Question about Amana Kitchen Ranges
Amana DRB1801AW Bottom Freezer Refrigerator. Hello. I have a loud intermittent buzz which lasts for about 7 seconds, followed by a loud click, as in a relay closing, coming from the back of the fridge. This repeats every few minutes, and the unit completely stopped cooling over night.
  • 3 more comments
  • barok129 Aug 26, 2010
    Why this ended up in kitchen ranges I don't know.
    Greetings. The buzzing is definitely not from vibrations. It corresponds with the compressor attempting to come on, but failing. It began on Sunday. By Monday morning the freezer was thawing. I unplugged the fridge for the day, and now the buzzing cycle starts immediately upon plugging it back in. The compressor simply isn't functioning. I cleaned as much dust as I could get at from the bottom of the machine, thinking it might be a thermal overload, but it has had no effect. Also, the fan in back is running fine.
    Compressor doesn't come on at all. I just hear the loud buzzing for about 8 seconds, followed by a distinct click which ends the buzzing. The fridge is quiet for about 3 minutes then the whole thing repeats.
    Would you recommend trying a Supco RCO410 3-in-1 relay overload device to try and get the compressor to start?
  • barok129 Aug 27, 2010
    Concise, accurate, and helpfull. Thankyou!
  • 4,472 Answers
It could be a bad compressor relay, a bad compressor or very likely a bad relay-overload-run capacitor. You can find the parts for your fridge here:
http://www.appliancepartsworldwide.com/Store_SearchResults.aspx?S=610222&ST=PBM
I would start with the relay. If the compressor needs replacement I would just get a new fridge.
Thank you,
Lee
Posted on Aug 26, 2010
  • 857 Answers
Such a sound usually comes from one of 2 sources:
- the compressor / pump, or
- an electrical problem.
1st check if the pump is securely fastened to the frame (where the pump's feet are attached to a sheet metal piece - this piece is often supported by springs / rubber cushions - so it can move / vibrate without shaking the entire fridge). You may want to be sure that things are "clean" here too. If this doesn't help, the pump may be imbalanced - which can cause "excessive" vibration or buzzing. You could replace the pump enirely.
If the buzz is not caused by the motion / vibration of the pump itself, there may be an electrical problem - which can be dangerous. so you may want to call for professional repair / service.
also note, a fridge is a mecanical device - some noise is normal.
  • Jayant Jha Aug 26, 2010
    3 of the most common fridge noise makers are the evaporator fan motor, condenser fan motor and the defrost timer. The evaporator fan motor is in the freezer section. Often when the freezer door is opened, the noise will get louder. The condenser fan motor is at the back bottom of the fridge. The defrost timer can be found in several different spots, at the back of the fridge, inside the fridge or under at the front are some common areas to find the defrost timer. Do not attempt to oil any of these parts, replacing them is the best repair.
    Sorry to say most times this is a faulty compressor. A compressor is a electric motor and pump mounted from springs inside the black dome, if one of these springs stretches or breaks the motor and pump hits the outer casing dome and bangs when it shuts off. Other things to check for, tubing touching one another, something fallen behind the fridge, condenser fan motor blade hitting something, defrost condensing pan out of place.
The refrigerator often freeze food at the rear of fridge. Have a buzzing sound follow by a click which last for a few seconds. The bottom freezer stopped working, started again and is not freezing now
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 11, 2010 | Amana ARB1917CSR Bottom Freezer...
My amana frig made a loud noise last night and now it doesnt work??
<span style="FONT-FAMILY: Arial; BACKGROUND: white; COLOR: black; FONT-SIZE: 10.5pt">Hi,</span><br /> <span style="FONT-FAMILY: Arial; BACKGROUND: white; COLOR: black; FONT-SIZE: 10.5pt"><br />As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.</span><br /> <span style="FONT-FAMILY: Arial; BACKGROUND: white; COLOR: black; FONT-SIZE: 10.5pt"><br />If your refrigerator is running but warm, then&hellip;</span><br /> <span style="FONT-FAMILY: Arial; BACKGROUND: white; COLOR: black; FONT-SIZE: 10.5pt"><span style="mso-tab-count: 1"> </span><br />Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...<br /><br />Refrigerator Condenser Coil Cleaning Refrigerator Repair<br /><a href="http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning" target="_blank">http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning</a><br /><br />Refrigerator Troubleshooting Refrigerator Compressor<br /><a href="http://www.fixya.com/support/r3885294-refrigerator_troubleshooting" target="_blank">http://www.fixya.com/support/r3885294-refrigerator_troubleshooting</a><br /><br />Refrigerator Compressor Start Capacitor and Start Relay<br /><a href="http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor" target="_blank">http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor</a><br /><br />heatman101 <br style="mso-special-character: line-break" /><br style="mso-special-character: line-break" /></span><span style="FONT-FAMILY: Arial; COLOR: black; FONT-SIZE: 10.5pt"></span>
Aug 27, 2010 | Amana Easy Reach AFD2535DE Bottom Freezer...
Amana Bottom Freezer, Neither freezer nor refrigerator is cooling
Contact the repairclinic.com for tech advice, they are very knowledgeable about these types of problems and what causes them, the service is free and they can sell you the needed parts after you chat with them online.
Apr 20, 2017 | Amana ARB1917CSR Bottom Freezer...
Buzzing noise
Put off it's power supply then switch it on after somtimes
May 12, 2010 | Kenmore 76579 Bottom Freezer French Door...
Amana botton freezer buzzing 10 sec, freezer not cooling
CHECK MICRO/ SW WIRES @ FREEZER INSIDE THE CABINET COULD BE LOSE
Aug 19, 2009 | Refrigerators
Buzzing noise from back of freezer
need to remove rear panel inside of freezer section. check for normal operation of evap fan motor. check for ice build up on evap.
Apr 21, 2009 | Amana ARS2464B Side by Side Refrigerator
Buzzing noise near compressor on an Amana refer. PARB1917CSO
I can help , It was the relay , they can blow when they experience a hard start , by replacing it and having the same issue this means the compressor is locked up , they sell a booster for this that can sometimes free the compressor up , its called an rco410 , this part will be your only chance to get your compressor going again. let me know if you have any other questions and tell me how it works out.
Phil
Jan 07, 2009 | Amana ARB1917CSL Bottom Freezer...
Buzzing intermittent
It sounds like the ice maker. If you don't have the water hooked up, and the ice sensor bar is in the down position, the ice maker assembly will attempt to make ice continuously.
Solution is easy: raise the ice sensor bar until it clicks in the up position. It will lock in this position, and the ice maker will not cycle anymore.
May 04, 2008 | Amana ABB2227DE Bottom Freezer...
most likely the compressor relay is the clicking noise but i think the problem is most likely the compressor is starting to go bad and is lcoking up. if the refig is under 5 yrs old it is most likely still in warranty by amana
Dec 09, 2007 | Amana ABB1927DE Bottom Freezer...
Kitchen Ranges Logo
179 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Mike Carew
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
