I have a MP1 Monitor 441 it came with the house farely new it worked fine for a few months now when i turn it on the fan turns on for a few minutes heat does not come out next thing i notice the propane has leaked out.
    Problem Solver:
  • 28 Answers
Im not positive the problem you are having maybe if you could most a little more description but be careful propane can be dangerous its heavier than air and will take longer to vacate the space although you may not smell it anymore
Posted on Aug 26, 2010
Mp1 monitor 441 ran out of oil and now wont start back what do i do
Check the fuel filter and the fuel strainer. The strainer is located on the right side of the heater at the bottom. It is on the side of the fuel sump with 2 screws holding the cover on. Turn off the valve at the oil barrel before removing the strainer and have some rags ready to catch the fuel that will come out. You may also have an air bubble in the line. Use the small screw on top of the filter to vent the filter. You can also place a bowl under the line where it connects to the back of the heater and loosen the line so you can get the kerosene flow started. Hope this helps.
Dec 15, 2010 | Heating & Cooling
My 441 model monitor heater kicks on but cuts off in about ten
Mine cut off also. I thought it was the wall plug. But as it turned out, I took the cover off the back, cleaned the filter (kinda like a blow dryer clogs in the back) and it is working fine now..... Hope that helps...
Karen
Jan 04, 2010 | Heating & Cooling
I have a LCD 19"Vison Monitor that overheats.
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Jul 31, 2009 | Hyundai ImageQuest B90A (Black, Silver)...
Blades will not turn
The motor probally damaged while you are moving the fan to the new house.
Jul 06, 2009 | Casa Vieja Probe Brushed Nickel Ceiling...
1996 A-4 Intermitent Heater Problem
may need a new heater matrix
Dec 15, 2008 | 1996 Audi A4
Monitor problem
Hi...there,
It's turns blue to power safe mode (yellow) it's prevent futher damaged to your monitor. It's seems you got a busted backlight inverter. Need to replaced a new one...Since you only got it for a few months, send it back to Acer for a replacement of a new backlight inverter... Have a nice day!
Oct 17, 2008 | Acer AL1916W 19" LCD Monitor
My monitor turns itself off
If it's only a few months old then send it back under warranty.
The fault you have is the inverter circuit.
Hope that helps. =)
Apr 12, 2008 | Acer AL2032WD 20" LCD Monitor
Operating manual for MPI monitor heater
You can obtain an electronic copy of the 441 owner's manual from http://www.monitorproducts.com/customer-support/manuals
Scroll towards the bottom of the page to find the 441 or 442 manuals.
Jan 09, 2008 | Heating & Cooling
Monitor Blanking
Buy a new monitor... It will make your eyes stop watering.
Sep 16, 2006 | ViewSonic VP191b 19" LCD Monitor
Heating & Cooling Logo
60 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
