Nothing turns on and its not the breakers or the water pan switch
  • 139 Answers
What kind of a/c is it window /central/ ?i can help ..what is the name brand ?is it a digital readout /if its a window unit let me know ..if its a window check to see if their is a reset on the cord where it plugs into wall..let me know ..good luck /joe/
Posted on Aug 26, 2010
    Problem Solver:
  • 28 Answers
Look on your furnace control board there will be a 3 amp fuse (purple) check to see if its blown if so make sure the 24 volt wires going to the a/c are not touching each other at any point then simply replace the fuse
  • RAD-doc Sep 30, 2010
    terrys_heati: what is wrong if THIS happens - I replaced the 3-amp fuse. When I turn on the air conditioner, there is a low hum for a moment and it blows the fuse again. ? ? ?
Stoves 1100E range cooker. The induction hob now constantly refuses to work then randomly beeps and flashes for ages then works again. This is daily. When not working it will not switch on with the...
As with all appliances. When in doubt turn off the main breaker to your hob. Wait 20 seconds. This might fix it. Next try a different element. Some of the ranges require you to turn the breaker on with cook top covered. If it still has problems try changing your frying pan.
Buy it from a repeatable store so you can return it if it is not the pans. Lastly. Try moving it in the surface as it will click until it finds the pan. Good luck.
Feb 27, 2015 | Stoves Sterling 1100E Stainless Steel...
Won't turn on
Please provide system type,make, and model number.
Nov 30, 2014 | Heating & Cooling
Hi, I have a dishwasher model sgs5022gb/07 that won't fill with water. Also the dial doesn't move round as the program progresses. This has happened before but it corrected itself. It's like...
The flood switch is tripped. This is located under the unit. Unplug or flip the breaker to the dishwasher, take off the black kick plate under the door, 2 screws, and you will see the white plastic "pan". The flood switch is located where you can't really see it but it is on the left hand side wall and is made of styrofoam. The best thing to do is to put some rags in the pan, this is not easy because there is little room to put them, and soak-up the water that has filled the pan. Eventually you will get enough water out that the float will deactivate the switch. What you hear "running" when you turn it on is actually the drain pump, it get activated when the flood switch is tripped.
Jun 30, 2011 | Bosch Dishwashers
Were is the reset button on the unit?
Hi, here is the theory on the reset button on Air Conditioners. They reset via the breaker panel box in your house. Check that first before anything else. However if your unit is popping breakers, it is because the rating for the breaker is incorrect, or there is something that needs servicing usually in the outside unit called the condenser. That piece contains the compressor. A faulty compressor and pop the breaker. Or If the condenser fan that blows over the coils of the outside unit stops (common failure) The compressor will overheat and shut down. That may not trip the breaker but the house will get hot anyway. Usual action for this is to replace the condenser fan motor and starting capacitor. Make sure the speed rating and directional rotation for the replacement motor is the same as the motor removed.
There are other reasons why the system won't come one fully. If the wall thermostat is digital and does nothing. including turning on the fan. There will be a small fuse located on the circuit board of the air handler (part of Air Conditioner mounted inside the house. It houses the circulation fan). That fuse could be blown. That one shuts down just about everything.
On air handlers mounted up into the attic crawl space there is an overflow pan. This pan is mounted directly below the air handler. This pan can fill with water when the drain pain contained inside the air handler starts to overflow because the drain system to that is clogged.
There is a "float switch" mounted in the overflow pan wired to the system in such as way as to shut down the entire AC system if that pan fills.
The handling is to clear the obstruction in the Drip Pan inside the air handler. Then remove enough water from the overflow pan and the AC will run as though nothing has happened.
If you have more questions, write to me on this site.
One thing more. The capacitor alone in the Outside condenser unit can fail and that will stop the condenser completely if it is of a "split" design and used for both the compressor and fan. When replacing this unit alone, ALWAYS find the same specification part.
I hope this helps,
Have a Happy New Year,
Mark
Jan 02, 2011 | Goodman CLJ30AR32 Air Conditioner
Hi - my Viking dishwasher has developed a problem where the pump runs continuously, whether the power switch is ON or OFF. After the power is turned ON, the troubleshooting guide indicates that there is...
if you open the kick plate, you'll see the pan below the motor and check for leaks. The leaks will trigger the sensor to pump water out. Once you dry out the pan, the pump motor will stop and you should be able to reset the program.
Oct 15, 2010 | Viking DFUD042 Built-in Dishwasher
I pulled the thermostat off the wall, and it is getting no power. All the breakers seem to be fine. Still nothing
go to common and hot, if you don't have 24 volts then check air handler for blown low voltage fuse or if all breakers are good the transformer is probably blown, or your drain pan may have water in it causing the float switch to shut the system down.
Oct 27, 2009 | QMark HBB754 Hydronic Baseboard Heater -...
RUUD Air Conditioner not turning on
Need to check the breaker to the unit at the electrical breaker box. You should have a dual 60 amp breaker that runs the unit. Also if you removed the front of the furnance on the inside the system will not work unless the front of the furnance is on. There is a safety switch that will not allow the system to run with the door off. There could be the problem if the breaker is on and electricity is supplied to the unit that switch may be out and need replacing. The furnance is operated on 110 volts the condensor (outside section) operates on 240v you need to insure that the proper voltage is supplied to both.
Since both units work together yet operate seperately if the furnance comes on and the condensor doesn't then there is an electrical problem at the condensor (more than likely the contactor switch) if the condensor comes on and not the furnance then there to is an electrical problem (either 110 volts not supplied) or the switch to the safety cut off is bad. Now if neither furnance nor condensor comes on there could be improper power to both or a bad thermostat since the thermostat activates both furnance and condensor. Good Luck on repairs
Dave
Sep 04, 2009 | Ruud UBHC Air Conditioner
Asko 1805 ALL lights flashing and no water coming out
High water level is often in the pan under the dishwasher.
  1. Unplug or turn off breaker.
  2. Remove kick panel.
  3. Remove water from pan.
  4. plugin/turn on breaker.
  5. watch for leaks.
May 30, 2008 | Asko 24 in. 1885 Built-in Dishwasher
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
