Question about Car Audio & Video
Need diagram for 1996 Jeep Cherokee under-dash/steering relay panel
I had a relay fall out from the relay panel under the dash/steering column area of my 1996 Jeep Cherokee. Of course, there is more than one relay spot where it could have come from and I hate to do "trial and error" with relays.
The Chiltons manual does not have a picture/description, nor does autozone.com or automotivehelper.com.
Does anyone have a picture/diagram/description of this relay panel?
Only symptoms are: horn does not work and A/C does not cool (but the fan works). The relay is the smaller type (an inch by half inch, not the one inch square type).
Thanks!
  • Matt Larkowski
    Matt Larkowski May 07, 2008
    Thanks for the tip... and that checks: I've managed to get a diagram from an auto shop. It turns out the A/C was a simple unrelated fix. The relay was a horn relay and I was able to figure out where to plug it in from the diagram. If anyone needs this diagram, I plan on scanning it in at some point in the future.
    So, in short: problem solved--once I found the horn relay location.
  • 113 Answers
Unfortunately the 2 symptoms you describe are not related to the same relay- the relays are typically in the same general area- the relay you describe sounds like the horn relay
Posted on May 07, 2008
Need to change flasher relay on jeep cherokee 1998
here is a video on changing what you asked for. it is under dash by steering column.
Jeep Cherokee blinker flasher relay how to location repair
Jan 09, 2014 | 1998 Jeep Grand Cherokee Relay
How to replace relay flashers on 1996 cadillac
On Cadillac Deville, the Flasher is located:
- Hazard flasher: Front seating area, driver side, under dash, mounted on passenger side of steering column
- Turn signal: Front seating area, driver side, under dash, mounted on passenger side of steering column
  1. Remove the necessary sound insulator panel(s) from under the instrument panel.
  2. Remove the flasher from the retaining clip and disconnect the wiring connector.
To install:
  1. Connect the wiring connector to the new flasher and install the flasher in the retaining clip.
  2. Install the sound insulator panel(s).
If you need additional details, diagrams or some copy about Owners Manual, click it to contact us.
Hope this helps, dont fogetted to rating this answer and leave us a testimonial comment.
Oct 13, 2011 | 1996 Cadillac DeVille
Where is the flasher located at?
Two FLASHER applicatiosn there:
Hazard flasher: Front seating area, driver side, under dash, driver side of steering column, mounted in convenience center
Turn signal: Front seating area, driver side, under dash, driver side of steering column, mounted in convenience center
If you need additional details or some repair manual sections, just send us a new comment.
Hope this helps (remember to rate and comment this answer).
Aug 29, 2011 | 1996 Jeep Grand Cherokee
Where is the flasher relay for a 97 jeep grand Cherokee?
Aug 19, 2011 | 1997 Jeep Grand Cherokee
Need to replace signal light flasher can not find old one
The turn signal flasher and hazard units are usually located located under the dash either to the left or right of the steering column on most models:
  1. Remove the turn signal flasher unit or hazard unit by pulling them up from the electrical connection.
  2. To install, push the unit(s) into the electrical connector.
Also, I suggest check your repair manual in this link: Jeep ZJ-Secc-8W-Wiring-Diagrams
Hope helps (remember rated this).
Jul 02, 2010 | 1994 Jeep Grand Cherokee
1996 Jeep Grand Cherokee 4WD 4.0L MFI 6cyl:
The Flasher is located front seating area, driver side, under dash, driver side of steering column, mounted in convenience center.
Application:
- Hazard flasher
- Turn signal
Check the ZJ-Secc-8W-Wiring-Diagrams (page 8) for Convince Center graphics.
I really hope helps with this (remember rated this help) Good luck.
Dec 29, 2009 | 1996 Jeep Grand Cherokee
I need to find the fuse box for a 1996 jeep grand cherokee limited
In here you can find the location of the Fuse Box, Power Center Distribution and other parts about the electrical system: ZJ-Secc-8W-Wiring-Diagrams (Module & Componentes Location / Page 10, Fig. 16)
I hope help you with this, good luck (rated this help).
Aug 30, 2009 | 1996 Jeep Grand Cherokee
Where is the flasher can located on a 2000 Jeep Grand Cherokee (Classic)? Cant find it anywhere.
are you refering to flashers not working and need to find the relay? If so its located in the fuse/relay box (under dash left of the steering column) most likely its the largest (black) relay in there. OEM part# 4686094 its easier to access by removing lower trim panel and or knee blocker.
Jul 01, 2009 | 2000 Jeep Grand Cherokee
Windows and lock wont operate on a 2004 Jeep Grand Cherokee
I just had the same with mine, pull the rubber boot back on the drivers side front door and look for a severed wire, mine was black...simply spliced the wires back together and problem solved!
Mar 21, 2009 | 2004 Jeep Grand Cherokee
Need to find my turn signal and flasher fuse on my 98 jeep cherokee looked under dash and fuse box cant find it.
It looks almost like a relay at the end of a wire. Sometimes you can get down and hear it when its on. Should be located under dash but on top of steering column. Good luck
Mar 20, 2009 | 1993 Jeep Grand Cherokee
Car Audio & Video Logo
755 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
