Question about Acer Computers & Internet
Hi i have an acer lcd monitor (a912wdb) and the and when i turn it on its just a plain white screen and i dont know what to do
SOURCE: Lcd monitor goes white
The E151FPb's seem to have a problem of this sort. After doing some research online I've found that the most common problem is a few dry solder joints on the large circuit board inside the monitor. There was also some talk of a connector suffering from heat creep that sound be connected better on the inside, but usually that would make the screen turn black if it were to become disconnected. The monitor can be opened by unscrewing all the screws on the back, there should be 6 screws you need to pull out before being able to open the case. After those, insert a thin, but strong piece of metal into the side and sort of twist/slide it along the side and it should pop open some clips and just work your way around the perimeter. After that it's just some simple and obvious screws to get to the circuit boards.
Posted on Apr 20, 2007
  • 108 Answers
SOURCE: ACER LCD monitor no image, appears white color only
Quickly go to the Acer website and check FAQ's and while there also find out how to get an RMA to return it. My guess is you have a bad monitor. At $200 roughly for a replacement I would hustle. I am assuming you got nothing but a white screen but did get video on your TV.
Posted on Jan 24, 2008
bammbammfran
  • 159 Answers
SOURCE: DELL LCD monitor E151FPb turn white
If the screen is all white light then you can have a number of problems.
One could be a bad video board, the next could be a simple loose wire from the video board to the back of the lcd screen OR a simple blown fuse on the back of the actual lcd screen can cause the same thing.
Snaps are all sround these things and can be really stubborn at times. Best to start the bottom first then work up each side to the top.
Something flat, thin and with a decent sharp edge on it will help. A pocket knife held parallel to the joint between the front and rear plastic works, you can also sharpen the edge of an old credit card with a file (nail file works) This isn't as strong as a blade , but safer if you slip !!
Fran
Posted on Oct 11, 2008
  • 1606 Answers
SOURCE: westinghouse lcd monitor 19" - screen turns white
Fade to white might be caused by a bad or open connection to the backplane or bias voltage setting of the LCD. Check the connectors and cables between the LCD and the main board. Also, look for loose or disconnected ground wires.
Posted on Dec 18, 2008
Service Dude
  • 201 Answers
SOURCE: monitor lcd acer al 1916 half the screen is white
Theres 2 PCB on the side working one of those is faulty
Posted on May 13, 2009
Can i upgrade my old monitor to a new acer 19" Acer Monitor
Hi Ricky,
In most situations you won't need any special connections, as most LCD screens have the same VGA interface sockets and cables as your older screen.
Let me know if I can be of any further assistance.
Best wishes,
Graemevm
Jan 24, 2012 | Acer Aspire T120 PC Desktop
Samgung pc monitor has a plain white screen when turned on. Also goes off after a short while and the blue power button blinks.
plain white screen means loose conecting the lvds cable to panel. reconect it.
if its goes off then check power board +5v or +14v filter capicitor.
Feb 17, 2010 | Samsung Syncmaster 940BW LCD Monitor
My acer X193w+ screen turns pink. What is causing
laurie515, Gee, I hope it's a 'pretty pink' colour. Do you really mean that What was once WHITE or VERY Lite GRAY is now appearing pink??? Laurie515 you must tell us more. How old is this unit? 4-6 yrs? I suspect that the "Cold-Cathode-Fluorescent-Tubes" that are hanging on the rear of the LCD glass panel and provide white light, have over time, now become tired out. YOU WILL NOT FIX IT!! IT WILL ONLY GET WORSE. Here are some options. 1. Trade in for new if yours is >4yrs old. 2. Check for swapout program with ACER? This is only a dim Maybe thing. You send them yours +$50-$100 and they return a refurbished unit. 3. Find local TV/Monitor Repair shop that knows all about LCD monitor repair. there are also guys on fixya that do LCD refurbishing (new ccf tubes/inverter/smps) Do some web searches on LCD monitor failures and also visit youtube for vid clips of monitor disassembly if you want to see the insides of a typical LCD monitor.
Bye for now. I'm louie12fix on fixya or lmistyrel@ aol.com
Sep 24, 2009 | Acer X193W LCD Monitor
Acer al1716 dont work
When the LCD monitor display flickers and or has a black screen then the fault is usually a faulty inverter or the CCFL lamp. When you look at the screen at a sharp angle and you see a dim image then it is a backlight problem and it is caused by a faulty inverter or a CCFL lamp.
Check out LCD Parts for parts, service, and DIY info. Use this link to their WEB site :-
www.lcdparts.net
Sep 03, 2009 | Acer AL1716 17" LCD Monitor
Al1711 Problem....
White screen is normally a problem with the LCD panel,generally difficult to repair
Samir.
Oct 25, 2008 | Acer AL1711 17" LCD Monitor
Lcd display
Try connecting your laptop to an external monitor.Connect it with a vga cable to your monitor and press Fn+ monitor key(I don't know what it is for acer) to switch displays.If there are no lines on the external monitor then the problem is due to the notebook lcd.If there are lines then it is due to a driver.Reinstalling the driver should fix that then.
Aug 24, 2008 | Acer Aspire 4315 Notebook
My 17inch monitor
If it's plain white with not even the startup logo,problem could be a missing supply from powerboard,defective interface board or worst case a defective Panel.
Samir
Jul 30, 2008 | Acer AL1717 17" LCD Monitor
Jan 11, 2008 | Acer AL1916W 19" LCD Monitor
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
