Question about Mitsubishi WS-55511 55" Rear Projection Television
My mitsubishi 55" rear projection tv won't turn on at all. It does not make the clicking sound it normally does when you turn it on and the green light does not flash at all either. Tried unplugging it and plugging it back in and also tried resetting it. Nothing is working. Any answers?
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 453 Answers
Problem with the convergence ic , normal repair on this unit is about $300 , but if u have some soldering skill u can do this job there is also 2 bad pico fuse 5amp , there is some wed side who sale as a repair kit
Posted on Aug 26, 2010
  • 2920 Answers
SOURCE: 55 inch mitsubishi rear projection,screen
you may have a bad colorwheel or its possible the flyback is going out on the tv itself.either way you will eventually lose the whole picture
Posted on Dec 05, 2008
  • 489 Answers
SOURCE: when I turn my wide screen rear projection 55 inch
something wrong with the power board. it need to be changed.
Posted on Sep 09, 2009
  • 115 Answers
SOURCE: Mitsubishi 55" rear projection TV, wouldn't turn off
um . that model doesn't have a reset button . but if no lights on front of the set even blink when you press the power button on the front or on the remote .then suspect front panel buttons ,with that model.
Posted on Sep 29, 2009
  • 93 Answers
SOURCE: Describe your WS-55413 55 in.
You may kneed a new lamp try Discount Merchant they also trouble shoot
Posted on Sep 15, 2011
SD Tech
  • 14553 Answers
SOURCE: Problem with the Mitsubishi WS-55315
ONLY1 of 2 things can cause this problem----
First thing to do is remove front speaker grill--it should pull out and issecured with plastic pegs--behind it you will find an inspection plate---
Notice the one or two pairs of wires coming from the front keyboard of theset---remove the inspection plate and follow the wires to the right--you canunplug both plugs(most have two and they are marked with letters and differents so you cannot get them wrong)
The idea here is to remove the front keyboard with its reset button etc fromthe circuit---You will still be able to try to turn the set on with theremote---
These sets have a Receiver that is called a DM board--(large metal box to theleft as you look from the back) and if the power goes out the green light willblink for about 70 seconds and then go out---it is the Receiver booting up. Itis called the DM board.
If disconnecting the keyboard allows the set to turn on--you have a bad resetswitch and two choices---either operate the set only with the remote or toremove the front screen and get at the reset switch (it is tiny) and removeand/or replace it.
If disconnecting the keyboard does not restore the set to operation---thereceiver is bad---there are 4 or more caps and some pico fuses that can fail inthat unit---Mitsubishi no longer sells or repairs these--if it is bad and notthe caps there is a company you can send the unit to and have it repaired--ifyou need to know their name let me know---
You can call them and get a quote for repairing the receiver.
Let me know what more information you need--I am here to help.
SD TECH
Posted on Sep 21, 2011
My mitsubishi tv W55613 won't turn on. green light keeps blinking even after resetting
Hit the front of the tv near the blinking light... give it a good rap or two. See if this helps. Helped mine. I had the same problem and the tech who came out to the house told me that it would work and it did! I could hardly believe it but it worked.
Feb 13, 2012 | Mitsubishi WS-55613 55" Rear Projection...
My Mitsubishi Medallion tv stays on for about 10 minutes and then shuts down and won't turn back on until a period of time has passed. It is a rear projection tv about 9 years old. Can anyone help ex
When it shuts off and the green power light goes off, press both the menu and input buttons on the front of the set (not the remote) and hold both for about five seconds and release.
Power light will blink a two digit error code like 2 blinks and then 3 blinks and repeat it several times.
What is the error code?
Nov 14, 2011 | Mitsubishi WS-55819 55" Rear Projection...
My tv ws-55819 tv won't turn on it cliks on but it won' syat on
ok when the power is plugged in hold down the menu + device buttens for five sec what is the error code there should be two sets of numbers....
like 1 pause 2 let me know and i'll see what i can do!
Feb 01, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi WS-65809 turns off right away
check the collector drop on Q29a002. If it is less than 16 nano amps, repl ic u12 in conver circuit. stk392-570 and pico fuses f04 and f05 24v circ
Jul 28, 2008 | Mitsubishi WS-55857 55" Rear Projection...
Mitsubishi 55 rear projection
sounds like yor green crt is shorted or you have some bad solder connections on the green CRT socket. Check the board with the green CRT socket for cracked solder. if the soler looks good your CRT is probably shorted.
Feb 02, 2008 | Mitsubishi VS-55705 55" Rear Projection...
Mitsubishi WS-55511 55" Rear Projection Television Logo
93 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
