Question about Sony KP-57WS500 57" Rear Projection Television
My tv picture seems ok, but there is blue, arching streaks running horizontally, and a blue outline around words on screen. What is wrong with my tv? Please help.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 453 Answers
U have a bad convergence ic , if u have same soldering skill u can do this repair , but i would recoment u to hire a tv tech normal repair is about $250
Posted on Aug 26, 2010
Green Lines on Samsung DLP
Either bad capcitors, or (if you're lucky) the color wheel needs lubed up. Probably bad caps.
Jun 12, 2012 | Samsung Televison & Video
Television is a Tosiba DLP 72HM195
your tv needs a y-load board its like a grafix card as computers have due to overheating the board components are affected this is a manufacturing fault it tends to happen with samsung aswell
Feb 22, 2012 | Toshiba 72HM195 72" HDTV
I have a KP-51ws520 that a friend gave up on and bought a new LCD TV. About a year ago, after a power outage in our neighborhood, this tv now has noticeable streaks across the screen at all times. Is...
It depends on what the problem actually is; are the streaks colors like red or blue outlines around lettering etc?
The more you tell me the better I can help. I will post a photo or two of what convergence problems look like.
This set is also prone to another problem, on a blank video input look at the screen: you should only see Video 1 (etc) and if you see faint curved lines (red, green or blue) and or the back ground is also wrong color you have the second problem.
let me know which it is.. If this information helped you rate this solution as very helpful as I do this here for free.
SD TECH
Aug 20, 2010 | Sony KP-51WS520 51" Rear Projection...
Picture is very blue, especially in dark scenes.
Sony TVs has an Optical Block issue. If there is an issue with the optical block, then there will be green, blue patches or tint on the TV display. Try resetting the TV to the factory settings and try Power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue still persists, then TV may require service. You can contact the Customer relations team and check for the available options. Sony had repaired free of cost for such issues. Hence, contact the customer relations.
Jul 21, 2010 | Sony KP-57WV700 57" Rear Projection HDTV
When I set the Directv receiver box to the 1080i resolution mode, the picture on the TV is ghost mode with red and blue outlines around each figures. please help. When I set the receiver to the 480i...
This may sound strange but I have seen something like this once before in this model----In the customer menu select Convergence---DO THIS WITH NOTHING CONNECTED TO THE SET FOR SIGNAL-- IF THE multipoint convergence looks ok---I saw one of these sets where the problem was the box that was giving the set signal---easy to find out if you have them swap that box out for another---The TV does not know(convergence wise) whether you are 480 or 1080---yes, sometimes the set needs to be adjusted in each of these modes for Convergence---the set I saw the convergence was ok in 480 but out the window in 1080----he had another box in another room and when we swapped it the problem was gone.
Let me know if this helps you---in the 480 you can confirm this by hooking a DVD etc and if that looks good---suspect the box.
If you have any questions let me know--I am here to help.
SD TECH
Sep 30, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Red and blue ghosting,
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 12, 2009 | LG RU-52SZ51D 52" Rear Projection...
RCA P60752EBLG1 Convergence Problem
If you wish to get some details; visit the site linked here. Pull up older posts.
Convergence adjustment to projection TVs are given.
Apr 24, 2017 | Televison & Video
Sony Color Rear Video Projector - KP 57hw40 / Mfg. February 2002
i have the same problem picture is blue/green with blue and green arched horizontal lines
no picture at all only sound then tv shuts off after 5-10 seconds and then a bright blue flash in the center of the screen
have tried adjusting the voltage screws didnt do anything
Jul 13, 2008 | Sony KP-57HW40 57" Rear Projection...
Horizontal streak in screen
Does it only show up on Cable or does it shows on all Dvd, Cable, Sat, etc ?
Jan 09, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
PT-47WX, Blue streaks across the screen?
It is not a bulb. It is a picture tube. If there are thin blue lines across the entire screen, not just the edges, and the picture itself looks too blue, it means that the blue picture tube is being driven too hard. This could be because the blue screen voltage is too high, the boost voltage on the blue picture tube is too low, or the video output is leaky or shorted. If the picture has what looks like blue arcs and double images on one or more sides of the picture, it means that one of your convergence IC's has burned out and needs to be replaced. These are things that should be tested and serviced by a qualified tech, so allow an experienced tech to handle it for you.
Sep 07, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Sony KP-57WS500 57" Rear Projection Television Logo
46 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
