Question about Canon LV-5210 Multimedia Projector
My Canon LV-5210 displays no image for my computer. It has worked fine in the past. And it did not work a couple days ago and then it worked OK yesterday when we accidentently pushed the Input buttom. But now it displays no image again. I have been following the Manual to do the following but still getting no image: 1) Computer 1?RGB (PC Digital)?[the fourth image with an arrow] or: 2) Computer 2?RGB (Scart)?[the fourth image with an arrow] What else can I do? Thanks, John
  • 857 Answers
If your projector displays no image, this could be a variety of problems. First, check that the projector has power. On the top of the LCD or DLP projector should be some lights. With power, those lights will be on. If it has power, check to make sure that the projector lamp is firing. If so, go to the source. Make sure that it is connected with a VGA cable or USB cable to your computer, or with an RGB cable, S-Video cable or DVI connection to your VCR/DVD Player. From a laptop computer, the VGA cable should be connected to the VGA out connection, and into the VGA in connection on the projector. Are both ends tight?
If everything has checked out so far, the solution probably lies with the external monitor port. Check this by holding the Fn key on the keyboard, then press the F7 key. (On some computers, the key might be F5 or F3. Try these if F7 doesn't work) Each time you press the Fn / F7 combination, you will cycle your display through the following settings:
* Press Fn / F2 or F2 once: The laptop screen only
* Press Fn / F2 or F2 twice: The projector port only
* Press Fn / F7 or F2 three times: Both the laptop and projector port
* Wait a few seconds after each time you press the key combination to let the LCD or DLP projector refresh. Nine times out of ten this will result in seeing your projected image.
this should help you :)
Posted on Aug 26, 2010
  • CaleVT Mar 22, 2011
    Thank you very, very much...it solved the problem in a couple of key stokes. Thank you again.
Horizontal lines in display
Canon LV-5210 Service I have a problem with my projector cable will connect the three colored yellow and red travaja not tanpoco and white so little that I can change to part travaje my Canon LV-5210 Service Peden me to say which is the part that must be changed
Sep 28, 2012 | NEC NP3250W Projector
Canon LV-S1 projector keeps shutting down after a minute or less
1,Check the fans ,whether each fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
Jul 15, 2012 | Canon LV-LP12 Projector Lamp for LV-S1,...
Canon LV 5210's warning led turns red and turns off directkly after start.
warning problem related to lamp, already encountered that kind of problem replace the lamp assembly and it work.
Apr 12, 2010 | Canon LV-5210 Multimedia Projector
My canon powershot a95 display screen does not show an image when I am trying to take a picture. The image that is displayed is black with white lines and varies in the amount of black and white. No matter...
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
Oct 10, 2009 | Canon PowerShot A95 Digital Camera
Went out of town yesterday, hooked my canon 5210 up just like I always do, and got no response from the macbook. Luckily there was another projector available, and it worked. Seems to be the projector, not...
My problem didn't get solved, but my frustration was that I got a technician online two or three times, but couldn't post a response! The program wouldn't accept any input from the computer! So I was muted!
Jun 24, 2009 | Canon LV-5210 Multimedia Projector
Canon LV-S2 projector not work with component signal input
Try unplugging the projector. This seemingly works but I can't figure out WHY....
Mar 18, 2009 | Canon LV-S2 Multimedia Projector
Need to replace lamp in canon projector lv5210 need to know how t
Manual is available for viewing/download here. Instructions for changing the lamp are on page 43, and for resetting the lamp counter on page 44.
Jan 29, 2009 | Canon LV-5210 Multimedia Projector
Black pictures when using flash
The black images with flash mean that the Iris mechanism in the lens is not working properly, and that needs a professional camera repair service.
Best regards,
Oct 19, 2008 | Canon PowerShot S2 IS Digital Camera
Vertical lines obscuring image
The matrix is dead. Probably because of an intensive light got into the lense while the camera was in night mode. It's dead. Nothing can be done.
Jul 24, 2008 | Canon PowerShot A80 Digital Camera
Blank black screen for my canon powershot S1 IS digital camera
This is a common problem with S1 IS and it is caused by faulty CCD sensor. Note that you can playback captured images without any problem but in capture mode all you get is blank screen. Will have to go to Canon but note that Canon repairs these models free of charge when it is the CCD sensor that stops working.
Sep 14, 2007 | Canon PowerShot S1 IS Digital Camera
Canon LV-5210 Multimedia Projector Logo
428 people viewed this question
old marine
old marine
