the web link. Good Luck
Galaxy DX Radios -- Tech Support
Ed ( Radio Man )
NC Electronic
Mills, Wyoming
307-266-4675
May 04, 2008 | Galaxy Radios DX-2547 40-Channels Base CB...
Galaxy Radios DX-2547 40-Channels Base CB Radio Logo
120 people viewed this question
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
