Question about Goodman CLQ36AR49 Air Conditioner
My A/C turned off. Still blowing air around. Hot air. Outside the A/C itself is not on. Any ideas???
    President:
  • 3,074 Answers
The air handler is running but the outside conderser is not. On the corner piece above the lines there are four screws, unscrew them and remove cover. Inside there is a contactor you have L1 L2 L3 and T1 T2 T3 and there is a coil in between them. O'kay we need to make sure we have power coming to the contactor so check to make sure it has power, if not then outside near the unit there is a fuse/breaker box. O'kay we have power so its not the outside fuse box. Now we need to make sure that the air handler is sending the 26 volts to the contactor, these are two small gauaged wires hooked towards the back of the contactor. You can also push the contactor in with a insulated screwdriver and it should engage the fan and compressor. O'kay we have the 24 26 volts from the air handler. We check for power ontop of the contactor we have it, so now it is either the fan/capicator or the compressor. To check compressor it is just a matter of taking off the other three screw and disconnecting the fan and lift the top off of the unit. then leaning over into the unit unsnapping the cover and making sure that the three wires are connected to the compressor. Since it is not tripping a braker it is not locked down compressor or shorted compressor. More then likely it is something with the contactor or the fan. If everthing checks good then evidently there is a leak and the freon is low and cut out on pressure. Hope this helps tim
Posted on Aug 26, 2010
    Problem Solver:
  • 28 Answers
If you open the bottom panel of your furnace you will find the controll board there will be 4 wires coming back from the thermostat and 2 going to the a/c the 24 volt hot wire for the a/c will be hook to the yellow wire coming back from the thermostat take them off the board and wire nut them together this will do the trick in many cases
2 Suggested Answers
AcJim
  • 107 Answers
SOURCE: Goodman A/C won't cool
Fan motor or capacitor has gone out. Running the unit with the motor not running can cause damage to your compressor
Posted on May 01, 2010
Replaced a starter capicator, now it just bloweswarm air
On hot day your unit may not cool enough. Make sure that outside unit is clean, filter inside should be clean. If all above is good your unit may be low on Freon.
Aug 11, 2014 | Dometic Heating & Cooling
Why does my pt cruiser blow hot air when a/c or just turning on outside air?
It's probably that the air tubes lines are already hot due to the hot weather(car parked outside in the sun) and it takes 2-5 for the AC to be blowing air at the correct temperature.
Solution: Turn the AC on but reduce the fan speed to bare minimum for the at least 2 min. After that, crank it up and you should be able to enjoy the cool refreshing air.
May 23, 2014 | Chrysler PT Cruiser Cars & Trucks
Chevy 2005 tahoe z71 blows cold air in back but hot air in front
Just got an answer from Chevy Dealer. When you replaced the battery it loses its memory as to where the door actuators were (the flaps that control the heat and A/C).
The fix:
Turn everything off and let the car sit overnight. The computer should reset itself during its learnings process.
In the morning turn on the ignition and let the car run for a few minutes before turning on the climate control.
If this doesn't work, plan on 1-1.5hours of labor for a technician to reset the actuators at the dealership.
Good luck.
Car Headlights.
Jun 01, 2012 | 2004 Chevrolet Tahoe
2000 nissan altima blows cold until outside temp reaches 90 degrees then blows hot
2000 Nissan Altima Heater Air Condition Section HA 76 pages Here is factory service repair manual for your vehicle . Do you know how to do testing on these system ? Automotive electrical system testing ? How to read a wiring diagram ? When hot outside is the inlet pipe to evaporator freezing up ? Do you know where this is , under the hood in the engine compartment at the fire wall . What are gauge readings , Is the compressor engaging ? Were any switches replaced ? Ambient temp. , thermal transmitter switch . pressure etc...
Apr 25, 2017 | 2000 Nissan Altima
We have multiple A1200ep Ask Proxima projectors. We are having a problem with two of them. They just shut off after a period of time even when your in the middle of using them. It's like the projector...
Clean air filters. DO NOT BLOW INSIDE!!!
Take the filter out andust it out somwhere outside.
If it does not help, more likely there is fault inside.
Possibly power supply.
Mar 07, 2011 | ASK Proxima DP1200x Multimedia Projector
Cold air blows outside and hot air inside
Make sure it is in cooling mode. Sounds like you may have a problem with the reversing valve but you would want to check the pressures in the system first and make sure the charge isn't low.
May 02, 2010 | Heating & Cooling
COMPRESSER IS VERY HOT, FAN OUTSIDE BLOWING COLD AIR OUT NOT HOT
Most likely the unit is low on refrigerant. You could also have a restriction in the system. You need to put gauges on the unit.
Jun 14, 2009 | Ruud UBHC Air Conditioner
Dual automatic air temperature control has one side blowing cold
What have done at the dealer before and works you should have bills should be an explanation.
May 11, 2017 | Lincoln LS Cars & Trucks
Only blows hot air inside
Set thr thermostat to AC instead of HEAT.
Dec 29, 2008 | Carrier 36KCARMS Air Conditioner
Goodman compressor cuts off when temp too high
I believe you have 1 of 2 problems going on here your system may be overcharged causing the compressor to cut out on a overload relay circuit internally, or it also could be tripping out a high pressure switch which could be from an overcharged system or a dirty condenser. I would have the tech come out on a 90 degree day and put the gauges on and check the pressures while it is operating under a full load.
Hope this helps you.
Please rate me
Jul 19, 2008 | Goodman CLQ36AR49 Air Conditioner
Goodman CLQ36AR49 Air Conditioner Logo
82 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
