Question about Sony KP-51HW40 51" Rear Projection Television
After initial warmup ~15 Seconds, the screen glows red. You can still make out the images but what should be black/dark is red. Sound is ok, and I have the same symptoms regardless of the video input, direct cable, cable box, DVR.....
    Genius:
  • 1,112 Answers
Hi:
This a common problem with sony rear projections, You should start with the most common solution to repair before futher diagnostics or repair.
Posted on Aug 26, 2010
My screen is all black with the words no database what does this mean ?
When the following symptoms, the need for LCD inverter with a: No image on the screen, but the power light stays on
Dark display but still readable
Between the screen flashes on and off 1/2 to several seconds
Power light stays on, but no display and sound
No image on the screen, but LCD TV still has sound
Picture cycle on and off, as well as high-power LED lights
Aug 04, 2013 | Sceptre Computers & Internet
Dim/dark screen on my lg50pc3d tv
After its on for 15 minutes, feel the heat sinks on the y board ( on the far left side) if they are cold then replace that and the upper and lower drive boards that attach to the Y main.
Aug 05, 2012 | LG 50PC3D 50 in. Plasma Television
The screen on my camera is black. You can still see the text on top of it, the battery meter, and the flash sign but other than that, it's just black.
This may be due to the CCD Image Sensor failure in the Camera.
To confirm the issue, please check if the previously captured images are displaying normally. The previously captured images and icons will get displayed normally if the CCD issue is there in the Camera.
If this happens only with the live view, then try Initializing the Camera.
The Initialize option can be done only if the Menu of the Camera is accessible. To access Initialize select MENU-->SETTINGS-->MAIN SETTINGS-->INITIALIZE-->OK.
The RESET button is located at the lower right side of the control button. To reset the camera, press the RESET button using a sharp-pointed object.
You may also try power resetting the camera. To power reset the Camera, remove the batteries from the Camera and then press and hold the POWER BUTTON of the Camera for 15 seconds and then reinsert the batteries after 1 minute and check if the Camera works normally.
If the issue is not resolved after resetting, service may be required.
Thanks for using FixYa.
Jan 17, 2011 | Sony Cyber-shot DSC-WX1 Digital Camera
The images apprear purple on the screen, and dark in patches. New photo's taken, come out purple. But existing photo's appear on the screen as, normal.
If the previously captured images are appearing fine in the Camera, then the issue is with the CCD Image Sensor unit only. Check if the display icons are appearing normally on the Camera screen.
Try power resetting and Factory resetting the Camera to check if the issue can be resolved:
Power reset:
Remove the batteries from the Camera.
Press and hold the POWER BUTTON of the Camera for 15 seconds.
Then, reinsert the batteries after 1 minute.
Factory reset;
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1 Menu of the Camera to OK.
Home-->Settings-->Main Settings 1-->Initialize-->OK
Aug 06, 2010 | Sony Cyber-shot DSC-T100 Digital Camera
When booting screen goes on for a second and blank after that
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :- To determine if you have a LCD screen or video card problem, read this and follow the instructions. Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case. The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills. Check out www.lcdparts.net for parts, repair service and DIY info.
Jun 11, 2009 | Fujitsu Computers & Internet
Monitor Problems
Defective CCFL backlight may has the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
Mar 30, 2009 | Dell Inspiron 9300 Notebook
No image on monitor
Looks like the Video card, or Video chip has bought the farm
Try hooking up to another monitor to confirm where the problem is.
Jan 30, 2009 | ViewSonic VX922 19" Monitor Flat Panel
Sony KP-51HW40 51" Rear Projection Television Logo
22 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
