Question about Samsung RS2556 Side by Side Refrigerator
Repair my light keeps blinking on the front door and wont get cold
    Genius:
  • 1,224 Answers
Filter replacement
Posted on May 13, 2008
Start light wont stop blinking wont start
Hello Robi, thank you for your post!
Based off what you have described your Frigidaire washer won't start and the light continues to blinks. This could be a miscommunication within your control panel or door latch. To clear out a miscommunication you need to perform a reset and that can be done by disconnecting the power cord for at least ten minutes. If the light continues to blink you may need to replace any electric component and that would best be completed by a professional technician. I hope that this information is helpful towards your repair. -Matt
Feb 19, 2016 | Frigidaire GLTF2940FS Front Loading...
Security light keeps blinking and car wont start
Either any of the door does not close properly OR the break paddle / break light button is loose and requires repair. If this does not solve the problem, report again.
Jul 13, 2014 | S10 99-04 Chevrolet Chevy Blazer Side View...
I am getting an error it is as follows: finished, spin, and wash lights blinking plus 3 beeps. What does this mean?
Try restarting it, make sure the load isnt to heavy, if that does not help, call a local repair man.
Nov 06, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
Wash load almost complete, buzzer went off, door locked & won't open. Lights all blinking. Unplugged washer, plugged back in, lights still blink, door still locked.
To open the door first unplug the machine then take off the front panel under the door (three screws at the bottom) reach in by the door lock and there will be a plastic tab hanging down, that is the manual release for the door. Pull it down and the door should open right up. I'm judging that the machine is flashing a code when it shuts down, often times its F11 or FdL in either case the problem is most often a bad CCU circuit board (whirlpool had quality control problems with this circuit board) There's what's called cold solder joints on the board at the points where the spade connectors and relays (5 of them) are supposed to be firmly soldered to the board. These bad connections cause the Duet washer to have all kinds of issues. To repair it you need to take out the CCU circuit board It's in a plastic case at the inside, top, back of the machine. Remove the case as a whole, it's easier that way. Then remove the circuit board and touch-up those points I mentioned. If you not good with solder techniques you can remove the board (keep it in the case) and take it, and this response, to a good appliance repair shop and they should be able to help you out. Good luck.
Jan 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Car wont start, emergency lights keep blinking;
The alarm is armed.Try unlocking the doors with your key
Apr 19, 2010 | 1991 Acura Legend
Yellow light keeps blinkingand the tv wont turn on
If the status light is blinking yellow it means the filter cover is open ( On the left side of televison)
If the lamp light is blinking yellow it means the lamp cover door is open. ( Behind front lower panel) If both covers appear intact the switches may be defective or not engaging properly.
Dec 11, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-62525 yellow blinking status light
Check that the lamp door is closed all the way. There is a saftey switch that closes from the door being on all the way. If not the status light will keep blinking. There is also a switch on the air filter door.
Jul 13, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Tv wont turn
The blinking red light at the the front of the television is the "Diagnostic STANDBY/TIMER LED".
This little red light will blink 2, 4, or 5 times and then stay off for three-seconds. And blink again for 2, 4, or 5 times. This cycle repeats. The most common diagnostic code is the 4-blink code.
When the red LED blinks 4-times, it means one of two possible causes:
1) +13V is not supplied on the A-board. Or, 2) IC502 is faulty.
It is best to take this television set to a repair facility and ask that the +13V power supply be repaired.
The copper tracks and integrated circuit pads are very thin and delicate on the KV-24FV12 circuit board, and will easily lift off of the circuit board, if the incorrect desoldering tool is used. Unless one has a good quality PACE vacuum desoldering unit, one should not attempt to repair the television.
Aug 17, 2008 | Sony KV-24FV12 24" TV
Samsung RS2556 Side by Side Refrigerator Logo
83 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
