2000 Ford Escort Logo
Posted on Aug 26, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Service Engine soon light just activated at 84000 miles. What can cause this on this model?
Anonymous
Level 2:
New Friend:
  • Expert 81 Answers
  • Posted on Aug 26, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
81
Questions
Helped
22866
Points
251
Time for factory service, that happens on those between 80000, and 100000 miles. Ford lets you know. They reset it once service is complete.
1helpful
My 96 Lumina, 3.1L has 94,000 miles and today during normal driving the service engine soon light came on and at idle the engine seems to be skipping or missing
If you know the plugs are fine then an ignition wire or a coil will cause the same symptom . If you had a code reader it would show you which cylinder is causing the miss. Beyond that a compresion test is needed.
1helpful
Engine Service Soon Light On code P0154
Error Code: P0154
Description:
Heated Oxygen Sensor (HO2S) 1 , Bank 2 - No Activity Detected
Problem areas:
- Wiring.
- Open circuit in signal wire, between Heated Oxygen sensor 1, Bank 2 and ECM. (Must check and confirm)
- Heated oxygen sensor (HO2S).
- Engine control module (ECM).
Suburban service engine soon
i think the check engine light caused by oxygen sensors,due to little misfire detected , fuel system ,bank 1 and bank 2 lean and rich mixtures..
2answers
Get "Service Engine Soon" light after car was
Purchase a OBD2 code reader for $50-$100. Scan for codes and let me know what Diagnostic Trouble Codes are active.
84000 miles and engine light came on, the car is driving fine and just had an oil change.
Pressure warning lamp, Check Engine warning lamp? Can you be a bit more specific. Thanks.
Regards,David
My service engine soon light is on. I have a known problem of a SDM being out (my airbags will not function)My service engine and the airbag light are constantly on because of this. Is the SES light on...
The service engine soon light will not be relate to the airbag light. You will need to have your obd3 Diagnostic Trouble Codes read Most auto parts stores will do this for you. This will also pinpoint the cause of your SES light. If your bags have not been deployed you can have the control module reset at www.myairbags.com for a reasonable price.
84000 miles on 6 cyl Mitsubishi Gallant. What is the recommended mileage for timing belt replacement?
Timing belt replacement for rubber belts is around 60, 000 miles, maximum is 90,000 miles, Since you have 84,000 miles, I would do it soon.
6helpful
Service engine soon light on my 2002 nissan xterra came on at about 100,000 miles. What could be the cause
If it's the indicator that literally says "service engine soon", and not the check-engine light, then you have no worries. That's programmed to come on at set intervals to remind you that routine service may be due soon (oil change, inspection, tire rotation, etc). It's not an indication of failure. Failures will be shown by the check-engine light. That one is nothing to worry about. Your owner's manual should have a procedure to turn it off.
2helpful
Service engine light comes on , p0420 code
the light can be caused by any one or combination of over 200 trouble codes, go to any kragen or Autozone parts store and ask for a trouble code test, it is free, then record the code(s) they come up with and post them back on fixya
3helpful
2000 Lincoln Contential Service Engine Soon Light
yes...they do program the computers to come on or give a "service engine soon" light so that you will bring them back into the dealership....if you have access to an obd2 diag tool you can reset the codes yourself
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
